Question about Digital Products Hewlett Packard OfficeJet J6480 InkJet Printer
HP 6480 all in one printer
What type of cord do I need to plug into the printer to the wall plug? Do I have to buy one from HP or will a genereic one do? Appreciate your help if you can
Thanks so much
    Scholar:
  • 97 Answers
along with the printer u might have got a 2 conductor wire, u should use that or ask for 2 conductor phone cable..............
Regards,  raj_p5983
Posted on Jan 22, 2009
How to reset printer HP deskjet D2660 all lights are blinking
Follow these solutions in the order presented to resolve the issue.
Solution one: Reset the printer
  1. Press the Power button to turn on the product.
  2. With the product turned on, disconnect the power cord from the rear of the product.
  • Unplug the power cord from the wall outlet.
  • Wait at least 15 seconds.
  • Plug the power cord back into the wall outlet.
  • Reconnect the power cord to the rear of the product.
  • If the product does not turn on by itself, press the Power button to turn it on.
  • Solution two: Service the printer Contacting HP for service in all countries/regions except Asia Pacific.
    If you have completed all the preceding steps and are still experiencing a problem, service the product.
    Determine if your product is in warranty or out of warranty. If you need help determining your product's warranty status, go to HP's Warranty Check Tool .
    • If your product is in warranty, Contact HP to obtain service.
    • If your product is out of warranty, Contact HP to find an authorized service provider or to setup service (fees might apply).
    Nov 25, 2014 | HP Deskjet D2660 All-In-One InkJet Color...
    Hp laserjet 1020 meltdown
    Try this out:
    Some printers require time to turn on. These printers may or may not give feedback in the form of blinking light(s). Wait up to a minute for the power light to come on before proceeding with the steps below. Instructions If the printer uses a power adapter (module), follow the instructions below. If the printer uses only a power cord, see the section below entitled “ If the printer uses only a power cord .” If the printer uses a power module Follow the steps below to ensure power is properly supplied to the printer:
    1. Check the power module part number against the part number listed in the User’s Guide to ensure the proper power adapter is being used.
    2. Disconnect the power cord or adapter from the wall outlet.
    3. Disconnect the printer data cable from the printer.
    4. Disconnect the power cord from the printer, wait thirty seconds, then reconnect the power cord to the printer.
    5. Disconnect the power cord from the power module and reconnect the power cord to the power module. This may not be necessary if the power module has a permanently attached power cord.
    6. Reconnect the power cord directly into a working wall outlet. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead. NOTE: "The HP Photosmart 8100, 8400, and HP Deskjet 6000 series printer power cords feature a green LED built into the power plug. If the LED is not glowing, the power module may have failed. Proceed to step 7 below.
    7. If the printer still will not turn on or the power LED built into the power cord is not glowing, plug the printer into a wall outlet in another room. If the printer or power LED turns on when connected to an electrical outlet in another room, there is a problem with the power in the original room.
    8. If there is still no power to the printer, then the power module, cord, or printer may be defective. Try the power module/cord on another HP Deskjet or Photosmart printer, of the same model if possible, to see if the power module is functioning. If the power LED is still not glowing, the power module may be defective. Replace the power module and cord.
    9. If the power module/cord works on the other printer, then this printer is defective. Service your printer.
    10. If you cannot determine whether the problem is the printer or the power module/cord, or if another printer is not available to test with, replace the power module/cord first. If this does not resolve the issue, service your printer.
    If the printer uses only power cord Follow the steps below to ensure power is properly supplied to the printer:
    2. Disconnect the power cord from the wall outlet.
    5. Reconnect the power cord directly into a working wall outlet. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead.
    6. If the printer still will not turn on, plug the printer into a wall outlet in another room. If the printer turn on when connected to an electrical outlet in another room, there is a problem with the power in the original room.
    7. If there is still no power to the printer, then the power cord or printer may be defective. Try the power cord on another HP Deskjet or Photosmart printer to see if the power cord is functioning.
    8. If the power cord does not work on the other printer, it is defective. Replace the power cord.
    9. If the power cord works on the other printer, then this printer is defective. Service your printer.
    10. If another printer is not available to test with, carefully inspect the power cord for damage.
    11. Inspect the power cord for visible damage. If the power cord is damaged, replace the power cord first. If this does not resolve the issue, or if the power cord looks fine, then service your printer.
    Goodluck,
    Dont forget to rate me as fixya..
