Question about HP Office Equipment & Supplies
Problem getting J5780 to recognize that cartrige door is shut
I purchased an HP J5780 Officejet and have been trying to set it up. inserted inkcartriges fine and closed lid. when turned on I get the message " door open, close print cartrige access door". from what I can see the access door is simply the top. I dont see anything else to close.please help
  • 837 Answers
Is this a BRAND NEW printer? Just setting it up, just took out of the box?
If so double-check that you have removed all the packing/shipping tape pieces, plasic guards, retaining pieces .. that is what is sounds like
Posted on Dec 26, 2008
HP Officejet J5780 All in one printer does not connect to my computer. I need to scan. How can I connect?
First off all check, printer printing properly?, if its printing only scan option not functioning then uninstall the drivers and re install once again. If printer is not at all printing, check system recognizing the printer or not.. if not recognizing, check with another USB cable,Replace formatter...
Feb 01, 2012 | HP Officejet J5780 All-In-One Printer
Tip
HP OFFICEJET J5780 HOW TO GET SCANNER TO WORK
To get the scanner working this is what you should do. First, do not install the software for Officejet All-in-one J5780. Instead of this, install HP Officejet All-in-one J5700, you can get it from the HP website. I do not know why but this software makes the scanner work. You can then install J5780 which will delete some of the old files but will keep the scan file on.
on May 25, 2008 | HP Officejet J5780 All-In-One InkJet...
Hp officejet j3500- refer to device documentation to troubleshoot
problem with any one of your cartrides. open the carridge door and renove color cartridge and close it.if it says insert left cartridge then it could be the problem with color cartrige.or the same error come then put the color cartridge and remove the block cartrige.if display says insert right cartridge then it could br the problem with black cartridge.try clesn the cartridge contacts & ink nozzles and put it back (use a soft cloth to clean the cotact)
Aug 04, 2011 | HP Office Equipment & Supplies
My officejet says insert cartrige in the slot to
It's not reading the chip on the cartridge. Push a wiggle it to see if it will make contact. Turn it off than on. if the chip is bad you will have to replace the cartridge again.
Oct 16, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Hp officejet j5780, NOT SCANNING
go to www.hp.com and download a new driver of your scaner for xp
Jul 03, 2009 | HP Officejet J5780 All-In-One InkJet...
2007 Microsoft Office won't recognize HP Officejet J5780. Why?
Ok, if it's showing up as a installed printer, right click that printer and choose set as default. Then right click it again, and go to properties. Inside properties you should get a button that has test print. Click that one and see if you get it to print a test page. If you can, then all is well, if not, then their is a driver issue.
Thanks Mark
Feb 23, 2009 | Microsoft Office Professional 2007 Full...
Hp j5780
access door means the door used to replace catridges,it pushes the sensor arm which enables or disable the door sensor,so u better check for thesensor arm connecting properly,try to push the door n check
thnx N
Jan 22, 2008 | HP Officejet J5780 All-In-One InkJet...
Cartridge door shows open but it is shut ?
Very simple,please remove ur cartriges and swicth off the system and now fix and restart ,if problem persit,get back to me
Sep 27, 2007 | HP OfficeJet 6210 All-In-One InkJet...
113 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
