Question about Kenwood KDC-X991 CD Player
I own a kenwood kdc-x991 and a 2nd gen I-pod put the two togather, worked good for about ten min, then I-pod shut down and kenwood unit is sending an USB error reading.Does anyone have an idea how to slove this problem?
  • MrWakeup Mar 12, 2009
    I have the same problem. I BELIEVE that the USB port from the deck is NOT powerful enough...I had mine playing an external 100gb Hard drive fine for 30 minutes for the first time....and then after that it would not stay on for more than say 30 seconds....
    Unplug usb device....change the source to something other than usb...change it back to usb, then the error goes away and you can plug your usb device in again...but you will most likely get that error again.
    I am working on getting an external power source for my external enclosures...but not sure how that will work out at the moment.
  • 4 Answers
Yup...if you use an alternative power source for the usb device....it appears to work fine now. I have (bought from fry's electronics) an adapter now that plugs into my cig lighter and haven't had any trouble anymore.
Posted on Apr 26, 2009
2 Suggested Answers
  • 4 Answers
SOURCE: Usb signal error on kdc x-991
I had the same problem. Unfortunately with the IPOD Unless you can give it extra USB power, it is unfortunately not enuff from the Kenwood's deck. I had ran a 100gb HDD in an enclosure...I thought great its working...worked fine for.....20-25 mins....
And started getting the USB Read Error...or something to that extent...I forget now. So I tried about 2 or 3 different enclosure that did not need extra power (or should not need extra power to run the drive, and no luck. So anyway I went to fry's and picked up a USB to Cigarette adapter and now all is well...The adapter cost me $10...
I have 3 external drives that now work. The only other thing that you might look at for the IPOD, is getting a cable that has 3 heads....
One going to the USB Port on the Kenwood, and then there's two more heads that split off the other tip one for the ipod and then it y's off to another usb, plug that into the USB power adapter from fry's and that might give you the extra power you need...( I can't guarantee this as I dont own an IPOD and probably never will unless someone gives me one for free.)
Posted on Mar 12, 2009
Powermate 4000 watt gen set shuts down after 10 mins of operation
Coils do develop thermal issues sometimes - replacing it is a good place to start.
Sep 13, 2017 | Coleman Powermate 4000 Watt Generator...
Does the kenwood kdc-2025 have a way 2 hook up a mp3 or i-pod?
no, it says mp3 player because it can read mp3 discs that are burned with Kenwoods software.
Dec 30, 2009 | Kenwood KDC-2025 CD Player
Will the Kenwood KDC 1032 RCA outputs work with an ipod adapter similar to an aux output? If so, how?
Hi, if you are trying to get your I-pod to play through your car stereo, then you would need to have the RCA inputs, not outputs. If you connect your i-pod to the stereo outputs it won't work because both things are trying to push sound out of their outputs. If you connect the adapter to the stereo's inputs then it would work.
Aug 11, 2009 | Kenwood KDC-1032 CD Player
GENERATOR WILL RUN ABOUT TEN MINS WITH LOAD THEN QUITS
You may have a 'TEST" mode on your Generator. Ten Minutes is usually the duration of the 'Exercise' function of most units, so I'd like to determine what mode you are starting your generator in. Please comment.
Mar 18, 2009 | Electronics - Others
Dec 26, 2008 | Kenwood KDC-X991 CD Player
Kenwood kdc-mp 825
it's a Canadian Kenwood.
http://inform3.kenwoodusa.com/manuals/KDC-MPV8025.pdf
I had the 925 purchased from Ebay, but I sold the car with it.
it's probably the ribbon wire broken between the face and the unit. I know that on Ebay some they use to offer a repair for these type of units.
Sep 06, 2008 | Kenwood KDC-MP828 CD Player
Ipos nano 3
It will work bu tonly after enabling the aux jack.
Place unit in standby mode then press menu for a second and then goto aux and select it to aux on1
Sep 02, 2008 | Kenwood KDC-135 CD Player
Kenwood Kdc 237
hi i just had same problem . Its because the steroes aux port is not switched on as default.
I downloaded the pdf manual for free and went through the steps .Unit has to be in standby mode then hold the menu button down untill the menu appears select aux then turn it to either off aux1 or aux 2 and that fixed the problem for me :) goodluck
Aug 25, 2008 | Kenwood KSC-310CCS Center Channel Speaker...
Kenwood kdc-x592
They dont work with classic ipod for direct ipod connection, also try updateing the firmware in your ipod this is a common problem, deck looks sweet tho eh?
Jun 12, 2008 | Kenwood KDC-X590 CD Player
Kenwood KDC-MP5028
with the unit in standby, press the menu key, use the joystick control to choose aux, and set the aux option to "on"...then press menu again to save...when you next switch on the unit, using the SRC button you can cycle through the available options...cd - tuner - aux..etc etc
Oct 24, 2007 | Kenwood 2005 KDC-MP5028 CD/MP3...
Kenwood KDC-X991 CD Player Logo
334 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
