Question about Hitachi UltraVision CineForm 55VG825 55" HDTV
How do I remove the front panel?
This is going to sound crazy, but a little spider has decided to make it's home in my TV. The little thing has created a web in between the plastic front panel and the tube. I just need to know how to take off the plastic front panel without breaking it. Thank you in advance for the help!
  • 398 Answers
Yes, I have seen this many times. Usually the best thing to do is remove the upper back cover and remove the webs with a clean, dry cloth, but be careful because the mirror is attached to the inside of the upper back cover.
Posted on Jun 26, 2007
My Sony DVD plays but there is no screen on the Sony Bravia TV. I hear the movie but no picture. The HDMI cable is plugged in. Why can't I get no picture? The TV is blank.
Make sure that you are plugged to the input of the TV and not the output. The other thing is it could easily be a bad cable. Check to make sure all cables are pushed in all the way as well. I know that sounds stupid but those are the little things that drive us all crazy but usually fix it. If none of this works let me know.
Jun 12, 2011 | Sony BRAVIA® DAV-HDX279W Theater System...
I have a LG wm2277hw washing machine. the drum will spin a little and then make a scaping sound like friction. The drum has a lot of play in it. Is there a hard plastic washer or shim that wears out. The...
The symptoms that you describe sound like the spider or support arms of your washer has failed. It the part that holds the wash drum true in the plastic tub. It's a rather difficult job to replace the spider since the washer has to be taken apart to get to the spider. Fortunately, LG does sell the spider, instead of making you buy a new spider and drum. You may need to also replace the plastic tub parts if they are too damaged to be reused. Get a few estimates before deciding whether to repair or replace.
Mar 21, 2011 | LG WM-2277HW Front Load Washer
I have a 1999 blazer zr2 with the 4.3 vortec OK now hears the problem to day when i was driveing in the snow i had to use the 4wd so i stopped and hit the 4wd button and it clicked and sounded like it...
Sound crazy, but alot recommendations say thet when you pass from Hi to Lo must insure that you have foot on the brake pedal.
Loss of vacuum engages the front hubs; other for no 4 wheel drive and no indicator light. Go home pulled all the fuses that had to do with the 4 wheel drive system, put them back in and 4 wheel seems to work fine now. And no there were no blown fuses.
I recently had same case and it was a bad electric motor on the transfer case (31000 miles). The 4x4 light wouldn't even light up or engage so I would lean towards it being something different on your end.
Also, could be the actuator pin or w/e the little plastic piece is that engages the 4LO might be broke, or maybe a couple of other things.
Keep us updated.
Jan 22, 2011 | 1999 Chevrolet Blazer
How do i take of the front cover of my 52 inch RCA hdtv? i need to clean out the inside of the tv because spiders somehow got behind the picture...
You will have to remove all the screws on back of TV Front Bottom panel first then you will have more screws that hold Top on in back and under front screen its not as bad as it sounds it just takes awhile to do while your in their clean your mirror and all 3 top lenses to Tubes.
Dec 03, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
The stench of mildew is getting stronger and stronger. it is worse when I open the washer door.
very common in the front loaders and so far there is no cure or reason why of the mold,
Jul 02, 2009 | GE WSXH208A Front Load Washer
Washing machine, bang crash
It sounds liek a shock/support is broke. Remove the lower front panel after you UNPLUG the washer and you might be able to see what is wrong.
Hope this helps.
Thanks
Vic
May 11, 2009 | Washing Machines
Spider web behind front of screen
Take the front speaker grill, and ther will be a few screws on the bottom of the screen. Remove those and lift the screen up and out.
Feb 14, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Bearings on a indest wie 167 washing machine
You can download a user manual for your m/c, but not a repair manual, Go to>
www.indesit .co.uk
Follow the links. To remove the spider, remove the rear panel, remove drum belt, undo drum pulley, you may have to heat the screw holding the pulley,undo all screws that you can see holding the spider to drum rear.
Withdraw spider, you may have to use some force to pull it off.
Fit new bearings or spider, and reassemble..
plz rate this solution.
Dec 15, 2008 | Indesit WA 115 Front Load Washer
Channel's going Crazy
You could have dirty contact switches on Front panel board the one with power vol+ vol- ch + ch- remove the board clean with contact cleaner this shoud slove your problem if not replace front panel board.
Sep 22, 2008 | RCA F36668 36" TV
Panasonic pt-50lc13 air filter location
It is in the front on the left of the bulb compartment. It is as easy as removing two screws using lots of DAMP Q tips and having some patience. Keep carefully swabbing top and underside filter until clean, then lightly and very carefully vacuum with a home vac do not use a shop vac!
Leave TV unplugged with cover off as long as you can I would say a few hours or overnight and then plug in. If the filter is clean and you still get the error message there are other posts here that explain how to go into service mode and reset.
You do not need to spend hundreds of dollars on a "Panasonic" technician who has "done it before". You can dooooo it!!
Jan 09, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Hitachi UltraVision CineForm 55VG825 55" HDTV Logo
99 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
