LG Flatron W2234S monitor seems to be in sleep mode.
The screen is black and the power button is pulsing on and off, as if the monitor is on power saver mode.
  • 5 more comments
  • dadbo Feb 20, 2009
    monitor flashes up normal brightness for a second upon being turned on then fades to the point of just barely being able to see something on the screen
  • nizl Feb 25, 2009
    Having the same problem. Screen's off, power button is flashing. Disconnecting and reconnecting all cables does not help.
    It happened when I was rebooting my computer.
  • Anonymous Feb 25, 2009
    same problem as described. moreover, when i manage to reset the monitor so that it displays something, the OSD menu doesn't show up anymore (just once or twice, if i'm lucky...)
  • Anonymous Mar 10, 2009
    Mine does the same... I have to leave it off all night and it is fine int he morning. Over heating?
  • Anonymous Mar 24, 2009
    I've noticed my Monitor goes in only what seems to be sleep mode when I tab in, tab out or start up or close a program. The little blue light in the right bottom corner flashes on...off...on a couple of times before i can see the LG Logo on my screen but as if it's in a sefe mode and then when i click anything on my keyboard it goes back to normal, and this happens everytime. Please tell me how I can fix this :)
    LG Flatron W2234S
  • filmernator Mar 08, 2010
    If I put my computer into sleep mode, the screen goes into power saving mode. No amount of mouse wiggling will get the screen to come back on when I switch on the computer. Means that I have to turn the computer on and off every time - rather annoying. Can anyone help!
  • Randall  Trahan
    Randall Trahan May 11, 2010
    Start with the easy things first. Turn off your monitor and your computer. Unplug your monitor from the back of your computer port and then put it back into the port. Start up your computer and then your monitor and see if that resets it.
    Genius:
  • 2,120 Answers
The backlight fluorescent bulb is burned out
Posted on Dec 26, 2008
LG monitor if back light floresent tube is burnt out is it replacable.
Posted on Feb 17, 2010
If you just installed a graphics card, make sure you use the adapter it came with
Posted on Jan 28, 2009
I can not turn off the sleep mode on my LG Flatron monitor W2361VG-PF
This monitor has a manufacturer's defect in two of the wiring harnesses: the harness going from the controller board to the power button (4 grey, 1 blue wire) and from the power button to the side controls (3 grey, 1 blue wire). Open the monitor (snaps apart, no screws) and gently tug on each wire individually. One of them is causing the problem. You can replace the harnesses, try to fix them, or solder new wires directly to the pins.
Feb 16, 2013 | LG FLATRON W2361V 23 inch LCD Monitor
Lg w2234s-bn Monitor Cycling randomly through Light View Modes/Power Button turning It's self on and off.
On and off cycleing could be caused by a bad power supply or a low battery on your remote. Check them both out. Good luck.
Apr 28, 2012 | LG 22" FLATRON LCD Monitor
My LG FLATRON W2234S monitor won't turn on. When I press the on/off button it lights blue for like 5 seconds and then it goes black again. Plugging the main power cabel in and out won't work. All help...
Try changing the Resolution for the lowest one, if it works it will see the letters and everything very big. I have same trouble, specially since I change the original Vista Starter for the new Windows 7, I have not found a free controler that helps me and I have seen many people with same the problem. Sorry for my english.
Oct 10, 2010 | LG Flatron W2243SPF Widescreen LCD Monitor
Lg w2234s no signal?
shut down the computer completely by pressing on the power button until no sound is heard. Then make sure that the screen is properly connected to the computer and turn on the computer. If this doesn't help, disconnect the cable that connects the screen with the computer, see that the connection looks fine (no broken pins) and then connect again to the computer.
Oct 04, 2010 | LG Flatron L1715S 17" LCD Monitor
Hello, I have a LG flatron w2234s and a week ago the screen started to shut down on its own while i'm using the computer or when it goes to sleep mode. The screen gives me the LG sign and just turns off...
First try it on another Pc, you'll know the root of the problem. If there's no problem on another pc then the problem would be with your video card/motherboard. If the problem is still the same on another Pc, then your monitor has internal problem. You better call up a technician, he/she will check it for you, must be Pcb problem. Good luck. Thanks for using FixYa.
Jun 04, 2010 | Computers & Internet
LG Flatron W2234S Monitor Monitor goes black
Ahh the same thing has happened to my monitor! Mine unfortunately is 1 month over warranty. Apparently this is a common problem with this model!
Oct 29, 2009 | Gateway FPD 1730 17" Flat Panel LCD...
Lg 22' monitor was widescreen now has black bars!! Cant remove ?
the grpahics from wowc burnd the sides of your monitor. your pretty much screwed if you keep playing that game
Aug 16, 2009 | LG Flatron L1710S 17" LCD Monitor
No picture lg flatron w2234s blinking blue light
Hi My screen developed exactly the same problem. It appears to be a hardwear problem associated with the screen it's self. continuity test is ok on the lead so I took it back to the shop under warranty and hey presto, the replacement works. I don't know what the problem is but there are a number of other folks on another thread with the same problem and their entries are dated May 09 too.  Dave
May 26, 2009 | LG Flatron L1750S 17" LCD Monitor
LG Flatron - Power button flashing blue
i get a similar thing, i accidently entered sleep mode then turned off my computer at the power button on the back, now i turn on my monitor( i dont get blue flasjhing but it jsut goes on and it doesnt register, then says going into power saving mode and the colour on the button turns yellow its very frustrating :(
Apr 20, 2009 | Computers & Internet
Computers & Internet Logo
3,481 people viewed this question
David Payne
David Payne
