Question about Dishwashers
Drain Clogged I have a Kenmore Quiet Guard Plus dish washer. The water will not drain from the unti. I believe the drian in the dish washer is pluged. I removed the 8 screws from the pump/strainer unit at the bottom of the unit I removed the top that the screws were holding donw, but can't figre out how to get to the drain to unplug it. The center metal unit is exposed and nut head is exposed. What do I do next to get to the drain hose to unplug it?
    Genius:
  • 2,920 Answers
You might try pouring liquid plummer in the drain part and jet it set it shouold eat through whatever is in there
Posted on Dec 26, 2008
Kenmore Quiet Guard is clogged on the bottom. Leaking water.
take out the bottom rack, pop out the center. use a snake on the drain. if not aviable us a wirer coat hanger. the water should go down. to top it off ad some draino or something like that. but rises your dishes before you put it in the dishwasher. remember a dishwasher is not a garbage disposal. run the dishwasher again i wish nothing in it. that will flush out the drain. then your good.
Jan 02, 2013 | Dishwashers
I have a Kenmore quiet guard 3 model: 665.74364k2 and serie F55202295. It is not draining properly. It works fine and cleans the dishes but when it goes to drain it leaks in my basement ceiling and vents.
if you have an air gap vent in the kitchen sink plumbing then make sure it is clear. Also looks like the kitchen drain end is blocked. Pour some caustic soda into the sink drain, wait 10 minutes and run water into the sink.
If you are using insinkerator (garbage disposer) in sink, make sure it is run before you start the dishwasher.
Jan 10, 2011 | Kenmore 24 in. 15932 Built-in Dishwasher
My kenmorre quiet guard 2 dishwasher is not draining completely and is leaving dishes with a soapy residue.P,ease help.thank you.
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Nov 11, 2010 | Kenmore 24 in. 15932 Built-in Dishwasher
I have a Kenmore Quiet Guard and it has stopped draining. The drain line is not clogged.
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
heatman101
Aug 30, 2010 | Kenmore Dishwashers
The washer was one last rinse and stop did't drain?
Generally a bad drain pump or a clogged drain pump or drain hose. Have a look and let me know what you find.
Benjamin
Aug 09, 2009 | Whirlpool 4.0 Cu. Ft. Plus Washer
Smelly dishes from Kenmore Ultra Wash
If you post the model number of your dishwasher plus its approximate age (in years) I can help more.
But the most common cause is a weakening pump motor. On many dishwashers, the wash pump motor is also the drain motor. Replacing that motor / pump assembly will solve the problem. While you are replacing the pump, check the heating element to confirm that it is not shorted out or broken.
For now, add a cap full of bleach to the water _after_ the initial dishwasher fill cycle ends and the wash cycle begins. White vinegar would also work, but this will not fix your problem.
Good Luck!
May 04, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
I have the Kenmore Plus Quiet Guard, just wondering about filters as the water is not draining?? Anyone know?
It sounds more like a failed pump.
Does it circulate the water while washing dishes?
You might check the junction where the dishwasher connects to your drain under the sink. Often, they empty into the garbage disposal.  The inside of that junction has a tendency to clog with food (especially grease) and the pump of the dishwasher doesn't produce much pressure, it is more designed for volume.
Jan 08, 2009 | Kenmore 24 in. 17602 / 17604 / 17609...
My dish washer does not drian completly
the water must pump uphill to the air gap. the last water in the line drops down the hose, and is in quantity equally to the volume of the hose from the bottom of the pump to the top of the hose. that flows to the bottom of the sump in the unit. if enough, it appears as residual water in the bottom. its ok.
m
Oct 27, 2007 | Kenmore 24 in. 16032 Built-in Dishwasher
Dishwashers Logo
95 people viewed this question
Top Dishwashers Experts
