Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
GE Profile refrig side by side Model GSS 20iEMCC, not cooling
GE Profile refrigerator side by side Model GSS 20iEMCC , 7 yrs. old. Not cooling.
No abnormal noises, nothing visually (frost, coil ice, dirt in back, etc) jumping out at me. I did the unplug reset... didn't work.
Refrigerator side is not cool at all, freezer makes no ice, but will cool a bottle of water a little. It will not freeze. Temp dials are turned up. Water dispenser works.
I had to empty out all food.
Thanks.
SAL
  • GE Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
df
Posted on Sep 29, 2010
Profile GE PS123Sc about 6-7 yrs old. Freezer side seems fine. Fridge side is too warm, but is cooling (about 40F). Fridge side lights are intermittent and control panel at top is intermittently dark or...
Sounds like a bad motherboard and probley need control board. You can put in self dianoss. Press all the buttons on panel for 5 seconds. This will start the program. It will check all sensors. Come back with codes and I will help you. Wait to hear from you. I hopes this helps. david_gra582
Aug 27, 2011 | GE Profile PSS26NGS Side by Side...
My ge side by side profile tps24 is not cooling on the refrig side and the body of the refrig is hot. Any ideas?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 02, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE Refrig model GSS 201emd cc - The freezer works fine, but the refrig does not, the lower area is cool however the top area is Hot and no air is coming out the top circulator fan. Can you tell...
It sounds like the cirulating fan between the freezer and the fridge is not operating. I have been successful in lubricating the bearings. It may need replacing. Available online
Mar 01, 2018 | GE (PSS26MSRSS) Side by Side Refrigerator
Items in refrig are freezing when they're not supposed to.
thermostat has failed i'd say..its not turning off at the requested temp.
Jul 24, 2010 | GE Profile PGSS5PJXSS Stainless Steel...
Side by Side GE Refrig/Freezer is blowing hot air out of the bottom - is this normal?
If your refrig is 10 yrs old or les , then yes , this is normal . It pulls air in from the back over the condensor coils then compressor and out thru the front . The refrig should be 3-4 inches from the wall so it can pull fresh air thru . If any closer , the hotter the air will be causing the coils and compressor to be hotter than designed for therefore causing less life for the refrig . The WARM air is good meaning the refrig is cooling properly .
Jul 18, 2010 | GE Refrigerators
GE Profile Refrig model PSC23SGRC ice maker stopped making ice. Water is ok, just stopped? Is this common? Its only 4 yrs old
Your model has an electronic ice maker part number Click Here=> WR30X10093 When the electronic ice maker fails you usually need to replace the complete ice maker. You can test the ice maker by filling the tray with tap water. If the water freezes aand then drops the ice then the water control on the back of your refrigerator is the reason. The water control valve is Click Here=> WR57X10032 Either way let me know your results, Thank You, Sea Breeze
Jan 20, 2010 | GE Profile PSW26P Stainless Steel Side by...
G E side by side refrigerator is not working properly....
Could be the start relay device on the compressor. Does it try to start every minute or so?
Sep 10, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerator not cooling
If it has a filter on the bottom, make sure that is clean.
Dec 21, 2017 | GE Profile 26.6 cu. ft. Side-by-Side...
GE refrigerator not cooling
on most refrigeration, the refrigerant goes to the freezer first and the tail end to the fridge. it is probable that the compressor is failing. compressors are quite hotg when running but not too hot to touch. if the compressor is too hot that also indicates failure. doubt it is worth repair
May 19, 2007 | GE GSS25JEMWW Side by Side
Refrigerators Logo
872 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
