Question about HP Pavilion a330n (Refurbished) (RBDM169AR) PC Desktop
Tower wont turn on
My tower for my pavilion a330n wont turn on when i press the power button on the front. Now it has done this to me before. When it does this the light on the back will blink but when it is solid green then i can turn on the power and it works fine. It usually starts working fine in a week or so. But now it has been over a month! Every thing else works fine( moniter, ect) Any help?
  • James shmidt Apr 20, 2007
    This makes sense to me. I happen to have a older pavilion sitting around so i'll see if that PSU will fit and work.
  • 385 Answers
Your power supply inside the CPU has finally failed. I agree with Smooth_Gecko, to be on the safe side, borrow one and test it first.
Posted on Apr 20, 2007
    Problem Solver:
  • 5 Answers
Same thing happened to my Pavilion t461 which eventually failed altogether. Recommend the Coolermaster IGreen PSU from eBuyer which fitted perfectly with a bit of persuation. Very quiet and comes in varies power outputs. Good review at http://www.overclock3d.net/reviews.php?type=3&id=81&page=1&desc=coolermaster_igreen_power_430w
Posted on Dec 09, 2007
    Scholar:
  • 125 Answers
Sounds typical of a failing PSU. Try and borrow one to test it? Check all connections first. Buy a bit big in the watts next time, it will use LESS power and be reliable. 500 or 600W
Posted on Apr 19, 2007
Hi could you help me now
Posted on Apr 25, 2007
Wont power up
My wont turn on too, There is a orange light on the tower, Green on the left, Battery ovel, If I push the restart button, also switch the power supply switch in the back, also unplug from it, Sometimes does it, Do ou know whats causing this to happen, Please let me know Thanks
Jan 26, 2013 | Asrock K10N78M Motherboard
The power button on my hp pavilion a330n does not turn on pc
Hi names rui
hmmmm no power have you check if the power supply is working when you press the power botton if not try replacing it.. if you replace it with a new one and still dont power on maybe your motherboard has a problem try going to a service center and ask them to check it out...
Jul 19, 2011 | HP Pavilion a330n (Refurbished)...
I need to replace the Power Supply from my a330n. I took the old one out last week, the new one arrived and I cannot remember (or see) were the 4 Pin plug goes too. I tried start up with out it, computer...
I'd check for pics on Google images on the model of your tower. Generally, the connectors in PC wiring are only meant to fit their proper connector (you don't have to worry about plugging into the wrong female connector, because it just won't fit if it's the wrong connector)
Feb 03, 2018 | HP Pavilion a330n (Refurbished)...
The light on the power supply (back of tower) and light on the front button that turns on the computer flashes. This is with the power cord plugged in. The computer does not turn on when I press the...
try removing the front panel make sure the button isnt clogged with dust or disconected failing that it may well be your power supply internal fuse which can be repaird but a trick job if youare not very good with a soldering iron you may get a replacement one on ebay.
Oct 06, 2010 | HP Pavilion a622n (PC108A) PC Desktop
When pressing the ON button it will not respond that fast it wont power up in short ... but waiting for a very long moment press it once again and it will be powered up .. what do you think was my pc...
Could be a static build up on the motherboard. Disconnect the power cord from the abck of the system tower and press the power button in the front for 20 seconds.
reconnect the power cable to the tower and now power on system.
Thanks for using fixya
proton
Jun 09, 2010 | HP Pavilion A6010N (882780985575) PC...
Wont post , no video what cld be wrong
It might be an issue with the motherboard or Memory but still you can try for a power drain
Unplug all the cables from the tower,
then press and hold the power button for 30 sec
then connect the cable back to tower then try to turn on your computer
Apr 29, 2010 | HP Pavilion m7560n PC Desktop
Tower problem
the problem is your power button needs to be replaced or you can buy a new pc box on ebay for cheap.
Nov 02, 2008 | HP Pavilion 754n PC Desktop
Hp pavilion a305w isnt working
sounds like it is in standby mode..........try pressing and holding the power button until it turns off fully. then remove the power cable to reset the power supply, wait for 5 mins then plug in and try again,
it is also possible that you have a fault , possibly a failed power supply, it might be best to investigate that if the power reset doesn't work
Sep 17, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Hp pavilion a330
the simplest solution maybe just so simple... just a suggestion try unpluging the power connector to the motherboard then just press the power button to clear and shorted circuit and grounds then replug the motherboard power... if still no power try a new power supply.... better buy a new one than more parts will be damaged if you got a broken power supply.... how to check your power supply??? plug the power cord then use a hair pin to plug the red wire (wire in the middle) the just plug the other end to any black wire... if the fan of you power supply works your power supply still good to go... use some tester for the voltage values of wires...
Jan 23, 2008 | HP Pavilion a330n (Refurbished)...
HP Pavilion a330n (Refurbished) (RBDM169AR) PC Desktop Logo
598 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
