Question about Philips 36PT842H 36" TV
Phillips hd 55 inch
Behind my screen protector i see spiderwebs hanging and a dead spider. i dont know if it's directly behind the screen saver or in the back of the tv and its just the projection making it look like it's right there in the front of tv.
    Novelist:
    Champion:
  • 236 Answers
It could be either place probably on the back of the screen itself. If it were on the picture tubes it would be big. You'll have to take the back off and check it. Stargazer
Posted on Apr 23, 2007
I have a Toshiba tv that is connected to Direct tv and I want to know how to connect my new Phillips dvd player to it my tv?
Flat screens normally have 3 different inputs from tv. Regular is tv coax cable, then audio/picture by using special rca cables, then last HDMI. You can use any of those inputs except hdmi because you already are using that input. You may be able to buy a hdmi splitting device that will allow both the tv and the player to input to the single hdmi input. Check Radio Shack or Wal-Mart.
May 12, 2014 | Toshiba HD-A30 HD-DVD Player
Have a 52' Panasonic projection HDTV & a spider
you just open your tv by using the tools needed match on the screws.if you fear to open your tv you go to the nearest technicans over you.
Jun 11, 2011 | Panasonic Televison & Video
Take off screen on hdtv misubishi 62628. the screen has a spider web behind it and i want to clean it out
To remove the spiderwebs, you don't need to take the whole thing off. You just need to remove the screws around the screen frame (top and sides). The screen frame and mirror cover can be separated several inches with ease. You just need to use a flexible duster, one of those electro-static attracting numbers would be great, to clean the web out. Be careful not to disrupt the rear, large mirror and don't scratch the screen. Good luck.
Mar 15, 2010 | Mitsubishi WD62628 62" Projection HDTV
Spiderweb effect on lcd screen
only solution is replacing entire screens. very expensive, try finding manufacturer on internet.
Dec 02, 2009 | Televison & Video
Phillips 55 inch rear projection tv red convergence screwed up
Install the DPTV305_DPTV345 Chassis convergence repair kit. You can get the kit at the following link and it contains the parts plus instructions on CD.
http://www.tvrepairworld.com/
Jul 25, 2009 | Philips 60PP9202 60" Rear Projection...
Need plexi-glass cover off my mitsubishi hd 1080 projection tv.
the plastic trim pops off and there are screws that hold the glass in place that you have to take out to be able to remove the plexi. it takes about 20 minutes to do
Jan 27, 2009 | Mitsubishi WS-55513 55" Rear Projection...
55 inch projection tv
BUSTY35,
Here is your screen info = protector...PS5501....$155.00
Lenticular = 23430819....NLA Fresnel..23430635...$135.00
...........................................T.
Dec 17, 2007 | Televison & Video
Spider on screen
You must remove the top back cover, but be careful and handle it gently because the mirror is attached to the inside of that cover. When the cover is removed you will be able to clear out any spiders, spiderwebs and dust and be sure to clean the 3 lenses on top of the 3 picture tubes.
Aug 09, 2007 | RCA P52926 52" Rear Projection Television
Spiderwebs under Screen, how do i clean it ?
Yes, I have seen this many times. Usually the best way is to remove the upper back cover and clean out the spider webs with a soft, dry cloth, but be careful because the mirror is mounted to the inside of the cover.
Jun 24, 2007 | Hitachi 50FX18B/19K 50" Rear Projection...
Sider webs
Here's my suggestion: I have a 55" Philips HDTV and I live in an area known for excessive dust and more than a fair share of spiders. I checked online and found that there are usually 1-4 access panels that can be removed for cleaning, repair, etc. Here are my steps: 1. Remove the upper most panel (usually a trapezoid-shaped plastic "box"). There are anywhere from 1-4 "hangers" that, once all the screws are removed, will hold the panel in place while you are unscrewing the last few screws. 2. Remove the panel and clean with a lint-free cloth the entire inside of the panel. This is an area where a lot of dust and spider webs can be found. 3. Grab your vacuum cleaner and carefully clean away all the spider webs. Making sure you don't bump into the inside of the projector screen! 4. Spray a small amount of dust cleaner or window cleaner on the lint-free cloth and run the entire length of the TV. Clean all surfaces this way except the reflector (mirror). It is best to clean the mirror with compressed air (get it anywhere - usually in the computer section). 5. Using a flashlight or bare lightbulb, thoroughly inspect all surfaces for dust and spiderwebs. And, of course, clean anything missed the first time around. 6. Using a clean lint-free cloth (I find cotton underwear from Wal-Mart works the best), spray a very small amount of window cleaner (streak-free Windex, etc.) on the cloth and rub the cloth together until almost dry. Then, simply wipe all three lenses clean. 7. Replace the back panel and pay close attention to the alignment of the holes to ensure the screw goes back in the same way it came (if not, the panel could ultimately lose the seal and allow for more dust). 8. Allow for several minutes drying time before turning the set back on. Hints: 1. Clean the speaker area, too. 2. Repeat the process at least each 30 - 45 days to ensure optimal performance. 3. Use a small computer fan to circulate air behind the set if the area gathers excessive dust. They're quiet and can be purchased (almost anywhere - Radio Shack, Wal-Mart, etc.)with switches that are easily accessible.
Sep 01, 2006 | GE 46GW947 46" Rear Projection Television
Philips 36PT842H 36" TV Logo
57 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
