Question about GE 36 in.JGP970 Gas Cooktop
Poor gas flow to GE cooktop
Installing GE gas cooktop JGP970. Due to dimension for downdraft system and location of gas inlet on cooktop, I have to use a 90 degree elbow between the cooktop and the pressure regulator. Instruction manual says to connect the regulator directly to the cooktop, but seems to imply by a diagram that the installation I used may be OK if installed above a built in oven. Problem: I am hardly getting any gas to the cooktop, only the largest unit will ignite and has a very small flame. From the stub I have used a 24 inch 5/8 OD flexible gas line with 1/2 inch connectors. The inlet on the cooktop is a 3/8. Any suggestions?
  • Mike Dec 26, 2008
    Oops had a mistake in e-mail address. Updated via profile
  • marlin siecinski Apr 27, 2017
    depending on which gas it is connect to, may be a bad regulator, your gas line is sufficient. if on LP have gas co. check your tank reg. if natural gas have them check water column pressure
  • GE Master
  • 3,248 Answers
Try a bigger inlet pipe sounds like pipe too small for load .
Posted on Apr 25, 2017
3 Suggested Answers
geemarie
  • 876 Answers
SOURCE: GE 36" Monogram Gas Cooktop - low flame
I would have someone come out. Perhaps a gas plumber first. Gas is not something you want to fool around with yourself.
Posted on Aug 01, 2008
textonor
  • 130 Answers
SOURCE: Ge Monogram Gas Cooktop - won't boil water - burners seem like they are starved for gas
Bret, lets give this a try. 1st look at the regulator. There is an arrow on it that has to point towards the cooktop. Put is on backwards and very little gas flow. I always advise this first as I have seen people tell me it is correct and when I got out there it was reversed. 2nd was this used as a live demo unit on Propane? If you are on natural gas, this will also happen. The 3rd thing I also check for in something in the gas line on the cooktop side. I had a unit that got some packing in the line and at 5 wc for natural gas, it doesn't take much to restrict. Hope this helps.
Posted on Aug 09, 2008
Need new electric cooktop to work with downdraft CV2236N-01.
never heard of one needing downdraft usually updraft . gas maybe but not electric
Apr 12, 2014 | Maytag MGC5430 Gas Cooktop
Downdraft fan switch
please go to web page and fix it:
http://www.ehow.com/how_8733070_troubleshoot-ge-gas-downdraft-cooktop.html
God bless you
Jul 14, 2012 | Cooktops
Can a GE profile black 4 burner with down draft gas cook top be converted to propane gas? How?
Hi and welcome to FixYa, I am Kelly
Everything I am reading says this unit comes with an LPG conversion Kit. It may have been removed by the detailer / retailer that you purchased it from (when ever that was.)
The 0.0354 orfices are supposed to be in the front of the inside of the cooktop and are labeled LP.
It is a matter of removing the 4 Natural Gas orifices and installing the LP orfices and then adjusting the air-flow of the grill burner Air Shutters as shown in the manual on page 32.
The center nut has to be removed from the top of the internal gas regulator and the mini post / plunger inverted and then the nut is reinstalled.
Just note that any conversions are supposed to performed by a qualified gas technician as stated by the WARNING in the manual on page 30.
The manual is here:
http://www.hammerwall.com/tempmanuals/L0603449.pdf
The step by step instructions are in the product user guide on page 30
or you can go to this link and click on info and guides:
http://www.ajmadison.com/cgi-bin/ajmadison/JGP990.html
then download the use and care guide.
Thanks for choosing FixYa,
Kelly
Jul 22, 2011 | GE Profile Nonstick Griddle for Downdraft...
My GE downdraft cooktop model JGP656 will not come up, so what could be the probelm.
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
May 06, 2010 | GE 36 in. JGP656 Gas Cooktop
Downdraft fan nor igniters work Electric tested and ok - what else could it be?
heatman101
Apr 11, 2010 | GE 30 in. Profile JGP989 Gas Cooktop
The flame is too high on my GE Profile gas cooktop
I had the same issue on my jgp975 and sadly I had to purchase a different unit. I use simmer frequently and I made the assumption that low was simmer. Wrong. I believe a true simmer is 450 btu and my unit did not go that low. I had to check the fine print/specs page and on some units the manufacturer had to be called. I did replace with another ge profile that did have the low setting.
Apr 06, 2010 | GE 36 in.JGP970 Gas Cooktop
I want to replace my Jenn-Air cooktop model 89890. What is the easiest replacement cooktop?
Greetings!
I tried to look up your cooktop and only found it mentioned in several places, and thus did not get a complete description of your unit. What I got leads me to believe that yours is a downdraft model. Whether or not this is correct, you'll need to measure the underside (cutout) measurements of the cooktop and the physical dimensions of your unit within the cutout. Armed with this information, you should be able to make an informed decision. I recently replaced a Jenn-air (downdraft, with switchable cooking modules) and selected a GE profile modle JP 989SK1SS (stainless steel). We also considered Frigidare, Jenn-air and some of the higher enders as well. Our preference boiled down to features, keeping all of the appliances (mostly) in the same brand, and reliability. Ours swapped out very close deminsionally, and the installation was easy and neat. Decide on a brand. Most dealers have a brochure that list all of the critical dimensions of their appliances, and you should be able to decide what's best for you.
Hope this was of some small help. Regards, and good hunting!
--W/D--
Jul 17, 2009 | Cooktops
Hello posted this question but family getting antsy without a cooktop. I am installing a 36 inch GE Profile gas cooktop, jgp970, along with a Frigidaire downdraft vent, pl36DD. The gas inlet pipe on the...
the reason for the fitting instruction for the regulator to be connected directly is that flex hoses deteriorate and allow a dangerous situation
AS gas is not in the diy domain I recommend that you get in an accredited gas fitter who will make a solid pipe to allow the fitment of the regulator away from the motor
While he is there he can adjust the regulator to get it all working correctly
Mar 13, 2017 | GE 36 in.JGP970 Gas Cooktop
Order in black w/matte finish grates & downdraft cover
No. If it is really important order the grates and downdraft cover as replacement parts. This will be expensive probably around $200 - $300.
May 25, 2008 | GE 30 in. Profile JGP989 Gas Cooktop
GE 36 in.JGP970 Gas Cooktop Logo
296 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Dave Harrison
Are you a GE Cooktop Expert? Answer questions, earn points and help others
