Question about Vivitar Microscope Set From 100x 400x 900x
What are all the tools used for?
There are several tools that we do not know how they are to used and there is no manual
    Problem Solver:
  • 8 Answers
    Problem Solver:
  • 12 Answers
Go to thehandyhandyman.com he will be glad to help you
Posted on Dec 26, 2008
ScanPst cannot helps
First of all you need to backup a corrupted .pst file before use other tools. All other tools attempt to read a source file. After reading you'll see a recovered messages in a tool. Later you can select a best recovery tool for your case of damages. I selected Convert OST to PST because it shows +10% of messages from my .pst file.
Apr 25, 2017 | Personal Computers & Internet
Pdf repair software
There are manual methods that might help you repair your corrupt PDF data, but most of the times the inbuilt repair tools that manually performs these operations fail to repair he PDF file.
During such cases, professionals recommend using recovery software like PDF Recovery Tool. This tool has an exceeding capability to recover maximum possible data from the most severely corrupted PDF files and save the recovered data in anew PDF file with utmost accuracy and maintaining all the key aspects like images, text, table, graphic etc intact. This tool is compatible with all versions of Windows OS and supports all PDF files created by any software.
PDF Recovery Tool to Repair Corrupted PDF File SysInfoTools
Mar 10, 2015 | Adobe Acrobat 7.0 Professional
2005pontiac wave timing belt installation
There are several pages of instructions and diagrams included in the service manual that explain how to replace a timing belt on your vehicle. Also, you cannot properly perform this task without the special service tools required to do the job. I do not recommend this for a home do-it-yourselfer unless you are willing to purchase the tools and perform this according to the manufacturers instructions. Severe engine damage can result if the manufacturers instructions are not followed and the special service tools are not used.
If you would like a copy of the manufacturers instructions and the accompanying diagrams, I can supply it for you if you want to sign up for my Pro Support.
Jan 07, 2012 | Cars & Trucks
Where can I get the tools required to remove a kenwood kdc x679. The system was already installed in the car when I bought it and it didn't know with the removal tools mentioned in the manual.
at walmart you can buy a stereo removal kit for the tabs on the side of the stereo
or you can use a very thin flat tip screw driver and push it in the side while you try to pull out on the stereo
May 09, 2011 | Car Audio & Video
I had a dremel passed down to me but don't know what it is for. Please advise how I can make use of this tool.
http://www.dremel.com/en-us/projectsandcommunity/projects/Pages/default.aspx
this website is directly from dremel. It shows different projects, crafts, or hobbies you can use it for. It is a real simple tool to use, and also is very handy. You can obtain several types of bits for it ones for sanding, engrving, cutting all types of materials, and much much more. Hope this helps
Jan 23, 2011 | Dremel 395 Variable Speed Multipro Rotary...
I need to install lower ball joints, how do you do this? Are there any diagrams?
Can't "safely" explain the whole process here...
Go to your public library (you have a card, right?).
The "Reference Section" has several car repair manuals (Motor's, Chilton's, etc.).
Find your book and photo copy the pages you need using the Library public copy machines (15 ~ 25 cents per page).
The books are full of pictures and numbered step-by-step instructions. They even give the part number for any special tools. You will need one special tool... a ball joint yoke chisel (another expert will actually know the real name of the tool - $8 AutoZone).
Sep 22, 2009 | 1999 Ford Taurus
Information on usage of oscillating saws
My "solution" was that I finally realized that Fein and Rockwell do not believe in providing service, so I had to look elsewhere. I called Harbor Freight, was able to get the advice and information I needed, and purchased a oscillating saw made by Chicago Tool. I would have preferred a Rockwell Sonicrafter, but after experiencing Rockwell's attitude towards potential customers, I realized that I would not be able to get the help I needed now, nor in the future should I have bought their product.
One good thing came of this experience: I learned of your servixe, and I am bookmarking your site.I'm sure that I will be making use of it some time in the future.
Feb 12, 2009 | Fein FMM250 Start Multimaster Oscillating...
Front wheel bearings 98 jeep cherokee 2WD
You will need several tools to replace the bearing besides a socket set of metric and standard sizes to remove the wheel and brake caliper. A 36mm socket (may be rented at some auto parts stores) An Impact Wrench for the 36mm socket (air or electric should work) A torque wrench (IMPORTANT!)- the 3 rear bearing bolts (12mm?) need to be torqued properly or else they will fail and cause the wheel to separate, i believe they need to be at 75 ft/lbs. Please check. Do not attempt to do this yourself unless you have the proper tools and know how to use them.  I recommend getting at least the Haynes manual that the stores have or buying the Dealers Service Manual (expensive but thorough and usually available on ebay!)
Dec 11, 2008 | 1998 Jeep Grand Cherokee
Model #5880-900 Hoover spin brush carpet cleaner
i WAS LOOKING AROUND FOR A SERVICE MANUAL FOR MY F5897900 CARPET CLEANER AND I SAW SOME THING ABOUT HAVING TO "PRIME" THE PUMP. YOU PPARENTLY TAKE THE TOOL HOSE AND HOLD YOUR HAND OVER IT FOR ABOUT 15 SECONDS. THIS MAY OR MAY NOT WORK.
ANYBODY KNOW WHERE I CAN FIND A SERVICE MANUAL FOR A HOOVER CARPET CLEANER? SEEMS TO BE A VERY CLOSELEY GUARDED SECRET.
RON
Sep 18, 2008 | Hoover F5906-900 Upright Steam Vacuum
Vivitar Microscope Set From 100x 400x 900x Logo
167 people viewed this question
Top Vivitar Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Vivitar Toy Expert? Answer questions, earn points and help others
