I somehow deleted channels off my Mitsubishi CS 2611R tv with the remote and don't know how to add them back on
    Problem Solver:
  • 12 Answers
Call your tv network and ask them to help you
Posted on Dec 26, 2008
Add channel to TV that I deleted (using rabbit ears w/ newish digital TV)
Confirm with another set if signal for that channel is still there or not--also if not too large a set take it to someone who gets the channel and add that channel back into the memory with the remote.
Oct 30, 2012 | Samsung LN19A330J LCD TV
How to add channels
Try doing the auto scan first to get all the possible channels.. Usually the Add/Delete function applies once the TV knows what channels are out there to add or delete.
Jan 23, 2018 | Emerson EWC1303 13 in. TV/VCR Combo
What buttons do i press to add/delete channels on emerson tv model# EWC1304? I cannot seem to get pass channel 2. I have no remote.
I have the same problem, my tv will not allow me to change channels but will only let me add/delete the channel the tv is currently on
Oct 11, 2011 | Emerson EWC1304 13 in. TV/VCR Combo
Several channels have lost sound entirely on our Mitsubishi CS-32509 television. On other channels things are in Spanish at times while in English at other times. Then there are other channels that have no...
You've managed to turn on "SAP" (second audio mode) which will cause the trouble. It doesn't affect all channels, as you're finding out, and can be frustrating. Mitsubishi remotes have a singe button for SAP, if I remember correctly, and you can press it and change modes without knowing it. (The button may be marked AUDIO or SAP.) Just press the button until the on-screen display tells you SAP is off. This will bring the sound back to normal.
This ranks up there with the mysterious black box that appears on some channels. This is because of closed-captioning being set to TEXT, and it happens the same way: pressing a button on the remote.
Jun 29, 2011 | Mitsubishi CS-32509 TV
Mitsubishi cs-26201 with "speaker off" - how to turn back on?
After a pulled plug got me Speaker off I was frustrated for weeks and found no solution online until I looked at a site offering original remotes and realizes I was using a VCR's remote for the TV. The Manual was long ago destroyed and is not available online that I can find, but I dug around for the oriignal remote and clicking the Audio button repeatedly brought up the Speaker: Off option and then it was just a press of Adjust to turn it back to On - problem solved.
I don't know if there is a way to do it without the remote, but the only controls on the TV are those on the front and in addition to steps people online suggested I think I must have tried every combination possible of pressing those in sequence or together as well as everything I could think of on the other Mitsubishi remote and the Universal remote I had been using.
Sep 04, 2010 | Mitsubishi CS-26201 TV
Mtisubishi TV (CRT), Model CS-2610R
that is because you do not have the correct input connected or the set needs to have a channel program redone
May 16, 2010 | Televison & Video
Ilo tv shows no tv signal, I believe that the channels are deleted but don't know how to add the channels back
Here is how to try and get them back if they are available.
On the original TV remote do the following-
1. Press the MENU button
2. Use the channel down button to select channel set
3. Select channel add/delete
4. Press volume up
5. Select channel you want to add by using the channel up/down buttons on remote.
6. When you get to the channel you want use the Volume up button and the color of the channel number should become either blue or green if it is added and it will be red if it is deleted.
7. Repeat until you have added all the channels you feel you are missing.
8. Press MENU button to exit.
If the channels are still available this should get them to return. If not contact you cable provider to see if they have moved some of their channels recently or check their web site for the current channel line up.
Good Luck and please rate this solution....
Jan 08, 2010 | iLO IWT3206 TV
Can't tune TV to channel 3 inorder to recieve digital tv
go into the menu & add that channel back on
somehow you deleted it
go to menu channel add/delete
Jan 19, 2009 | Emerson EWF2004 20" TV
Mitsubishi CS-31505 TV - UN-memorize QV (Quick View) Channel?
I've learned from a Mitsu tech that there is indeed NO easy (nor logical & user-friendly) way to UN-memorize a QV channel.
However there IS a work-around to accomplish that so that the QV will revert back to its Factory Setting of "Last Channel Recall."
Using the Mitsu remote control:
1. Poke the Menu button.
2. On the Menu, select the "Add/Delete Channels."
3. Select the Antenna (A or B or whichever) and select the channel which was memorized in QV.
4. When that memorized channel number appears, select "Delete."
5. Poke the Menu button again to exit.
The QV memorized channel number is now gone, restoring the QV function to "Last Channel Recall."
NOTE: If that particular deleted memorized channel was also included among the SQV (Super Quick View) channels, it can then be added back into SQV using the Menu and SQV option.
Hope the above helps those who have encountered the same issue.
DWL
Jan 17, 2009 | Mitsubishi CS-31505* TV
Sylvania TV stuck in Game mode remote no longer works
go up to your TV and go into the menu. Go to the channel selection and run the auto select for channels. This will take some time but the TV will end off the first channel found, the only thing is you cannot get back into video mode without the remote
Mar 26, 2008 | Sylvania 6413TC 13" TV
Televison & Video Logo
70 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
