Question about Whirlpool AWM8143 Front Load Washer
FP code appearing on lcd disply
I have a Whirlpool aa class 6th sense front loadind washing machine,
i keep getting a fp code appearing on the lcd display at the rinse or rinse spin stage of the cycle, we have to stop the programme and move it on to the next stage of the cycle to let the programme finish.
Could you please tell me what the 'FP' code means and is there anything i can do to rectify this.
Thank You.
Remove pump and check pump for foreign objects stopping impellor turning, worked for me hope this helps
Posted on Dec 29, 2008
Fp not draining
have you checked the water pump is actually running there is a possible blockage in the water outlet pipe turn the machine off and try to blow down the pipe to see if its clear as sometimes there is a coin or a paper clip and other items preventing the water pump motor from turning if you can hear your breath bubbles clearly then the water pump is not working, I hope that helps eric
Dec 09, 2017 | Whirlpool Washing Machines
Fp appears on the digital disply
Hello, If the drain time exceeds 8 minutes, the drain pump is turned off and FP is flashing. The pump may have something stuck in it or the drain may be clogged. Hope this helps
Jun 09, 2011 | Washing Machines
Am getting FP error message on a Whirlpool 6th Sense washing machine. Have removed foreign objects from filter but still getting error message. What more can i do?
your right the error code is filer pump now disconnect power and let unit sit for 1 hr should reset its computer
dam computers
Dec 29, 2010 | Washing Machines
What does FP mean?
Try looking online for another manual. Or call anyone who sells your machine. Me thinks the solution is simple, but you need to talk to any seller of your machine, and soon.
Mar 04, 2018 | Whirlpool Duet GHW9150P Front Load Washer
FP fault code on whirlpool washing machine
i have a whirlpool 6th sense awo 10761 and evrytime i start a cycle it stops and the door lock light flashes can any one help me
Nov 07, 2009 | Whirlpool Washing Machines
When machine get to rinse cycle it stops and the letters FP appear.
FP means "faulty pump" but before buying a pump make sure to check your drain hoses first since any blockage may cause the same readout in display:
Opene the flap on the front lower right side and unscrew the cap. If it doesn't come out easily a bit of force will get it out - look for hair klips and fluff blocking the pump inlet/outlet hoses.
GOOD LUCK!
Aug 30, 2009 | Whirlpool AWM8143 Front Load Washer
My washer gets so far then says fp
fp indicates a pump failiure so either clean the pump filter, or if the pump filter is clear then you will need to replace the pump as this is indication of a knackerd pump
Jan 24, 2009 | Whirlpool AWM5125/1 Front Load Washer
Whirlpool 6th sense awm8163 programes never stops now cannot get it to work at all
The pump is at the lower left of the front of the machine covered by a white plate. Use a bowl to catch any remaining water when opening the screw thread inside and then clean and replace. If it is truely beyond repair then a new filter pump can be bought from ebay for £3 or thereabouts.
I have just drained mine manually in this way and am going to run it empty with soda crystals to glean a few more days use whilst the new pump arrives.
Good luck :)
Jan 20, 2008 | Whirlpool AWM8143 Front Load Washer
Whirlpool AWM8143 Front Load Washer Logo
1,206 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
