Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Bad contrast and there is a high-pitched intermittent whine
My son says the front needs to be removed and the mirror and bulbs/tubes need to be dusted. I won't let him do it unless I know it might work. A bad picture is better than no picture--I can't afford to replace it
  • 10,594 Answers
You son is right if TV has low contrast and brightness in picture.
It doesn't cost any thing and just needs cleaning of front screen and lenses with soft cotton cloth.
Posted on Dec 26, 2008
  • 15,935 Answers
There are no tubes on a rear projection. 3 lights red blue green. One may be out, or in need of all 3. The entire projector can be accessed thru a few screws at the rear of the TV onve it is removed, bulbs can be cleaned, and you can access the cabint for cleaning.
  • blueextc3221
    blueextc3221 Dec 26, 2008
    Lamp Replacement: This is the biggest detraction to rear projection televisions because lamp replacement can be expensive. A typical replacement lamp for DLP, LCD and LCoS costs at least $200. Most rear projection owners will have to replace a lamp every 3-5 years. Owners of CRT rear projection have an added disadvantage in that when one of the three guns (red, green, blue lamps) goes bad, it is recommended to replace all three to keep the colors balanced. Replacement of those lamps is even more expensive because a professional technician is likely needed to install and calibrate the lamps.
  • 4,472 Answers
Sounds like the color wheel at first glance, how long have you owned the set? Once I have more information I can assist you further.
Thank you,
lee
High Pitched Whine
A high pitched whine like that indicates a bad bearing. Water pump, power steering pump, accessory belt slipping, alternator bearing, or in the worst case scenerio, Transmission pump.
Dec 12, 2013 | 2001 GMC Yukon XL
Distorted loud static sound consistantly on phonak unit one year old
Ensure the acoustic tubes are not obstructed. Detach them from the hard plastic flesh coloured part and clean them in warm soapy water, rinse and dry/allow to dry. Reassemble.
There is a possibility that this might be caused by the gain of internal amplifier being set too high, though this usually results in a constant or intermittent high pitched whine. Try adjusting the recessed wheel on the unit.
If neither of these measures cures the fault, you will need to take it to a technician, return to the supplier/manufacturer, or/and replace the unit
Aug 12, 2013 | Select Products Hearing...
Continued battery drain and high pitched noise when car started
Maybe the alternator is bad. A high pitched whine could mean that the alternator is not working properly.
One can test, by removing the belt to the alternator and running the engine and seeing if the whine goes away.
Jan 16, 2011 | 2000 Toyota ECHO
Exact problem, lamp comes on, no picture, lamp light flashes.
remove the lamp and with a light and or mirror look where the front of the lamp faces--there is a color wheel there--if it is shattered or damaged the set will not come on--most of these sets have a high pitched whine or grinding noise if this happens---the wheel is available on the internet and a moderate job to replace--I have seen lots of them bad---if you want an idea of what it looks like--etower.766@netzero.net Steve
Aug 10, 2009 | Samsung HL-P4667W 46" Rear Projection HDTV
High pitched buzz/whine during wash cycle only, spin fine
1) Make sure valve is open all the way 2) some machines have a screen inside of the hose hook up which could be clogged. 3) last check to see if it is the hot or cold by switch your selector switch on your machine to hot then cold. If one of these positions eliminate the noise then the valve in the machine is bad.
May 16, 2009 | Maytag Atlantis MAV8000
High piched whine on left front! 2001 dx
hat u need to do is drive vehicle until you hear this pitch once you hear it turn steering to the right to see if whine disappears if it does you are looking at replacing wheel bearing.
Feb 26, 2009 | 2001 Mazda MPV
High pitched whining
Sounds like a tube TV . If so I believe the tube is cracked not hard to do during moving Ive done it before. it can be replaced for around 125$ to 200$ look at how much your TV is worth and if it does not exceed the value of you unit . Then locate a repair shop in the yellow pages.
Oct 05, 2008 | Computers & Internet
High pitched whine
Ok maybe this may help .... there is a coil LL08 I believe... somtimes it creates a high pitch whine like you describe.. its stands up on the deflection board..it basicaly a large coil of copper wire....you can take silcon and put on the coil...in effect damping the ocillations...hope that might help
Mar 27, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
37 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
