Question about Sony BRAVIA DAV-HDX267W Theater System with Wireless Speaker Kit System
Sony bravia wireless speakers won't pair? ANy answers?
Just bought a SONY BRAVIA HDX567WF and the wireless speakers won't "pair" up? Help?
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    wireless speaker use infra red sensors for signal transfer, make sure speakers sensors are aligned / facing straight and receiving proper infra red signal from transmitter of main unit.
  • willirl45 Dec 13, 2013
    A little late perhaps but this unit's wireless speakers use RF (radio frequency) not infrared. So the wireless unit does not need "line of sight" to the transmitter.
    Problem Solver:
  • 18 Answers
You might try setting the wireless to a different channel. Mine did not work at all on "A" but worked fine on "B".
Posted on Dec 28, 2008
Sony bravia lcd tv 40 inch
I have a Sony Bravia 46'' TV. I bought a Universal WiFi Adapter from Walmart a few years ago for about $50. You have to plug it into the Ethernet port on the Bravia using an Ethernet cable (the other end of the Ethernet cable goes into the Ethernet port on the adapter). The adapter needs also a power outlet. I do not remember if the adapter came with the Ethernet cable (likely) or I had to buy it separately.
Before buying the adapter make sure that:
1. Your Bravia has an Ethernet port (on my Bravia it is in the back of the TV), and
2. You have/use a wireless router for your home network.
Hope this helps.
Jun 22, 2014 | Sony BRAVIA Televison & Video
SONY Bravia 3D TV won't recognize my SONY 3D DVD Player
I don't have the answer....but I just got the same problem. DVD player senses no 3D TV though my Bravia KDL certainly is. Did you ever get it fixed?
Sep 14, 2011 | Sony TMRBR100 3D Sync Transmitter for 3D...
Turn demo mode off on Sony Bravia home theater
On your remote;
Press the Home button
Scroll left to settings
System settings
Auto-start up - go through setup and select "Home" (not store)
Sorted
Dec 06, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
Sony bravia 46 shutting off a blinking 6 times
here's blink codes for sony bravia
1 blink abnormal AU Power Voltage
2 blink abnormal d5v/a9v power voltage
3 blink Abnormal panel voltage
4 blink backlight failure
5 blink abnormal main power voltage
6 blink abnormal speaker voltage
7 blink internal temp. rise
8 times ic5000
that helps?..
Sep 11, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony hdx279w surround
Your system should come with all the cables and connectors you need for the system. The rear speakers should plug directly into the back of the system using the speaker connectors that came with your system. If you are trying to add additional speakers then you need special connectors for that type of application. You can try www.BogueEngineering.com for special connectors. Hope that helps
Feb 12, 2009 | Sony BRAVIA® DAV-HDX279W Theater System...
S-Sir Sub Unit won't pair
In order to properly pair the units, verify that the channel switch on the back of the sub units are set to either A, B, or C. Then go into the setup menu and go to setup tab. You can then scroll down to system setup. Verify that the base unit is set to the same channel as your sub units A, B, or C. You then can choose the pairing operation. Have your sub units close to the base and on for this operation. They must be linked to have the pairing operation work. The pairing option will ask if you are ready to pair a sub unit. Select OK. You will then be instructed to begin pairing. Find the pairing button on the back of the sub unit and depress. Depending on the sub unit you may see a red light flash or the front display will say pairing. Once complete the menu screen on the TV will tell you that the pairing is complete and ask if you would like to do another unit. Continue if you have another unit or select OK to complete the process. Once you return to the system setup menu the channel indicator A, B or C will have the work pairing next to it (i.e A (pairing)). If you continue to have trouble you can change the RF channel on the system setup menu from AUTO to ON. Good Luck. CEB
Jan 29, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
No sound from back surround speakers
We just hooked ours up and had the same problem, we switched around the s-air cards and that solved the sound problem immediatly.
Jan 11, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
SONY DAVDZ361 HTK
have you checked the ID matches the same as the unit, I.E A on the wireless unit and A on the dvd player,?
what is the wireless unit light status? flashing green???
if flashing and you have tried messing around with pairing best way is to switch the wireless unit to A then do a reset on the unit, cant remember the exact button combinations, it will be in the instructions, something like press stop, pause and power at once. but check the instructions that should solve it, if not email me on eamonnl2004@hotmail.co.uk i will try help you there
Jan 01, 2009 | Sony BRAVIA DAV-HDX267W Theater System...
Codes for DAV-HDX275 BRAVIA
Amigo conseguiste resposta para trocar a regiao do home theather de 1 para 4? No aguardo, em.maciel@ibest.com.br
Aug 11, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Sony BRAVIA DAV-HDX267W Theater System with Wireless Speaker Kit System Logo
268 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
