Question about Kenwood KVT-617DVD Car DVD Player
Coin Stuck Inside kvt-617dvd
My cousin (4-years old) was sitting on my car while it was turned off. Hr grabbed the change laying on my car and stuck a couple of coins inside the CD slot. Now the coins are jammed inside. I am looking for a way to take the deck apart and take the coins out without damaging the lens. any suggestions???.....or where could I find a service manual to take the stereo apart. Thanks in advance.
Sell me urs!!!!!
Posted on Jan 02, 2009
Cabrio washer pump (maybe) makes a grinding noise.
The water pump may have an item stuck inside. Open the water pump and remove whatever is stuck inside. I've found jewellery, coins and even sand stuck inside mine...
Stuff you'll need
Adjustable wrench, towels, sticky tape, bucket, screwdriver, pliers, time to repair: 3/4 hr - less if you are very handy.
Instructions
  1. Disconnect the washer from power and turn off water.
  2. Unscrew water inlet pipes from the back with a wrench. Some water may be spilled, so place some old towels on the floor.
  3. Remove the drainpipe from the drain.
  4. Secure the lid of your washer with sticky tape and lower the front of the whole machine onto a towel so the back of the machine is facing up. Ask someone to help you since the washer is heavy.
  5. Unscrew the panel that covers the back of your washer.
  6. Loosen the clamp that secures the pump's inlet hose to the tub and pull the hose away.
  7. Remove the wire protector and detach the pump's wire connector from the body of your washer.
  8. Unscrew the pump's mounting screws and loosen the clamp that secures the drain hose. You can then pull the pump off.
  9. Unscrew the top section of the pump and remove any junk. Rinse it out over a bucket to remove sand and grit.
  10. Screw the pump back together. Then connect the drain hose back to the pump's outlet and secure the clamp.
  11. Reconnect the inlet hose and its clamp, secure the pump with the mounting screws and then reinsert the wire connector and replace the wire cover.
  12. Replace the cover of the washer, lift it back into position. Ask someone to help you since the washer is heavy.
  13. Reconnect the water, drainage pipe and power.
  14. Pick up the towels, pull off the sticky tape and wash the dirty towels.
  15. Pour a (large) glass of wine, sit back and enjoy your handiwork.
Jan 03, 2015 | Washing Machines
Change in the waterpump
You can try disassembling the pump only sufficiently to get the coin out but if you go that far you might take a look inside the pump to determine whether anything else is stuck
Feb 18, 2013 | Haier HLP23E Top Load Washer
Coin completely jammed in vertical coin drop mechanism
unplug the machine,open the top of the coin op i use a stubby 5/16 nut driver,you have to remove the rod and it's a 5/16 inch rod,turn it counter clockwise to remove,this rod holds the unit in place,when you have the rod out then you can grab the front where you put the money in and lift it up and out,it sits in a couple of slotted holes
Nov 11, 2017 | Maytag MAT12CS Top Load Washer
Where can I find the middle and last coin in 1-4. Please help. This is new super Mario bros. I can't find them anywhere. Please be specific
Coin #1 1/4 of the way through the level, hit the ? block and grab the mini mushroom. Go back a few steps to see a tiny pipe; go down that. The coin is on the right side of this area. Coin 2: A bit more than halfway through the level, there is a large walled-in area with a red turtle before it. Step on the turtle, then grab it by holding the B button; throw its shell into the walled off area, then when it finished bouncing around, go down the pipe. Do not collect the coins; instead, hit the last block before the up pipe, then hit the P switch. Jump up the blocks and collect the coin. Coin 3: A bit more than 3/4 of the way through the level, the coin can be seen under an overhang. As little Mario, hold B and dash across the hole in the ground, then grab the coin.
Mar 07, 2010 | Nintendo DS Console
Speedometer is stuck under zero
Pull the rubber trip reset pin out slowly so all you see is the hole & the shaft. Take a long tin-tie (about 5 inch) & fish it inside the speedo to the needle & carefully bring it back counterclockwise when its back at least to "2-3 O'clock" hold it & turn your switch to coil...the needle will go back to zero. keep the tin-tie in your coin box if ever it happens again!
Jan 01, 2010 | 1993 Honda Civic 4 Door
My 2 year old stuffed a couple of coins intoPS3
open it and try to get the disc port open on then just take out the coins and put it back together (and try to keep coins away from your 2 year old)
Nov 19, 2009 | Sony Playstation 3 (PS3) Console
Dryer sounds like there is change on the outside
i had the same problem last week on my dryer, turns out that the felt on the drum where its attached to the housing has worn off, my dryer is so old. i did do careful inspection, by sticking my head in the drum and turning it by hand and looking into the seam. it does sound like there was a coin in there, but it was just metal to metal scrapping. im off to my buddys used appliance store to look for a felt seal.plz rate-bozcro
Sep 20, 2009 | Dryers
JVC HR -J655EK Video Stuck
Hi hannah. The simplest way to remove stuck tapes is to remove the top cover. Usually just a couple of screws. Then remove the stuck tape and put the cover back into place. You can also look for emergency eject hole and insert a snall pin into the hole and attempt to eject the disc while repeatedly twisting the pin inside the hole.
May 16, 2008 | JVC HR-J461MS VHS VCR
Kenwood KVT-617DVD Car DVD Player Logo
167 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
