Question about Sony DVP-NS755V DVD Player
Blue-Green-Yellow tint when playing a DVD.
Have tried adjusting the Playback Picture (Custom Picture Mode) without any degree of success.
  • 1 more comment
  • csgoltzman Dec 26, 2008
    Component video input. The DVD player is now working after shutting it down and restarting.
    Thanks for your interest.
    CSG
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    how did you hooked dvd player with TV? used composite video or component video input?
  • Anonymous Mar 28, 2014
    When playing a DVD the picture has many many lines such as ///////////////////////////////// thoughout the whole picture. Is there a way to adjust?
  • 10,594 Answers
OK.
Posted on Dec 27, 2008
How do i adjust brightness?
Press the left/right direction button to adjust settings. When you select a picture Mode other than "Custom", these items are automatically given parameters to correspond with the chosen preset mode, so any change to these parameters would return the Mode setting to "Custom".
Oct 28, 2014 | Coby Televison & Video
I am trying to playback videos on my JVC Everio Camcorder using the colored AV cords. I hear the audio coming through my TV but there is no video/picture. I have tried adjusting the settings and tried...
First, set [SWITCH TO ANALOG I/O] to [OUTPUT]
then turn off the (camcorder) unit.
After you connect the cable (from AV connector to the TV's AV Input Connector (accepting the 3 color cables), set the TV to VIDEO mode, selecting the AV input (from your Camcorder).
Then start your playback on the camcorder ...
slide the mode switch to select the (video) mode (instead of the picture/photo mode)... press the PLAY/REC to select the playback mode, and select the desired files/frames to play.
Hope this works for you. Have you tried using the HDMI mini connector instead ? (same process, just set your TV to accept input from the HDMI input)
Jun 03, 2014 | Video Cameras
Green picture
Hi Lizzette,
I am afraid your problem is a little technical. Well if you know something about lcd tv technicals, the problem seems to be the T Con board and/or its connectors. Check the ribbon cables and connectors, clean them properly and and start the tv.If it is not possible or it does not work, please consult someone qualified to handle your set. Good luck.
Dec 18, 2013 | Samsung 46 in. LCD HDTV
Cant change from shoot mode to playback mode.also zoom lens is not adjustable
The Fuji FinePix F470 camera is an excellent device. Most of the controls are computerised in such a way that makes picture taking and viewing less stressful. Changing from shoot mode to playback mode is by the press of the play button which looks like an arrow the zoom lens is not manually adjustable it adjusts by the press of the W and T buttons.
Here is a link to help you download the brochure, User guide and quick start guide for the camera:
http://www.fujifilmusa.com/support/ServiceSupportBrowse.do?prodcat=842410&sscucatid=664271&sscucatid=664272
Hope this soultion has been helpful?
Dec 19, 2010 | Fuji FinePix F470 Digital Camera
The picture has a green tint to it on all channels
The color signal consists of Red, Green and Blue. Those three colors, at various degrees, make all the other colors on your screen.
If you have a BRIGHT green screen it's best you don't operate your set.
If it's just tinted green then there is a problem on the CRT (Cathode Ray Tube) drive board. Do check your "tint" setting and see if someone misadjusted it. If that isn't it then you need to have your set on an electronics bench and get an estimate for repair.
Apr 17, 2010 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Adjusting color/ user mode??
The TV will not let you set brightness, contrast, color or tint in the preset modes like Vivid, Movie, Standard etc. Look for a mode that says custom, user etc..
Nov 11, 2009 | Olevia LT42HVi 42 in. LCD Television
Projection has yellow tint
From your description, it sounds like a problem with the blue color. Green LCD=purple onscreen, Red=cyan(baby blue) onscreen, Blue LCD=yellow onscreen. It could be a lot of dust on the blue lcd panel, or worse, might be a burned polarizer filter behind the lcd panel due to excessive heat. If you can focus on the yellow and its tons of yellow specs, its dust. A burned filter however, must be replaced. A technician trained in projectors will have to do it. The filter material is glued to a thin glass panel and is replaced as a single filter. It's a very involved repair.
Sep 04, 2009 | Hitachi CP-X251 LCD Projector
Camera is stuck in voice record mode when I turn the camera on and I cant change it to camera mode
I have the same problem - mine is from using the camera in the pit at a concert - I think the camera got wet to some degree. I have found a way to get to picture capture mode, but it is a workaround and not a fix.
If you hold the display button (>) in for a couple of seconds, and then turn the camera on, it will go into playback mode without the lens extending. From there, if you press display button (>) again, it will go into picture capture mode.
I'm still hoping that there is some way to fix this, but haven't found one yet.
Jun 24, 2009 | Pentax Optio S5z Digital Camera
Samsung SGH-D880. Cannot turn off annoying beep
Key tone volume
In Idle mode, press [Volume] to adjust the key tone volume.
You cannot adjust the key tone volume in any other way.....
Please rate this solution
Jun 09, 2009 | Samsung Cell Phones
Picture calibration settings for 42lg70
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
  • Fresh Contrast: Off
  • Noise Reduction: Medium
  • Gamma: Medium
  • Black Level: Low
  • Real Cinema: On
  • TruMotion: Low
  • Color Standard: HD (N/A w/HDMI)
  • White Balance: Warm
  • **Method: 10-Point IRE
    • 10 IRE
      • **Red: 1
      • **Green: 2
      • **Blue: -16
    • 20 IRE
      • **Red: -6
      • **Green: 0
      • **Blue: -7
    • 30 IRE
      • **Red: -5
      • **Green: 0
      • **Blue: -4
    • 40 IRE
      • **Red: -8
      • **Green: 0
      • **Blue: -4
    • 50 IRE
      • **Red: -4
      • **Green: 4
      • **Blue: -4
    • 60 IRE
      • **Red: -6
      • **Green: 6
      • **Blue: -5
    • 70 IRE
      • **Red: -8
      • **Green: 3
      • **Blue: -10
    • 80 IRE
      • **Red: -8
      • **Green: 7
      • **Blue: -16
    • 90 IRE
      • **Red: -9
      • **Green: 5
      • **Blue: -18
    • 100 IRE
      • **Red: -10
      • **Green: 4
      • **Blue: -9
Color Management System
  • Red Color: 0
  • Red Tint: 0
  • Green Color: 0
  • Green Tint: -15
  • Blue Color: 0
  • Blue Tint: 11
  • Yellow Color: 15
  • Yellow Tint: 2
  • Cyan Color: -15
  • Cyan Tint: 0
  • Magenta Color: 0
  • Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it.
im isf certified those settings are right on the money straighter than a ruler
Oct 05, 2008 | Televison & Video
Sony DVP-NS755V DVD Player Logo
177 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
