Question about Kitchen Appliances - Others
Blower motor on wood burner only turns slow.
Blue ridge fireplace wood burner insert L 151271 blower only turns slow. rheostat went bad and a substitute (dimmer switch) was used.
thought if the motor was bad the motor would quit, and not just go slow.
cannot find an onwers manual on line, and the company no longer exists.
looking for a manual, and to find out if the blower motor would go slow, or just not work, if the blower motor is bad.
Thank you for your time.
    Problem Solver:
  • 12 Answers
Go to thehandyhandyman.com he will be glad to help you
Posted on Dec 26, 2008
Need blower for model #crhfd400rt-m-m gas fireplace
PDF]BLOWER ACCESSORY - Home Depot
www.homedepot.com/.../0e104dad-8f0d-4383-aa50-11...
The Home Depotinstructions may result in a possible electric shock, fire hazard and will void ... Thisblower contains assembly instructions for the following models and item ....CRHFD400RT-M-M (Item # 0328248), BD23 series, Q stove, PCSD25RT .... andrequire no further lubrication. ... Type of gas used (Propane/LP or Natural gas/NG).
Lowe's STYLE SELECTIONS Blower Fan for Gas Fireplace ...
answers.lowes.com/answers/0534/product/3162223/questions.htm?...
... real customers have contributed for the Blower Fan for Gas Fireplace Inserts. ... Cedar Ridge 32,000 BTU Vent-Free fireplace (Model# CRHFD400RT-M-M)?
Cedar Ridge Hearth Crhqd250t - Sepeda Ontel Klasik Vector
efratoium.xyz/cedar-ridge-hearth-crhqd250t/
Feb 26, 2013 | Heating & Cooling
Need schematic for BK3 blower sku 6417002
First I would put those two wires on the same side of the thermal. Then see if the blower works. If it does that's the problem. Don't leave it that way, that is a safety switch. If blower works, replace the switch.
Jul 02, 2017 | Heating & Cooling
Blade on fireplace heat o lator appears to be turning the wrong way. Heat does not come out of the top of the fireplace. What do I do to be able to take out the heat o later and reverse the fan?
Roger. it depends of whether this is a Gas Fireplace or a Wood Burning Fireplace?
If it's a direct vent gas fireplace, the blower was installed incorrectly. To access the blower, you will have to dismantle most of the interior of the firebox and the burner tray (Interior floor of the firebox). This will involve disconnecting the gas line from the burner. The blower is on the floor of the control compartment and is attached to the rear wall of the control compartment. Whoever installed it, has it aimed in the wrong direction. Which is can of hard to do, since there is an arrow on it, pointing in the UP direction. Once you unplug it, you can take out the sheet metal screws that hold it in place, and it will be quite obvious which way the exhaust should face. Which is UP.
Now that I've told you how to do all of that, I must be totally honest, by telling you, the blower will not increase it's efficiency. Your Direct Vent Gas Fireplace is rated as a Decorative Gas Appliance only. It is not heater rated. In fact, 80 % of all the heat goes out the direct vent. The only real heat, is generated off the glass, once it's hot.
So now, you get the chance to make the decision. With all that's involved, is worth changing the blower and not really gain anything?
If you have a wood burning, brick fireplace Heat-a-Lator, just turning the fan motor around, so that it's pulling air into the chamber, will solve the problem.
I really hope all of this has helped you. If I can be of further assistance please let me know. Thanks.
Jul 14, 2011 | Heating & Cooling
How do we install a burner on a fireplace?
Thinking of adding a fireplace or wood stove to your home? If so, proper installation and maintenance is absolutely critical to ensuring the fire stays inside your freestanding fireplace or wood stove and doesn't venture outside of it.
If your manufactured home already has a fireplace or wood stove, it's a good idea to go look over these safety guidelines to confirm that it was installed correctly. If you plan to install a fireplace or wood stove, follow these safety guidelines carefully.
First, don't try to tackle this project yourself. While installation manuals usually provide all the instructions necessary for a manufactured home owner to install a wood-burning fireplace or wood stove, the consequences of a mistake are so disastrous, it's a task best left to experts.
It's a good idea to first check with your insurance company for their guidelines before installing these items. Your insurance policy may not cover damages if a fireplace or wood stove was not professionally installed. Plus, the manufacturer's warranty on the fireplace or wood stove may not apply unless the unit is installed by a professional.
Also can check this ARTICLE for other details.
Hope helps.
Jun 02, 2010 | Heating & Cooling
Fireplace will not stay lit and pilot light is on
This sounds like the high temperature switch has failed and is telling the unit to shut down after it gets started, the pilot has to be lit for the main gas valve to turn on when the thermostat calls for heat, The main burner comes on and stays on until the thermostat is satisfied and tells it to shut off, you dont say if there is a blower in this unit, if there is a blower after the main flame comes on the unit heats up it turns on the blower if equiped. If the blower fails to turn on the unit would be shut down on overtemp as the firebox would get to hot and be in danger of causeing a fire. if no blower there still is an overtemp switch that shuts the unit down if it gets to hot or the switch is bad, it could be a bad overtemp switch or if equiped a bad blower motor or even a plugged chimney as this would also cause a overheat ing condition. Hope This Helps Don
Dec 01, 2009 | Napoleon 36" Zero Clearance Top/Rear Vent...
I have a wood burning fireplace and i am trying to find out how to work the side and top damper and vent to heat my home
top damper wide open and bottom damper wide open will burn very hot but too fast if you close the top vent off it will smoke in the house the idea is not to smoke the house but once you have a good fire lit with hot cinders to cut back on the top to ceep some heat in cut back on the bottom to burn slower if this is a metal box wood burner it should heat great if it is a standard fireplace with a glass door you need to be careful how close the flame is to the glass it can break. glass front fireplaces don't heat as well as an insert wood burner let me know if this is uesful or any more assistance needed thank you
Jan 05, 2009 | Heating & Cooling
Kitchen Appliances - Others Logo
309 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
