Question about LG WM1814CW Front Load Washer
DE Error Code LG WM1818CW
Error code stopps washer an just beeps and then shuts off
  • SheilaRN Mar 17, 2009
    The washer starts briefly then shuts off, display DE. I've unplugged it and tried to restart but the same thing happens.
  • 640 Answers
Door error,,did you overload,,,is door closing correctly..if so replace door switch
Posted on Dec 26, 2008
Why does my LG washing machine model WD(M) 16115FD show error code dE?
It appears to be a problem with the door? You can go to the following link and try their troubleshooting, hope it helps. http://www.ehow.com/how_7850983_troubleshoot-de-code-lg-washer.html How to Troubleshoot DE Code for an LG Washer eHow
Aug 10, 2014 | LG WD-16115FD Front Load Washer
What is LG washer code dE?
The dE error code indicates a Door Error. The washer thinks the door is not closed. Have a look at these...
1. There should be a plastic finger on the door that pushes the door switch when the door is closed. Is the plastic finger broken off by chance?
2. The switch itself could be bad.
3. If you overload the washer, this could cause this error code also.
Aug 10, 2014 | LG Washing Machines
Lg intellowasher wd1074fb
When you see the DE error code, it means a "door error". This is a sign that either the door is not shutting, locking or opening. Most of the time, this is a simple fix and service is probably not needed. Check for something stuck or lodged in door. Check door gasket. Check door latch.
May 13, 2014 | Washing Machines
My washer is showing dE message what is this mean?
The machine identifies and indicates some operational errors through a series of beeps.As you are using LG WM2455 Front load Washer it is showing error message The error message "DE" This error signal beep during drain.Unhook/clean drain pipe and press the 'Start/Pause' button to continue cycle.Thanks for your question.
Jun 17, 2011 | LG WM2455 Front Load Washer
Try to start machine code de showing and beeping
DE = Door Error.
Latch, sensor or similar has failed.
See this link:
LG -
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 13, 2011 | Washing Machines
LG WM-2277HW Front Load error code dE
de error code means the door is open. If code does not clear when door shut then could be door interlock or main pcb fault
Oct 24, 2009 | LG WM-2277HW Front Load Washer
Error code de
Click on your model number (below FIXYA) on this website, & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, u hv your manual on line. If available that is....................
Rate me pl if helped...................
Mar 18, 2008 | LG WD-1280FHD Front Load Washer
Error code de
DE is a error code for your door switch. The door is not locking properly. You need to get a new door latch mechanism.
Sgt 48
Mar 29, 2007 | LG WD-1280FHD Front Load Washer
LG WM1814CW Front Load Washer Logo
281 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
