Philps magnavox 50mf23id/37 hdtv
Tv does not turn on. downloaded software still no change. help!!!!! tv is still dead.
  • 13 Answers
SOURCE: 32 in Magnavox tv model 32MF231D/37
An earlier post of the smaller model of this with the same problem said to remove the metal cover over the power supply.
I have the 26MF231D and it worked great afterward (even though you can't mount it)
Here is how you remove the cover.
http://www.flickr.com/photos/88002248@N00/sets/72157611665895426/
Posted on Dec 26, 2008
MNfisherman
  • 11896 Answers
SOURCE: Tv went off and won' come back on.
Most likely you will have to replace the power supply. It is a very common problem especially in newer electronics. You can test it with voltmeter or multi-tester. They tend to get worn capacitor inside the power supply due to cheaper parts
Posted on Aug 24, 2009
  • 11 Answers
SOURCE: magnavox 37MF331D/37 keep asking for software upgrade
Your set either has a bad SSB (small signal board) or needs a software upgrade. Try the upgrade first by going to http://www.m4c.magnavox.com/cgi-bin/dcbint/cpindex.pl?scy=US&slg=AEN&cat=FLAT_TV_CA&sct=LCD_LARGE_30_40_SU&grp=TV_GR&session=20090830171041_4.131.87.247&ctn=37MF331D/37&mid=Link_Software&hlt=Link_Software
Download the latest software release for your set then follow install instructions that are contained in the user manual for your set.
Posted on Aug 30, 2009
  • 8 Answers
SOURCE: magnavox 37" flat screen model no.37mf23id/37
Yes, he means 2200 microfarret (called uf from here on out). Another important concern when buying a replacement is the voltage. You need to get something that is at least 25v. I recommend a 35v or better. Another notable point is that this may not always fix the problem. As with mine, there was also a 1200uf (microfarret) 35v capacitor that was blown. You can tell this because they bulge at the top. I have both of these caps (2200uf 35v and 1200uf 35v) on order and they will be here tomorrow. If I do not post back here then they fixed the issue for me. I suspect that this will resolve the problem. Look for bulges on top of the caps. This is an indication that they are blown. Most all of you experiancing these symptoms will see the 2200uf cap bulging but you may also see others bulging too. If you do then you need to replace those too. No electrolitic capacitor should be bulging at the top so if its bulging its bad, and if its bad then your tv will definitely not work. Have fun.
Posted on Oct 13, 2009
budmrtn
  • 11361 Answers
SOURCE: My 2 year old Magnavox 37MF231D/37 LCD TV just
The problem can be in the backlight inverter board (hard to get to), or the main power supply module may not be working. Look at the power supply first since it is easy to get to, look for burnt parts, bad capacitors.
http://en.wikipedia.org/wiki/Capacitor_plague
Please
Posted on Nov 11, 2009
Fixing a Philps 42PFL7432D/37 Flat Screen LCD TV that isn't turning on.
The video driver board is likely at fault here. Test it per the factory repair manual.
Sep 12, 2016 | Televison & Video
My magnavox 51mp6100d/37 rear projection television has a distortion problem. When I suse the adjustment box for the rgb tubes, red is fine, blue seems to just apply a blue haze, not really go great...
This problems is not the lamp problems.This problems is call convergence problems.The colors R,G,B mis alignmrnent, have ghost picture or 3D pictures.The tv convergence board,the 2 STK convergence ICS and some or all it resistors are dead.These parts nust be change in the convergence board to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Sep 02, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
My magnavox model 50MF23ID/37 is 4yr old. tv wont
If you hear a clicking noise that sounds like the ballast trying to power on the lamp, but nothing happens, the lamp may be faulty.
http://www.discount-merchant.com/
Here you can get your lamp that most likely needs replacing.
Mar 26, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
My 2 year old Magnavox 37MF231D/37 LCD TV just blew the picture screen. The audio comes through fine, but the screen is dead black with no menus, info, nothing. I tried various inputs, same result. I...
Please
Nov 11, 2009 | Toymax Magnavox 37MF331D 37 in. LCD TV
My tv picture is light and hard to see and will periodically shut off.its only abput 5 yrs old/
For a Philips LCD TV, that's at least two years longer than they typically last. The most common problem with Philps TVs is the power supply board, which could cause the TV to shut-down by itself. The picture being too-light could happen for several reasons. In general, a repair shop needs to figure out what's wrong.
Nov 02, 2009 | Philips Magnavox 42MF521D/37 Television
Dead set
you can look at the capacitors on the power board if any of them have puffed up tops that is the ones. Also when you are looking at the power supply look under the heat sink at the top right they try to hide one.
Sep 06, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Magnavox 37MF331D/37 keep asking for software upgrade
Jul 22, 2009 | Philips Magnavox 15MF400T 15 in. LCD...
Magnavox 42MF230A/37 Plasma TV should i fix it? ?
you will need that part to repair yours. i recomend using the heatsinks from yours. u need to check the FETs on the board that drives that one before u power it up, or u could damage the new part.
Dec 05, 2008 | Philips Magnavox 42MF521D/37 Television
42pf9956/37 philps plasma
I don't know why but this got my TV on.
I took off the back cover and found the source of the clicking.
Two blue plastic rectangular relays in the exact middle.
When I pushed the power button, I felt the top relay click, and I saw a flash from the bottom one. (they are right next to each other)
I took a hair dryer and placed it over the two relays for about 1 minute and tried the power.
It clicked only 4 times and then came on!!!!!!!!!
For some reason heat helps the relay.
If anyone is a tech and can explain this, please do.
Good luck!!!!
My tv is on and it didn't cost me anything.
I just can't turn it off now!!!
Sep 25, 2007 | Philips Magnavox 42MF521D/37 Television
Televison & Video Logo
137 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
