Lighting kit does not light. kit instructions say to connect black kit wire to blue wire in fan, and white wire to white common wire in fan. Nothing happens when lights switched on, Checked for 115 vac between blue and white wires in fan. No voltage was measured.
Check blue wire to bare ground.
Then check each wire to bare ground, with switch on and off.
Add a comment with result.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: Wiring light kit to ceiling fan
connect the white wires from light kit filter to the white wire labeled "for light" from fan. then connect black wire from light kit filter to blue wire from fan. use wire nuts to make the connections
SOURCE: Trying to connect a ceiling fan light kit.
Those connections sound OK ,, now you have to go to the canopy and see if all the wires for the fan/light are connected to a house wire. If there are two switches , then the blue fan wire would connect to the red wire .. it may be capped off in the ceiling. If there is only one control switch , then the blue wire from the fan will connect to the same ceiling wire as the black fan wire does.
Please Vote !!
SOURCE: I am trying to install a universal light kit in a
Remove the fan, attach the blue wire with the black in the ceiling box and your light will work.
Testimonial: "Yep, you are absolutely right! And I was able to remove the cover at the ceiling with no problem. VERY HELPFUL. THANK YOU!"
