Question about Sony Playstation 3 (PS3) Console
Horizontal lines on my new tv when i use ps3
Hi ive just bought a lg 50 inch plasma 1080p and 100hz
when i watch the hd channel it is perfect but when i use the ps3 it has thin lines down the screen they are more distortions than solid lines but annoying all the same
my ps3 is connected by component cable
any advive would be great
    Sergeant:
  • 204 Answers
1 of 3 things, 1.) the easiest would be to try a HDMI cable 2.) Your PS3 video may be going out (try it on a diff TV) 3.) your Video inputs on your tv may be going out. Good luck to you!
Posted on Dec 28, 2017
5 Suggested Answers
  • 36 Answers
SOURCE: HDMI causes red lines (static?) on screen
Try to borrow a HDMI cable from someone else, or try yor setup on another HDTV, and sdee if the results are the same, then at least you can narrow down the problem to the TV or the cable.
Posted on Dec 29, 2007
SOURCE: Playstation 3 Flickers when set to 1080P
I did some further research. I updated my firmware for TV(samsung) to the latest. This did not resolve the problem. Then I changed the hdmi ports. what I found is that the problem(ofcourse only with 1080p) is seen in the first 3 hdmi ports on tv, BUT NOT at HDMI 4 port. That may be our TEMPORARY SOLUTION. but not a final solution.
In samsung LNxxA650 series, HDMI 4 is at the side, not in the same zone as other 3 in the back. so, it's hardware implement may be little different.
So, does it mean it's been all TV's fault? no, not necessarily. The ports 1,2,3 are working good with blue-ray disk videos with 1080p. How is that possible? So, well, for one, I think PS3 itself could use different ways (integrated chip vs embedded firmware OS ) for launching xmb vs running blue-ray videos. If it is a handshake issue, then PS3 has to resolve; I will also call samsung and launch an investigation. For them, All ports should behave the same. period.
Suggestion: As for other TV brands, try with other ports and check. Otherwise, update firmware/call TV technician. please launch complaints at TV so, that they realize that they need work together to with SONY folks to get this resolved.
Posted on Jan 11, 2009
  • 18 Answers
SOURCE: line going up and down TV when i play ps3?
  1. Turn off your PS3
  2. Hold down the power button for at least 5 seconds
This reset the video settings to default settings.
Posted on Jun 03, 2009
  • 12 Answers
SOURCE: Is it ok to play ps3 on plasma tv. I just bought a
I have 2 50" plasma tvs. One is a Samsung and the other is a LG. I play my PS3 on both and have not had any problems whatsoever. You can also look through the manual and it should also give you some facts about hooking up a console system to it. You should also have different settings for the TV such as standard, sports, game mode, etc... So you can set the tv up on however you wanted to view it. Have fun gaming!
Posted on Dec 03, 2010
Vertical green line
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ...
I Have An Lg Plasma It Has A Green Line Down The Center What ...
www.diyforums.net/i-have-an-lg-plasma-it-has-a-green-line-down-the-ce...
i have an lg plasma it has a green line down the center what. .... Essentially I just disconnected the flat cable around where the vertical line was, sprayed it with a ...
LG 50PK550 Plasma Single Thin Green Vertical Line - Fixya
www.fixya.com/.../t12061168-lg_50pk550_plasma_single_thin_green
Mar 10, 2008 - Posted on Mar 17, 2012.
Jan 16, 2016 | LG Televison & Video
TV link not working with my LG 50PH660V 50-inch Widescreen 1080p Full HD 3D Smart Plasma TV with Freeview HD/600Hz. I connected coax cable to my Sky Box, switching on the RF on, but I can not get it w
Hi Jim, your nearly there, all you need to do is go into the tv menu and move from DTV to the old type channel numbers and then find the bit where you can manually tune the tv to channel 68.
Have a sky menu picture running and you will see it come in.
Feb 03, 2015 | LG Televison & Video
Is it ok to play ps3 on plasma tv. I just bought a 50 inch lg plasma and don't want to mess it up. Its a 1080p 600hz
Dec 03, 2010 | Sony Playstation 3 (PS3) Console
I have set my LG 47LH4000 to trumotion 100hz but when you press the ok button when watching it says 1080i 50hz should be 1080p
All TV signals, including SKY, are transmitted at 1080i and 50hz. The only sources for 1080p are Blu Ray, XBox or PS3
Mar 09, 2010 | LG 47LH40 47 in. LCD HDTV
Watching a football game picture is very unclear
The noise reduction option will cause a blur on fast movement. Also, you probably already know this, but a standard definition broadcast will look very blurry on an HD TV, so make sure the channel you're watching is actually an HD channel.
Oh, wow, I just noticed that this is from October. Oh well, maybe you're still having problems.
Oct 18, 2009 | LG 50PS60 50 in. Plasma HDTV
I just bought a 50" LG tv plasma and its supposed to be a 720....
Well it depends on what your watching on the tv. If you hook up an HDMI cable with a dvd player or other accessory, such as HD cable box on an HD channel it will swap to 720p.
Aug 04, 2009 | LG 42PC1DV 42 in. EDTV-Ready Plasma...
42 inch LG Plasma TV - Lost picture
If you paid by cheque or credit card, that is your proof of purchase.
Mar 09, 2017 | LG 50PG6000 50 in. HD-Ready Plasma TV
Horizontal Lines when Viewing HD TV
Would you please change the picture mode 4:3 or scan fit to 16:9?
Nov 19, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
HD4208TIII-PDP 42'' Plasma TV
Your TV may not support your HD channel signal. Check with HD DVD & non-HD DVD players to confirm.
Jan 01, 2008 | SVA-USA HD4208TIII-PDP 42 in. EDTV-Ready...
sounds like it may be a software upgrade
Oct 16, 2007 | LG 50PX4DR 50 in. Plasma TV
Sony Playstation 3 (PS3) Console Logo
50 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
