Question about Frigidaire GLTF1670A Front Load Washer
Front load washer isn't spinning out
I have a frigidaire front load washer model GLTF1670A. it has been working fine until today. all of a sudden it won't spin at all. it looks like it wants to spin, but only slightly moves and then stops and finally goes on to the next cycle.
  • 61 Answers
The first thing to check is if the door is locking. Put the unit into spin turn unit on let it go for about a minute then shut it off, try to open the door right after you shut it off if the door opens you need a door switch if not chances are you need a motor control board. Before replacing the board call for service they are expensive if it is a guess. good luck
Posted on Dec 26, 2008
  • graham mcdonald Dec 26, 2008
Frigidaire gltf1670a front load washer not agitating or spinning. Can my broken shocks have anything to do with that?
Your broken shocks could have disconnected some wires due to the vibration. Plug off the wall, open up the machine to examine. In the process you have to change the shocks. Disconnect and refit each terminal, especially the connector to the motor.
Click if helped.
Mar 21, 2013 | Frigidaire GLTF1670A Front Load Washer
Hello, my Frigidaire GLTF1670A Front Load Washer timer is not advancing. It will go for a little bit then stuck and runs and runs until I advance it myself. What part needs to be replaced? The timer washer...
sounds like your timer is bad take the model to sears repair store and get a new one. make sure before that the washer do the other funtions even if you have to advance the timer. if it does then get the timer.
Feb 05, 2011 | Frigidaire GLTF1670A Front Load Washer
Washer will not spin dry
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 19, 2010 | Frigidaire GLTF1670A Front Load Washer
Washing machine will not drain the water??!?
Check the drain pump it may be clogged or not working. This is a common problem i have working at a camp with 15 washers.
Mar 26, 2009 | Frigidaire GLTF1670A Front Load Washer
Loud noise during spin cycle
I bought the frigidaire affinity washer. It was quiet until it began the spin cycle, then it sounded like a jet taking off and began to bounce. Come to find out we set it up improperly. You must remove all shipping bolts on the back of the machine and make sure it is level. Ta Da!! it now runs perfectly quiet with little vibration.
May 05, 2008 | Frigidaire GLTF1670A Front Load Washer
Frigidaire Front Loader Won't Drain
if your washer is digital or with elecronic control board check the the motor control board located at the bottom difiniely you have to call a tech to confirm that. other model like wd5595 and wd 8095 has the same problem and it is the motor control unit that always fails.
Mar 21, 2008 | Frigidaire GLTF1670A Front Load Washer
Ftf530Es;Frigidaire front load washer
did you check the filter? If the filter is plugged in the least bit it won't allow machine to spin at high speeds
Mar 08, 2008 | Frigidaire GLTF1670A Front Load Washer
Washer will fill, drain, and run a complete cycle but will not agitate or spin
sounds like the motor control board is bad. you could test the motor to see if it ohms out ok, the diagram has the readings. The diagram should be on the side panel (inside the cabinet) on the lt side in a brown envelope.
Jan 07, 2008 | Frigidaire GLTF1670A Front Load Washer
Same as many - Washer does not spin or agitate but everything else works fine
your brushes are gone you will have to wright down you model number and look on ebay there really cheap
Jan 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Front Loading Washer Leaking
there should be a rubber pipe going to the soap draw to the drum normally there's to pips one at the front of the machine and one on the top it is there have a good look in the machine make sure its un plugged be for putting your hands in the machine ok
Nov 28, 2007 | Frigidaire GLTF1670A Front Load Washer
Frigidaire GLTF1670A Front Load Washer Logo
257 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
