Question about Sanyo DS24425 24" TV
Aspect ratio I cannot change the aspect ratio on the TV. When I go to the menu, Aspect Ratio is in red and I cannot select it. This is a pain because some shows are cut off, such as sports scores at the top of the screen. The channels work fine on other stations, so I am convinced it is the TV. Please help.
  • Anonymous Mar 28, 2009
    I can't get the audio to work. I get a picture but just fuzzy noise from the audio. I believe one of my 3yr old sons pushed a button on the tv but I can't figure out out to get audio back. Is there a reset option that sets everythign to the way it was originally? Also my aspect ratio is red and I can't select it.
    Novelist:
    Champion:
  • 236 Answers
You may have a vertical circuit problem causing the picture to stretch out. This is called "over scan". You need to have a tech check it for you. Stargazer
Posted on Apr 23, 2007
  • nathanpwoods Aug 30, 2010
    I have the same problem as the first listed above, the channel that the problem involves is a sports channel- in widescreen. I don't know why I can't access the aspect ratio adjustment, please help! There must be a reason for this.
How can I get rid of the nasty wide horizontal line on the screen of our TV manufactured 2008...? Will It be expensive to repair...?
If by "nasty wide horizontal lines" you mean LETTERBOX masks (at the top and bottom of the screen), all you need to do is select the correct ASPECT RATIO for the program you are watching. Consult your USER MANUAL to determine the menu settings for ASPECT RATIO.
If you do not understand what "aspect ratio" means, or what different aspect ratios exist, do an Internet search for "aspect ratio" and read.
May 21, 2015 | Televison & Video
Change aspect ratio samsung monitor
go to picture set up to select the aspect ratio you want like 4:3 or 16:9, just press the menu.
Oct 13, 2012 | Magnavox 32MF369BF7 32 in. LCD TV
Ok, so I need help. My mother just bought a flatscreen tv from best buy and had it delivered today by the Geek Squad. However, the picture makes the people look fat and the sound is tin-like. She can't...
The people look fat and stubby is due to trying to display pictures that were made for old TV 4:3 aspect ratio and you are now trying to fill in the TV screen that has 16:9 aspect ratio. The only way for you to see proper pictures is to set the aspect ratio to 4:3 mode or set it to automatic to let the TV select correct aspect ratio of the pictures, the bad part is that you will see black bars on the left and on the right of the pictures, see more details with regarding to the aspect ratio in the user manual.
Learn more here also:
http://hometheater.about.com/od/televisionbasics/a/aahdtvfaqs6a.htm
http://reviews.cnet.com/16:9-widescreen-tv-aspect-ratio/
Not sure about your sound problem.
Dec 17, 2010 | Televison & Video
I have a 55cm TFT LLED-22FHD TV. The aspect ratio is 16:9. This is too wide and the images appear fat. How do I correct this.
Go to the picture menu and select a different aspect ratio. Auto sizing is useful as the TV will detect the picture size and select the correct aspect ratio, except for letterbox and super wide screen of course as your screen is not the right shape for those.
Hope this helps.
Nov 17, 2010 | Televison & Video
Adjust resolution on lumix dmc-tz3
Select PICT.SIZE from the REC menu. Depending on the aspect ratio, you can choose from 0.3MP to 7MP. For full details, refer to the "Using REC menu" in the manual (page 52 in my copy).
Jul 09, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
Picture size doesn't fit the screen I tried to adjust the aspect ratio but the option is locked on the menu. What to do? (Olevia TV model lt42hvi
You cannot change aspect ratio when recieving HD signal. Try changing the cable box or satellite box format or aspect ratio.
Dec 30, 2009 | Televison & Video
How do I change the aspect ratio
Aspect Ratio–Selects the screen aspect ratio: Normal, Wide, Zoom, or
Cinema. You can also press the ZOOM button to select the aspect ratio.
Aug 16, 2009 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
Occasionaly a wide screen dvd plays only in full screen
The aspect ratio on your DVD player is not set correctly. Look for a SETUP button on the remote control, there should be something like "QUICK SETUP" or something similar on the setup menu, if not then go to the menu that has the aspect ratio settings listed. Change your aspect ratio to 16:9 WIDESCREEN, and this should solve your problem. Your aspect ratio is 4:3 which is for a regular TV, if the images (especially people) look real skinny and tall on your TV then your aspect ratio is not properly set. Good luck to you!
Jul 30, 2009 | Oppo Digital DV-981HD DVD Player
I cannot change the aspect ratio on the TV. When I go to the menu, Aspect Ratio is in red and I cannot select it. On certain channels the screen is too big and I can't see the edges of the broadcatsed...
This is a quote of what Sanyo told me: "The aspect ratio can only be changed when the unit is in the video mode." So I tried switching modes with the input button and it worked but went to like a letter box/wide screen type of picture, which doesn't help me. We have dishnetwork and on the Panasonic plasma we can adjust the ratio with their remote so I have two options there but not with my Sanyo unfortunately. Hope this helps
Jul 22, 2009 | Sanyo DS24425 24" TV
Sanyo DS24425 24" TV Logo
1,393 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
