Question about Hampton Bay 52 In. 5-Blade Fan, Aged Wood/Gold, French Scavo
Fan running & stops then goes the opposite direction
This fan was in the house when we purchased it. It is a Hampton Bay fan with a remote and a wall switch to activate it. The unit frequently stops going in the direction it is set for and starts going in the opposite direction. The remote will only operate the light function ( On, Off, Dim) and also the direction of the motor but will not operate the on or off of the fan.
    Top Expert:
  • Hampton Bay Master
  • 41,830 Answers
Your Hampton Bay combo probably was installed incorrectly. A frequent cause of erratic operation is a conflict between the remote control and the wall switch.
Posted on Sep 09, 2017
bigg t
  • 640 Answers
SOURCE: Hampton Bay Ceiling Fan At Slow Speed
is the fan single phase or three phase?in other words does the fan connect to 2 or 3 wires?if it connects to 3 wires just change 1 wire to another.
Posted on Aug 12, 2007
SOURCE: Hampton Bay Ceiling Fan - Clarington 503837 52"
It slides in above right above the ball, in the mounting bracket where the canopy is. You may have to kind of encourage it to go in there, and you will need to push wiring off to the sides and out of the way to help it have clearance to get in there.
Posted on Apr 15, 2008
I recently replaced my hampton bay fan for the same reason (slow at all speeds) and discovered scorched and melted capacitors and wiring inside the fan. My suggestion is to stop using fan and replace immediately.
Posted on May 11, 2008
  • 157 Answers
SOURCE: hampton bay fan, wall mount remote control
Hello burrow31. There maybe a switch located on the fan stating 'remote/manual'. Check your manual. Remove the battiers in your remote and short out the battery contact terminals. Reinstall the battiers, start the fan and after fan has reached set speed press & hold fan speed button for one second. Still no speed change contact the Mgfr. with model & serial #.
Posted on Oct 13, 2008
SOURCE: Hampton Bay ceiling fan, Remote does not turn light off
if you have the remote controll for both the fan and light you can have the controll on both the fan and light...
other wise it can't
Posted on Dec 08, 2008
Ceiling fan light delay
How do you change the speeds? Pull chain ,dual control on wall or remote.
Sep 15, 2013 | Hampton Bay Dryers
Missing remotes for hampton bay ceiling fans
https://www.google.com/search?q=remotes+for+hampton+bay+ceiling+fans&rlz=1C1PQHB_enUS689US689&espv=2&biw=1536&bih=748&source=univ&tbm=shop&tbo=u&sa=X&ved=0ahUKEwik3qiMx4bTAhXh5oMKHV3vDJ4QsxgIGg
Apr 02, 2017 | Hampton Bay 52 In. White Redington...
Hampton bay fan model 761 567 running faster on
Your issue is most likely a faulty speed control. The part is integral to the remote receiver in the fan housing. You can purchase spare parts for this fan through Home Depot (Hampton Bay) Service at 800-654-0688.
The receiver is located in the upper portion of the housing for the fan motor. Look for a semi-circular black control box (usually manufactured by Rhine)
Jun 05, 2010 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
I HAVE A HAMPTON BAY MODEL AC-418 CEILING FAN. IT
The fan unit itself is manufactured by AirCool 800-896-4908
May 10, 2010 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
My ceiling fan does not work.It is a Hampton Bay. There is power.
Hampton Bay receivers are notorious for taking a dump, replace the remote. If you're just adding the remote... There will be 6 wires on the remote, a set of two (white and black) a set of three (white black red or blue) and a single small wire by itself. The single wire by itself is the Antenna wire, do not wire it to anything, or it will fry the board in the receiver.
Mar 31, 2010 | Hampton Bay 52 In.Carriage House II in...
Unable to get fan to respond to remote Hampton Bay 54
these fans must be reset as follows remove the battery from the remote manually turn off the wall power switch put the batteries back in the remote turn on the wall power switch press the remote buttons...if this doesn't work let me know
Jun 01, 2009 | Universal Remote Control Hampton Bay...
Unable to get fan to respond to remote Hampton Bay 54".
There is most likely a wall switch which you will need to ppush to the on position to send power to the fan, then the remote will do as it is supposed to do. If you find that it is not the wall switch, then I would check the electrical panel for a circuit breaker that has kicked partway off or blown fuse.
Apr 26, 2009 | Universal Remote Control Hampton Bay...
Hampton bay Mod. # 587-186
The dip switch is on the receiver box which is located inside the housing on the ceiling, inside the remote control, and inside the wall switch if you have a wall switch made to control the fan.  All must have the same dip switch settings.
Dec 23, 2007 | Hampton Bay 24750 Huntington III Ceiling...
Hampton Bay 52 In. 5-Blade Fan, Aged Wood/Gold, French Scavo Logo
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
