Question about Kenwood KDC-X991 CD Player
Usb signal error on kdc x-991
I own a kenwood kdc-x991 and a I-pod 2nd gen. I paird the two togather, everything worked for about ten min then I-pod shut down and kdc-x991 is showing a USB error signal. What can I do to fix this problem?
  • 4 Answers
I had the same problem. Unfortunately with the IPOD Unless you can give it extra USB power, it is unfortunately not enuff from the Kenwood's deck. I had ran a 100gb HDD in an enclosure...I thought great its working...worked fine for.....20-25 mins....
And started getting the USB Read Error...or something to that extent...I forget now. So I tried about 2 or 3 different enclosure that did not need extra power (or should not need extra power to run the drive, and no luck. So anyway I went to fry's and picked up a USB to Cigarette adapter and now all is well...The adapter cost me $10...
I have 3 external drives that now work. The only other thing that you might look at for the IPOD, is getting a cable that has 3 heads....
One going to the USB Port on the Kenwood, and then there's two more heads that split off the other tip one for the ipod and then it y's off to another usb, plug that into the USB power adapter from fry's and that might give you the extra power you need...( I can't guarantee this as I dont own an IPOD and probably never will unless someone gives me one for free.)
Posted on Mar 12, 2009
Kdc-x991 is in protect mode. Mechanic open car door without my key fob and could only turn off alarm by resetting my battery. How do I enjoy my tunes again?!
theres a short in the wiring of the speakers. The protect youre reading is the deck telling you its shut down its circuits to prevent damage.
May 04, 2011 | Kenwood Car Audio & Video
How do i get my kdc x991 to play western digital
you may have too many files, the kenwood units will only handle 65025 files or 50 folders containing 255 files maximum.
Nov 05, 2009 | Kenwood KDC-X991 CD Player
Will the Kenwood KDC 1032 RCA outputs work with an ipod adapter similar to an aux output? If so, how?
Hi, if you are trying to get your I-pod to play through your car stereo, then you would need to have the RCA inputs, not outputs. If you connect your i-pod to the stereo outputs it won't work because both things are trying to push sound out of their outputs. If you connect the adapter to the stereo's inputs then it would work.
Aug 11, 2009 | Kenwood KDC-1032 CD Player
Security unlock code for kenwood kdc-x991
if you bought it brand new it should come with the security code. If not you can try 0000 or 1234, something easy like that is usually the case too.
Feb 23, 2009 | Kenwood KDC-X991 CD Player
I own a kenwood kdc-x991 and a 2nd gen I-pod put the two togather, worked good for about ten min, then I-pod shut down and kenwood unit is sending an USB error reading.Does anyone have an idea how to slove...
Yup...if you use an alternative power source for the usb appears to work fine now. I have (bought from fry's electronics) an adapter now that plugs into my cig lighter and haven't had any trouble anymore.
Dec 26, 2008 | Kenwood KDC-X991 CD Player
Kenwood KDC-MP438U "USB ERROR"
Dec 20, 2008 | Kenwood KDC-MP228 CD Player
Kenwood kdc-x592
They dont work with classic ipod for direct ipod connection, also try updateing the firmware in your ipod this is a common problem, deck looks sweet tho eh?
Jun 12, 2008 | Kenwood KDC-X590 CD Player
Usb drive
Another solution here....I have a Kenwood KDC-x991 deck.
Have USB Read error problems..
Anyway I had a 30gb hdd, replaced it with a 100gb (according to manual, will use up to 120gb w/out external power...)
Anyways long story short, the 100gb drive worked fine for....20-25 mins...
I was happy. Now here's the clincher. After 20-25 mins, it gave the USB read error. (instead of resetting the deck and have to make the date/time/eq/sound/setting changes I unplugged the USB drive...changed source from USB to tuner (or anything else for that matter). Then switched back to USB w/ no device installed and after 2 seconds or less, the USB Error disappeard and said no USB device connected....Anyway thats the best way (I've found) to get around the Resetting the deck. Anyway after that from then on I could not get the Hard drive to work for more than 30 seconds. It would play then give me the read error.
Tried a different drive...80gb same prob...went back to the 30, and it was fine.
Tried a 160 (I knew it wasn't going to work) and it didn't either.
Anyway was thinking what to do.....most of the USB external drives I had came with a power port on it aside from the USB port plug. Or the drives came with the Y Cable....
The long part plugs into the Kenwood deck, and then the END of that cable plugs into your USB external drive, and the small piece connects to a (get we gooooo FTW) USB to Cigarette adapter!!!!!
And this worked like a charm on ALL my drives. Stable...and just plain worked great!
Anyway I hope that this will help you guys w/ your usb probs!
Jan 10, 2008 | Kenwood DNX7100 Car Video Player
Kenwood kdc w5534u
Hi! I have problem with usb...i try to connect 5 or 6 diferent usb flash device and after reading it shown that no device? it is a technical problem? Thanks!
Jan 06, 2008 | Kenwood KDC-W5534U CD Player
Kenwood KDC-X991 CD Player Logo
419 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
