Question about Western Digital Caviar WD1600 (1600YD) 160 GB Hard Drive
I have a hard drive wd1600 and the computer its in is no good so i want to install it into another computer how do i do this
    President:
  • 1,179 Answers
Make sure the other computer is compatible with the hdd. Remove the hdd from old computer. Set jumpers to what new computer requires for 2nd hdd. Put in new computer and hook up proper cables. Boot and bios should recognize new hardware. Hope this helps.
Posted on Dec 26, 2008
Can I connect a WD1600 Hard Disk via USB connector for external drive?
You need to purchase an USB hard drive adapter case and install your hard disk inside this case. Take your hard drive with you when you got to a computer shop so you will get the correct IDE or SATA USB adapter case.
Mar 26, 2013 | Computers & Internet
Windows7 wont read wd1600 caviar as a external drive ???
Did you install the western digital drive softare? There should have been a disk with the drive, which you run when you have installed the drive. It tells the computer there is a new hdd in town. If you don't have the disk, google Western Digital, find their website, and search for HDD driver software, with the model number of your drive. You should be able to download the drivers to your computer, and install them that way.
Nov 05, 2012 | Western Digital Caviar WD1600BB 160 GB...
I have an WD1600 and Windows don't want to startup. It Always restart. I've tried to repair windows with CHKDSK, but i have bad sectors that can't be repaired by CHKDSK. I can't find any...
Mohamed if the hard drive has bad sectors on it is best to replace the hard drive itself. But you need to save the files first by doing so, you have to do a parallel re install. Parallel re install is like booting your hard drive with 2 operating systems for details on how to do that click on this link.
Once you are finished try downloading and saving it on a external hard drive all the files that you saved. Purchase another hard drive and upload the files that you have saved
Jul 18, 2011 | Western Digital Caviar WD1600 (1600YD) 160...
My wd1600bb-00dwa0 hard drive I believe died as I got a MEGATREND WINDOW which stated that the hard disc was bad. It would have to be bad, right? I couldn't get anything else to come up on my monitor....
yes u can go higher with GB you just have to be sure that the rpm's match youll see on the label it will tell you either 5400.3 or 5400.6 or 7200rpm. be sure also the dimensions are the same if you have a 2.5" get a 2.5" a 3.5" won't fit
Jan 31, 2011 | Western Digital Caviar WD1600 (1600YD) 160...
I have a pc with a western digital wd1600 hard drive that will not start. I am not sure if it is the power supply or the hard drive. What is the easiest way to try to get the data off the hard drive?
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 22, 2011 | Western Digital Caviar WD1600 (1600YD) 160...
I have a WD1600. When I turn the computer on, I hear a ticking noise from the hard drive. It ticks 10 times and pauses, and again until I get a hard drive failure on my screen.
The ticking is the reading head trying to read the data. Since it fails that means that the hard disk has died. This is unfixable and all the data on it is lost. Just take it out and replace it.
Sep 01, 2010 | Western Digital Caviar WD1600 (1600YD) 160...
Jumper settings wd1600
yes, you are correct.
Feb 20, 2009 | Maxtor Hard Drive
Run wd1600 via ide-usb problems
Just replace the case the drive is in. You can get them from stores that sell computer parts like Fry's Electronics. There are many online sources too.
Feb 08, 2009 | Western Digital Caviar WD1600 (1600YD) 160...
Format harddrvies western digital wd1600
try using the dynamic drive overlay supplied with the drive? Your MB may not be able to handle it.
Aug 12, 2008 | Western Digital Caviar WD1600 (1600YD) 160...
Western Digital Caviar WD1600 (1600YD) 160 GB Hard Drive Logo
400 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