    Jan 30, 2008 | HP LaserJet 1020 Printer
    98.01.01. error on HP LaserJet 600 M602
    Try this:
    Turn off the machine
    Take the toner/cartridges out of the machine
    Wait 30 sec
    Plug the power cord back into the printer and wall (Make sure the printer is plugged into the wall and not a surge protector)
    Insert the toner/cartridges back into the printer
    Turn it on and test
    Nov 29, 2013 | HP LaserJet 3030 All-In-One Printer
    Hp PSC1210 All-In-One not turning on
    HP makes a couple of different power cords for the PSC 1210 and their other printers. First make sure you are using the correct power cord (Amperage and voltage). Unplug the power cord (from the wall and the printer and from a power module if you have one). Leave all of the sections unplugged for at least 15 seconds to reset the power module/printer.
    Next connect the power cord to the wall outlet and to the power module if present and check if the LED (if present lights up). If it doesn't try another outlet. In either case, check what the outlet voltage/amperage is at the end of the power cord with a multimeter (before you plug it into the printer). If you have a power module, then check the Amperage (it will be a DC current out).
    If you are not getting the correct voltage and amperage out or the LED doesn't light (with a known good outlet), try a different power cord/module.
    You can order these from HP.
    If you have the correct power at the cord, plug the power cord into the printer and attempt to turn it on. (Press and release the power button.) If the printer still doesn't come on, the unit needs service. Contact HP if the printer is under warranty. Decide if it is worth fixing if it is out of warranty.
    I hope this helps.
    (I've had to use the HP Repair/Replacement service after a unit was in a home that was hit by lightning. Due to printer availability, an HP gift card was provided to buy a new printer.)
    Dec 11, 2011 | HP PSC 1210 All-In-One InkJet Printer
    Hp deskjet 940c - all 3 light are blinking
    Check this page...
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpd09170&cc=us&lc=en&dlc=en&product=59129
    "Here's what it says is the solution for all 3 lights blinking.
    1. Turn the printer off. Unplug the power cord from the back of the printer. Unplug the power cord from the wall outlet.
    2. Wait 30 seconds. Plug in the power cord to the wall outlet. Plug in the power cord to the back of the printer.
    3. Turn the printer on.
    If you have completed all of the steps listed above and are still experiencing a problem, service your product."
    Dec 23, 2009 | HP DeskJet 940c InkJet Printer
    Just changed both ink cartridges. Test prints fine. Tried to copy a doc, prints wall to wall black ink. What's up?
    hi first of all try to scan something from your computer if scan is fine then open solution center and then go to solution center and click on settings after that click on printer tool box click clean print heads/cartridges after cleaning align then now try to copy
    if still you have a problem then Perform a reset of the HP All-in-One
    1. Press the On button and turn off the HP All-in-One.
    2. Unplug the power cord from the wall outlet.
    3. Unplug the power cord from the back of the HP All-in-One.
    4. Wait for 20 seconds.
    5. Plug the power cord back into the HP All-in-One.
    6. Plug the power cord into the wall outlet.
    7. Turn on the HP All-in-One by pressing the On button.
    Aug 05, 2009 | HP PhotoSmart C4280 Laser Printer
    The plug is no good and do any one no were i can buy a plug for a hp photosmart 7760 i brought it from a flee markit for only 10$ so if anyone no were i can bug a plug that fit it please advise me...
    If it's just the plug, any standard computer power cord will go between the wall and power brick.
    If you actually need the power brick, the part number is 0950-4401 and it should cost you about $30.
    Jul 12, 2009 | HP PhotoSmart 7760 InkJet Printer
    How do you print envelops - the names are never centered and theirs a ig space between name and address on envelops hp office jet pro 6480 all in one
    Since there are few step you have to complete before you can pirnt envelop
    and theis site will not let me listed all of the step and pic to show you how it is setup.
    the following link is the HP 6480 printer define how the evelop printing is done.
    start on page 21.
    http://h10032.www1.hp.com/ctg/Manual/c01325559.pdf
    Jan 13, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
    HP J 6480 Fax
    1, plug in fax line in line jack on all-in-one unit
    2, hit the fax key
    3, key in fax number whitch you want to fax
    4, hit start
    Dec 04, 2008 | HP OfficeJet 6210 All-In-One InkJet...
    Digital Products Hewlett Packard OfficeJet J6480 InkJet Printer Logo
    314 people viewed this question
    Top Digital Products Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Alan Rothery
    Alun Cox
    Are you a Digital Products Office Equipment and Supply Expert? Answer questions, earn points and help others
