Question about Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher
My dishwasher just quit working there is power to the machine,
None of the front panel lights come on, it just quit without warning! the model # mdb8600aww and serial # 12747634ap thanks kathy
    Master:
  • 416 Answers
Is there power coming to dishwasher did you try another outlet at all (if it is connected to outlet). It can be blown fuse, tripped circuit braker, or just one of the house electric swithes shutts of. Check the power wiring visually maybe you will see a damaged area
due to short circuit. If you see no visual damages try to turn it off for a while then o=turn on again (by unplugging if its possible).
Also You need to check the door latch
Good Luck
Posted on Dec 26, 2008
    Sergeant:
    Champion:
  • 338 Answers
The thermal fuse on your control board blew.. it needs to be replaced. do you need to know how to change it?
  • 100 Answers
Just check may be the main power cod is burnt or faulty.
  • 13,433 Answers
If your dishwasher doesn't work at all, check these:
Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker.
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
I have a Whirlpool Quiet Partner Two dishwasher. The rinse only light & quick wash light constantly blink and I can't run it, none of the buttons will work. Is there a way I can reset my dishwasher?
This generally means the control panel is no longer working and must be replaced. That's the entire plastic assembly at the top of the door, in which the buttons reside. Disconnect power first, remove screws inside the door which hold the panel in place. Unplug power connectors, remove circuit board control board. Find dishwasher model number and search parts for that model. The part is pricey, more than $100 last time I replaced mine. Install control board into new panel, make power connection. Reassemble door. Good to go.
Oct 03, 2015 | Whirlpool Dishwashers
Asko 1805 - inside light is on, none of the operation (front panel) lights turn on
Quite simple after all. If the main power button on the top left hand side of the door is pressed in (on). Whenever the door is openned their is a light in the DW which comes on like the fridge or oven.
Keeping the power button off turns the light off. For us this is good as we usually only close the door fully (catch catches) when we run the machine.This way we are not wasting electricity.
Nov 14, 2009 | Asko 24 in. 1805 Built-in Dishwasher
Suddenly stopped working - won't run on any cycle.
First check the electrical supply. I have seen dozens of dishwashers which did not have the hot wire connected tightly enough (inside the connection box behind the lower panel). Sometimes the loose wire caused the breaker to blow. If you have control lights but the dishwasher will not start it could be a bad door latch saftey switch. $10 part, cheap. Hope this helps, Ken
Apr 24, 2009 | Dishwashers
"normal cycle" light keeps blinking
The blinking button indicates the button is bad. The button console will have to be replaced.
If you need further assistance, let me know
Regards,
reg501
Jul 11, 2008 | Whirlpool 24 in. DU1050SS Built-in...
Dishwasher stopped working
You have a board problem it came from a power surge.
Nov 11, 2007 | Maytag 24 in. MDB5600A Jetclean II...
Maytag Dishwasher
we have a model mdvtt53aww1 and you can push three buttons and will light up the hi temp wash, heated dry and sanitize is there a code make it start
Oct 01, 2007 | Dishwashers
Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher Logo
57 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
