Question about Rowenta Professional DM890 Iron with Auto Shut-off
Rowenta Professional My spray button is stuck. How do I get it to come back up to the orignal position?
    Genius:
  • 1,074 Answers
Take it down and stretch the spring or replace the spring ,it is dead ,if you cannot do it your self contact a tech.good luck
Posted on May 02, 2007
SOURCE:
Rowenta DW9080 Auto/Off stuck. How do I bypass the Auto/Off feature, or find a replacement switch?
thermostat defective,,,can be do drect by expert professional,,,but it will burn your all clothes due to very hot position,without auto cut
Nov 13, 2014 | Rowenta DW9080 Steamium 1800-Watt Steam...
ROWENTA PROFESSIONAL
Try to check the wire connecting to the switch from the steam unit,.,,
Jun 07, 2008 | Rowenta Professional DX8900 Iron
How to take hose off rowenta professional garnmet steamer
http://laundry.manualsonline.com/manuals/mfg/rowenta/rowenta_iron_product_list.html
Aug 13, 2014 | Rowenta Commercial Garment Steamer - White
Retractable cord
Don't be in such a rush to repair your Rowena when the cord won't retract. Simply spray the opening with silicone spray and wait 20 minutes. Hit the retract button and VOILA!!!!!
Feb 03, 2014 | Rowenta Professional DE880 Iron
The rocker button to enable steam to flow seems stuck. It will not rock.
The stem rod for the steam control is choke or faulty. These prevent the water going onto the sole plate that why no steam.It is possible that there is dirt that has accumulated into the stem of the steam button and is sticking the button. It is better to remove the lid and make a good cleaning to free the movement. use good spray of jet air, use WD40 to remove dirt and free.---------------- Pull the button up. You may have to coax it up; You can pry it back to the up position with a needle. Grasp it firmly and pull it straight off (it is fitted in place by friction only). Below the button is a stem that operates the valve, gently full it back up with a pair of needle nose pliers (careful - the stem is plastic). Replace the button (align the stem into the hole on the bottom of the button. Cycle the button a few times with water in the reservoir.It seems like it sticks when the iron is left unused for a period of time; or the dirt get collected under the button.As if the valve sticks when dry. You can leave some water in it when not in use. --------- This will help.Thanks.Helpmech.
Jul 11, 2011 | Rowenta DG-980 Iron
Rowenta DM-880 steam button sticks. Spray button works fine. Any ideas? Thanks.
This will work for sure.
Aug 21, 2010 | Rowenta Professional DE880 Iron
I need to use the self clean on my Rowenta professional iron
On the Rowenta DX8750 Professional model you fill the water tank, set on high, and HOLD the steam level lever all the way over to the right (where it says "self clean"). I did not see the info on the internet anywhere (not even in an online manual I found - my husband pointed it out to me.
You have to hold the lever over the entire time, it won't stay in that position so you almost have to use two hands. Pick the iron up hold it as you would ironing and rock it back and forth bottom to top. It's good to have a cloth under the iron so the yucky stuff doesn't get on your ironing board. I rocked it, and then would lift it nearly vertical and flakes of yuck would come out in the steam, and browinish yucky stuff would come out of the steam holes - just clean that off the sole plate when cool.
Feb 14, 2010 | Rowenta Irons
Rowenta Professional Iron - steam button suddenly stopped working
Have you tried descaling it? It may well be blocked up with limescale. Personally I only ever buy cheap irons and bin them when they go wrong! As you say-they are generally too expensive to repair.
Jun 11, 2009 | Rowenta Professional DX8900 Iron
My Rowenta Professional Iron stopped the steam function button.
You may consider buying annew one Wallmart usually have a range of irons some under $10.00
Jun 10, 2009 | Rowenta Professional DX8900 Iron
Need to clean my Rowenta
let warm up and spray a good oven cleaner on it and let sit for awail(turn iron off) then it should just wipe off!
Please rate this answer!
Jan 23, 2009 | Rowenta DG-980 Iron
Rowenta Professional DM890 Iron with Auto Shut-off Logo
207 people viewed this question
Top Rowenta Irons Experts
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
