Acer 4620z Hi on my daughters acer 4620z the center pin on the laptop ac connection is broken and moves is ther any way to repair without rteplacing the motherboard? Can I get a external battery charger? thanks...dave
  • Anonymous Mar 07, 2009
    I have gateway mx6956, the ac jack had started messing up last year. I took it to repair shop and they soldered it, and said if this happens again that nothing can be done and that the computer is worthless. So during this year, i have had the laptop on a table, never leaning on anything, then tonight, it decided to do the same thing again. Is there a charger for the battery that is external that I could buy, in addition to purchasing another battery, then just switch them out?
    Dedicated:
    Visited the website for 20 consecutive days.
  • 90 Answers
Hi sir,
You can get the power pin unit replace on any authorized ACER center.
Also, you can have the external Battery charger as well, just browse through your local ecommerce laptop parts sites.
Hope this helps.
Thanks.
Posted on Mar 18, 2009
Clicking cd player
http://www.laptopinventory.com/LaptopInventory.php/Acer/Extensa/4620Z/CD%20RW
If the drive is clicking, it is probably broken inside and should be replaced. The link above will show you how to do this and should also have links to replacement parts for your computer
Aug 04, 2013 | Acer Extensa Computers & Internet
I have an Acer Aspire One and when I plug the charger in I have to spin it or wiggle it or both to get the battery to charge. Once I have it in position it generally stays on charge, but if the cable is...
It could be either one Sarah.
The AC adapter's (Charger) cable, or the DC Power Jack where the AC adapter plugs into the laptop.
This is an example of the DC Power Jack not installed,
http://www.laptopjacks.com/view_part/Acer-Aspire-ONE-AOA150-ZG5-DC-Power-Jack-AC351816.html
(You can click on the three views of the jack to enlarge)
1) Check the DC Power Jack to see if it's in good repair.
Battery removed use a small flat tipped screwdriver, and Gently see if you can move the Center Pin around in the jack.
See if the Center Pin will move side to side a small amount. There is supposed to be No perceptible movement.
Referring back to the closeup photos of the DC Power Jack, the flat blade-like prongs are upside down, in relation to how the jack sits on the motherboard.
The flat prongs go down through the motherboard, and are soldered to the motherboard.
If the center pin of the jack is stationary, but the jack as a unit moves around, one or more solder joints, (Connections) for the flat prongs may be cracked.
The repair consists of completely disassembling the laptop, removing the broken DC Power Jack, and installing a new one.
Acer Aspire One service manual,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-acer
(Click on the blue - One - in Aspire One.
This is a PDF file. The computer you are using now has Adobe Reader on it which uses PDF files.
After you click on the file name (One) it may take up to 30 seconds before you see the first page.
It may also take additional time for the file to fully download.
(Took 12 seconds just now for full download)
No perceptible movement of the DC Power Jack? Suspect the cable of the AC adapter right near it's plug. (Plug that plugs into the DC Power Jack)
For additional questions please post in a Comment.
Regards,
joecoolvette
Jun 25, 2011 | Computers & Internet
Password bios of extensa 4620z
You should be able to remove the password from the CMOS setting.
Just select F1 at boot up and locate the password section once you are in the CMOS Setting then clear it .
Regards
Feb 25, 2010 | Acer Extensa 4620-4648 Notebook
My pin on my laptop is lose how can i fix it and my laptop dont turn on
Do you mean the pin where the charger (AC adapter) connects to? If so, this is often difficult to fix. This is possibly why the laptop won't turn on. Can't connect the charger since the connector pin is broken, so no way to charge the battery. This can sometimes be repaired by disassembling the laptop and soldering the connector back into place. If the connector itself is broken then some sort of hack job solution using generic parts canimplemented but the end result will not be very pretty. The bill for such repair jobs usually starts at around $100 & goes up in price.
Feb 19, 2010 | Acer Aspire One Netbook 8.9" Notebook
Acer extensa 4620z ... enable wifi card permanantly
The switch simply turns the radio on and off, if it can stay in the on position just leave it in the on position. It should stay enabled if the radio is "on". There really is no reason to keep rurning the radio on and off. If you need to disable it, then just go to the device manager and disable it there. The switch is a pain to replace, first you have to find the right one, then the soldering of the switch is another battlle all to itself.
Oct 08, 2009 | Acer Extensa 4620 Notebook
Blinking yellow light on Acer Aspire
You can find the broken piece on line to purchase,This can be repalced by soldering it to the motherboard.You will need to find someone to replace this probably a tv repair technician who is good at soldering small circiut boards.You can also purchase the motherboard and replace it
Good luck
Sep 28, 2009 | Acer Aspire 5500 5570-2609 Laptop
Loooking for an a/c adapater for an acer extensa 4620z
Try here:http://cgi.ebay.com/NW-AC-Adapter-for-Acer-Extensa-4620Z-5620-6846-Notebook_W0QQitemZ390019100656QQcmdZViewItem,
http://www.notebooksupplies.com/acer/extensa4620ac.html
Jan 16, 2009 | Acer Aspire 5610-4648 Notebook
Acer 3680 ac pin broken
That's really not advisable. At our shop we do socket repairs, I suggest finding someone local who specialises in laptops and asking them to replace it. You can get the sockets on e-bay, etc, if you wish to try it at home, though I don't advise it.
Don't forget to take static safety precautions!
Aug 19, 2008 | Acer Aspire 3680 Laptop
Computers & Internet Logo
46 people viewed this question
Alun Cox
David Payne
David Payne
