Question about Frigidaire ATF6000ES Front Load Washer
My Fridgiaire stack washer shuts off during the spin cycle and water remains in the basin.  I have taken all clothes out, given it rest, felt inside basin for an clogs, checked to make sure drainage house is not blocked or kinked.  When I attemtp to restart the cycle it starts up for 5-6 mnutes and then just shuts off again. help!
  • 640 Answers
The door is not closed ..try putting pressure on the door latch assm,,if bad replace,,
Posted on Dec 27, 2008
Clothes are wet after spin cycle
U need a technician for that... there is a problem with the "flow valve" sorry can't help u out much with that... but maybe u can visit this site and hit the like button... www.facebook.com/muktidayasewa
Jan 13, 2014 | Amana 3.2 cu. ft. Top-Load Washer
Water does not turn off during spin cycle
Hi Robert!
If a washer unit is not advancing correctly to the next setting or cycle you could have a few issues. The main control board is not communicating correctly to the rest of the unit; the fill sensor and water valve sensor(s) are not operating properly; or the unit is not sensing enough water has been added to the unit. I would strongly suggest to contact a service professional to test all areas of the unit before repairing any further.
Mar 28, 2013 | Frigidaire FEX831CS Top Load Stacked...
My neptune won't spin during the spin cycle Water left in the basin clothes are soaked
could be a bad pump or something in the pump like a missing sock it wont spin unless the water is pumped out
Nov 18, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have a Whirlpool Ultimate Care II, top loading washer. Upon intial start up the machine agitates. During the spin cycle, the cold water remains ON, throughout the cycle. This is leaving the clothes wet...
The timer is at fault.
During the spin cycle the timer should send intermittent power to the water valve. This activates cold to help rinse soap residue from the laundry.
If cold is continuous it means the timer is not breaking correctly.
Feb 14, 2010 | Whirlpool Washing Machines
Not enough water to wet all the clothes.
Either the water level switch has bad calibration or the water level tube has lost its air seal and needs to be refitted and air locked. If you do not know how to go about these tasks, call someone with experience. Goodluck, Macgivor
Jan 16, 2010 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Washer sounds like off balance during spin
old duets have nut on rear pulley that becomes loose. remove rear panel and tighten nut. check while spinning by hand if pop is felt. if it rotates smoothly then you may need new shocks on tub
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water fills the washer during spin cycle
defective timer...a model # should be under the lid...or open dryer door and on front dryer panel right hand corner..onthejob
Jan 16, 2009 | Whirlpool LTE5243D Top Load Stacked...
Cold water pours in during final spin
No - the timer is the likely suspect.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 15, 2009 | Kenmore 98702 Stacked Washer/Dryer
There is something clogging your pump, dismantle it to clear it. Plug off the wall socket mains first.
Jan 15, 2009 | GE WDSR2080D Top Load Washer
Drum doesn't move or spin
kenmore tumble action washer model#417.44152400,
Washer is approximately 3 years old. Will not drain or spin. When it tries to spin, clicking noise heard inside of unit. Would a clog insie the lines disable the spin cycle ?
Oct 18, 2008 | Kenmore 43142 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
80 people viewed this question
Top Frigidaire Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Jason Harris
Jason Harris
Sal De
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
