Question about Philips DVD763SA DVD Player
Philips DVD 763SA Player Problem
Hi FixYa,
We have the above mentioned Philips DVD Player but sometimes it works and sometimes it doesn't.  It only works if we unplug the player, replug and try to play the DVD.  Most time the DVD player has started and then began to jitter (going into slow motion).  We'd unplug and restart the DVD about 2 to 4 times and then finally the player would work (as long as we didn't fool with the controls).
I'm assuming this Player is on its way out, but since it is a multi-region DVD player and we live in the UK, I was wondering if I could do something to fix it myself....with your help, of course.
Do you have any recommendations for what is wrong and how to fix it? Thanks. Tom
  • 1019 Answers
SOURCE: multi region phillips dvd player
Is this a Multi-region Player ?
Some Players are region Set to play Only the region they, are intended For. i.e Region 1 = NTSC( USA ) Region 2 = (PAL ) UK. Region 6 = ( ASIA ) And so on.
If you need a multi-region hack for your player, Post here.
I do charge a Small fee for This service.
Mike @ compurepair.
Posted on Feb 29, 2008
SOURCE: Philips mini DVD PET702/75 multi region unlock code
To check the software version and change
region code of your DVD Portable
1. Power ON the DVD player and open the DVD
door
2. Press the “SETUP” button on remote control,
then select the “Preference MENU”
3. Press the remote button in the sequence as
9 -> 6 -> 5 -> 3
4. The LCD display showed the existing region
code. Press (navigation up) or
(navigation down) repeatedly to select the
number from 0 to 6.
5. Refer below table for your region code setting
moz-screenshot.jpgmoz-screenshot-1.jpgRegion
1=USA
2=Europe
3=Asia Pacific
4=Australia, New Zealand
5=Russia, India
6=China
Select “0” setting = Region Free (confidential)
Posted on Mar 04, 2009
  • 35 Answers
SOURCE: Want to unlock Philips DVD player (DVP320)
Did you follow these instructions exactly? If you pressed 9990, as you mentioned, it will not work. You need to press 99990. Do you see region "0" on the display?
start the player without any DVD in it.
open the lid.
while the lid is open press 9,9,9,9,0
you should see region 0 displayed.
close the lid.
Your DVD player is now region free.
note:
replace 0 with 1 to 6 at to set the wanted region number if needed.
Posted on Mar 05, 2009
SOURCE: multi region code for philips hts 3090 dvd player
With your set on and without disc in the tray:
1. Press PLAY from your remote control
2. Press the following button sequence: 1590 2379 390
3. Press PLAY again
This will release the region verification in your home theater (region free). However, some DVDs (multiregion in particular) will not play, since they require region detection from the player unit.
I've done this to my 3090 and been using it like this for 3 years.
Posted on May 27, 2009
  • 50 Answers
SOURCE: My DVD player isn't multi-regional
Here's the regionfree code..
1. Open Tray
2. Press 9,9,9,9,0
3. Press open/close to close the Tray
4. Regionfree..
Jay
Posted on May 29, 2009
Philips dvp3360 doesn't work at all after upgrade
try to RESTORE to the date was working before. The driver can NOT be compatible with the model.
God bless you
Oct 12, 2012 | Philips DVP3560 DVD Player
I have lost the remote to my philips dvd 625, is there any way to navigate without it?
i have a remote for a philips dvd 625 (dvd player doesn't work anymore)
mail@aukebergsma.nl
Netherlands
Jun 16, 2011 | Philips DVD625 DVD Player
When we start our DVD player (Philips DVP 3256) its shows ENTER PASSWORD. what it will be?
Hi yogeshsghige ,
The default password could be 0000 or 12345 or something else , and it should be mentioned in your player's manual , do check the manual and find out the default password.
Hope this helps ..:)
May 27, 2011 | Philips DVD625 DVD Player
Hi what cable to I need if i want to connect a philips dvp3260 to a plasma tv that has a usb and hdmi input?
The DVD player that you have doesn't have a hdmi output. also the dvd player only has a usb input. so you should buy either a VGA cables or RCA cables depends on what you want.
this is the link for the manual of the dvd player: http://download.p4c.philips.com/files/d/dvp3260_12/dvp3260_12_dfu_eng.pdf
this is the link to the website: http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?hlt=Link_Overview&tmplt=ePlatform%20-%20Philips&scy=GB&slg=ENG&session=20110522113658_68.42.214.72&ctn=DVP3260/12
May 22, 2011 | Philips Televison & Video
I have a Philips HTS 3371 DVD home theatre and can not play many DVD's as it give wrong region error. Can you please provide the unlock code and how/where to enter it to get it fixed?
Hi -
Please follow the instructions below for unlocking your Philips HTS 3371
Please note: Unlocking a DVD player may invalidate the warranty. Unlock sequences may not work with some firmware updates and some DVD players have been damaged through failed attempts to unlock them. Unlocking your DVD player is done at your own risk.
1. Switch the DVD player ON
2. OPEN the disc tray
3. Key 9 9 9 9 0 using the Philips remote control supplied with the player
4. Press PLAY. The disc tray will close.
5. Switch the player OFF then switch ON again.
6. To test, play a disc from a region which was previously locked.
If it does not work the first time, switch the player off and back on, then try again.
This is a verified unlock method, but I was unable to confirm whether it works for players sold locked to Region 1 (North America). If you have a Region 1 player and the method above does not work, you will not be able to unlock your player.
Regards,
BElectric
Mar 26, 2011 | Philips HTS3371D Theater System
Can't run a Dual layer DVD Philips DVD player DVP3005/69
You Don't!
moz-screenshot-2.jpgmoz-screenshot-3.jpgwww.p4c.philips.com/files/d/dvp3005_69/dvp3005_69_pss_aen.pdf
click on the link above and download a PDF on the model you have, and in the 2 pages you will never see any mention of 2 Layer media.
Apr 25, 2009 | Philips Televison & Video
open the lid.
close the lid.
note:
Mar 05, 2009 | Philips DVP320 DVD Player
Disc Error when I try to play a dvd LG DP781
Sounds like either a dirty or weak laser/lens. Pls try cleaning with a CD disc cleaner or manually using cotton buds (if the eye is accessible).
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 17, 2008 | LG Televison & Video
HR 720 does not burn to DVR -R media
Hallo everybody,
this guy "mysus" is a genius! I have had above problem on a Samsung HR-725 (160 Gb Version of the HR-720) now for approx. 1 year. I´ve called the Samsung Hotline and tried other dealers - nothing worked. Today I came accross this help and tried it out immediately - and it works perfectly. However, you do need to know a little about PCBs and electronics.
I used a variety of different -R DVDs and they all seem to work now. Many thanks once again for this fantastic link.
May 01, 2008 | Samsung DVD-HR720 DVD Recorder
Philips DVDR3450H
Put the DVD back into the drive...Then open the DVD menu by selecting the first tittle on the disc....Hold down the up arrow on the remote to make the "Editing menu" appear....Then select "Finalize Disc".
These instructions can be found on page 54 of the instruction book.
Dec 29, 2007 | Philips DVDR3450H DVD Recorder/HDD...
Philips DVD763SA DVD Player Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
