Question about Polti Vaporetto 2400 Canister Steam Vacuum
Vaporetta polti VTT2085 1998
Mine creates steam but dose not pressurize out when flex hose is connected and switched on. Can any one assist with advise.
I am a automotive technitian and own www.winbrake.com so as there is no repairer to be found in South Africa I have to undertake the repai myself
  • 57 Answers
The solenoid isn,t operating. Either the valve is stuck or the coil is burnt out
Posted on Aug 29, 2009
Why no steam on polti 715 no steam
I had this problem, that is, my Polti 715 would not create an steam at all. It turned out that the boiler/steamer unit inside the Polti was badly corroded. So the only way to fix it was to replace the boiler/steamer unit inside. I had to send my Polti to an authorized repairer to have it fixed. The reason for the corrosion was that I did not follow the manufacturers instructions fo run the Kalstop solution through the machine every few months to stop calcification in the boiler.
May 03, 2014 | Polti AS700 Canister Steam Vacuum
Polti vaporetta comfort steam cleaner...no steam
if you put two much water in it it wont steam
Dec 26, 2012 | Vacuums
My polti vaporetto 2300 is belching with steam,have changd the safety cap seal,but hasn't helped --any ideas
My polti 2300 vaporetta is heating the water but not getting up to steam, could the problem be the safety cap?
Nov 17, 2010 | Polti Eco Pro 3000 Canister Steam Vacuum
Starting a polti vaporetto steamer
Put a couple of lts. of water in the tank, replace lid, assemble hose with tool you require. Plug in switch on, wait for needle to climb into yellow then pull trigger for steam
Jan 23, 2009 | Polti Vaporetto 2400 Canister Steam Vacuum
Polti steam cleaner
It should go just below the red providing steam isn,t escaping from the cap otherwise you won,t get the pressure build up to enable it to come out when you pull the trigger
Oct 23, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
Polti 1500 no steam just droplets of water
Before trying anything else make sure you turn up the pressure control knob in the direction of the + sign if it is turned right down you will have steam in the system and the gun will be heard to click open the flow control valve but you will not get any steam because the control screw is set too low just turn it anti-clockwise to increase the flow and your good to go .I hope this helps I have one too and I some times forget to turn up the flow and wonder why for 3 minutes then realise that during storage and manuevering it gets turned down by accident and i turn it up and all is well again.
Jun 20, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
Polti vaporetta - steam escaping from valve
Are you sure it is not escaping from the top? if so replace top.I have had this myself
May 11, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
Cant find out where i get a new gun handle mine has snapped
http://www.spares2you.co.uk/Vacuum+cleaner+spares/Polti+steam+cleaners/Vaporetto+2400/
Mar 14, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
Rubber seals for wand sections
Try eBay or you're local plumbing/bathroom store.  What you need are called o-rings.
My problem was that there's an o-ring on a spike in the hose attachment and that was split which meant it leaked water/steam.  I replaced it and it's working fine again.  I got my o-ring (in a pack of 200 assorted sizes) from eBay for about £3 but that was only because I was too lazy to go down to my local plumbing/bathroom shop which probably would have sold me 1 for a few pence.  Much better than £50 to replace the hose!
Dec 11, 2007 | Polti Vaporetto 2400 Canister Steam Vacuum
Polti Vaporetto 2400 Canister Steam Vacuum Logo
469 people viewed this question
Top Polti Vacuums Experts
Jose Pino
Billy Detlefsen
Are you a Polti Vacuum Expert? Answer questions, earn points and help others
