Question about Canon PIXMA MP210 Photo All-In-One Printer
Installation Just trying to get it connected to my computer without the instal disk. Any tips?
    President:
  • 1,179 Answers
If you do not have the install disk then try the Canon website. They should have drivers available for download in their support section. The driver is what you need to get the computer to see the printer. Hope this helps.
Posted on Dec 26, 2008
  • Roy Lonsinger
    Roy Lonsinger Dec 28, 2008
    This is the only way you will get it connected without the disk.
Presario CQ57 model compaq laptop Widows could not update the computer's boot configuretion. Installation can not proceed. solve this problem tips
Sounds like you will have to re-attempt a clean install from a Windows installation disk. Unfortunately, the disk will need formatted. You can use a recovery or boot disk to do so.
Apr 07, 2014 | HP Compaq Presario CQ57-229WM Notebook PC
Computer is not reading the installation disk
By installation Disk do you mean the CD/DVD-ROM? If yes
Check to see if the drive's LED flashes when the system is trying to boot. If it doesn't, open the system and make sure all the cables to the CD/DVD- ROM is properly connected and to the right slots. If the cables are properly connect and the CD/DVD- ROM is still not working replace the CD/DVD-ROM.
However, if its that the system could not install a particular program, make sure the installation files are complete and try again. If its a downloaded program, verify the completeness of the file downloaded and try reinstalling the program.
Feb 13, 2012 | Peachtree Software Computers & Internet
Trouble shooting new os 10.4 tiger installation on mac pro
You sure you got the original gray label install discs for this computer? Sometimes people stick gray discs in with the computers and they are not specific for that model.  The Macbook Pro ships with Tiger 10.4.6
Borrow a black label Tiger retail disc from someone and install your OS that way.
Oct 27, 2009 | Apple MacBook Pro Laptop Computer with...
Lost install CD for Canon PIXMA MP160
all you have to do is download the install software from canons website. it's free and easy.
Mar 01, 2009 | Office Equipment & Supplies
Computer crashed
It should not be necessary to have the installation disk - you can configure the router for wireless use by going into your browser and typing into address bar 192.168.1.254 (I think this is right from memory) - the username & password for accessing the router utilities is by default "admin" (without the quotes) - you will need a wired connection to accomplish this.
Otherwise, if you are using a wired connection, it will connect automatically. Good luck!
Feb 14, 2009 | 2wire (1000-400108-001) Router
Need the installation disk
hello,
Ok try to hook and see if the system install it without a installation disk.
If this not resolve, then you have to find driver at lexmark websites.
http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=229:1:0:0:0:0
may this help.
melnavz
Jan 23, 2009 | Lexmark X6570 InkJet Printer
I have a CanoScan LiDE 70 scanner. It won't speak to my computer. It is plugged in to USB. Message appears saying try switching it on, but I can't find any switch. Icon appears in directory. Tried re...
first check whether u have installed all the usb drivers
then uninstall the scanner software and install it again without connecting your scanner.
there is no switch on it u will have to remove the power connection
restart ur computer when u finish installing the drivers
connect your scanner when u restart ur computer
Nov 13, 2008 | Computers & Internet
Lost my installation disk
Here is the driver download page:
Lexmark Z640 - Drivers & Downloads
Download the software into your computer, locate downloaded files and start installation program.
Start installation with printer USB cable unplugged, plug when required by software setup.
Vote the solution.
Thanks
Aug 15, 2008 | Lexmark Z600 InkJet Printer
When I try to reinstall my router I can't get beyond the first step as the disk thinks our computer is not connected to the internet when it is. It convinces my computer that it is no longer connected....
Step 1: Turn off your computer, router, and disconnect the power to the modem.
Step 2: Connect one cable between the modem and the router's internet port
Step 3: Connect another cable between the router and the computer.
Step 4: Turn on the computer, then the router, then the modem - in that order.
Step 5: Now try running the setup disk.
Explanation: The modem has a security feature that disallows more than one device from connecting to it at one time. Once a specific device is connected, the modem expects that device to be connected at all times. If you unplug your computer from the modem and plug in the router without disconnecting the power to the modem, the connection will be rejected. This probably explains the reason for the error message you were receiving.
Furthermore, you do not need the installation disk in order to install your router. Open your browser and type http://192.168.1.1 in the address bar. A username and password screen will appear, the default is usually admin/admin for both, but if that doesn't work just try admin in the password field. When you have successfully logged into the web utility, you will be able to alter the settings at your discretion. For the most part the router will work upon proper cable connections, however you will want to enable security features to prevent attackers from gaining access to your computer.
May 04, 2008 | Computers & Internet
Canon PIXMA MP210 Photo All-In-One Printer Logo
57 people viewed this question
old marine
old marine
