Question about RCA HD52W59 HDTV Projection Television
Service menu How do you get the service codes to get into the service menu in the tv to do the convergence. I had a power surge and the fuse blew and I replaced it and all I need to do is realign the blue and red again.
Turn television off and then hold ch - and vol - on the tv, not remote, for about 10 seconds and it will come back on with service menu up. There you can change alignment.
Posted on Dec 10, 2007
    Problem Solver:
  • 6 Answers
1. TV turned on
2. Press and hold the 'Menu' button at the tv.
3. Press and release the 'Power' button.
4. Press and release the 'Vol up' button.
5. Release the 'Menu' button.
6. The initial security parameter displayed will be 'zero' Change this to '76'.
You are now in the Adjustment mode
7. Use the 'Channel up or down' to select parameter 'P'.
8. Write down the old value of the parameter before changing.
9. Use the 'Volume up or down' to change the parameter value.
10. When you have made all the adjustments you want turn the set off to exit.
Posted on Nov 15, 2009
Htey will not align in the customer setup menu and I know how to use the service menus. all I need are the codes to get into the menus. Techs want to charge $300 to adjust the tv.
Posted on Apr 20, 2007
    President:
  • 1,284 Answers
You can align them in the customer setup menus. I wouldn't touch the service menu unless you know what you are doing.
Posted on Apr 19, 2007
Colors are seperated on toshiba 50A61
Go into menu and with original remote call up convergence--either it has a problem(will not adjust) or you may with the remote be able to manually adjust the convergence back: sometimes if a power outage/surge it scrambles the convergence memory.
Aug 28, 2012 | Toshiba Televison & Video
I can't find auto converge choice in menu of rca 52" rear projection tv.model # R 52 WH 74.
You have 3 pico fuses by your fly-back transformer. One of them blew that controls your convergence circuit. Your TV now thinks that it is a Basic CRT set with 1 tube. Find the bad fuse and replace with a 1/2 amp pico fuse, and re-solder all the pins of your fly-back transformer. Your menu should have the convergence option again.
Apr 27, 2011 | RCA HD52W59 HDTV Projection Television
Setting convergence using service mode on the tv.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Nov 23, 2008 | RCA P46920BL 46" Rear Projection...
Double vision tv
MY TV WON'T COME ON? MY POWER SURGE WORKING IS WORKING.
Jun 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Convergence problem on 60 inch rear projection RCA
i have a rca 52 inch projectin t.v and the power light turns on then off 3 times then it won't turn back on
Apr 22, 2008 | RCA P60828 TV
Fuse blew. Convergence messed up - No menu option. GE 46GW945
if you had a good pic before it went out then keep it but if you did not then toss it yes you have bad stk convergence ics this is not costly if you do the repair your self you might even have bad solder connections just look and see if your connections have small cracks in it then just solder your done good luck
Nov 15, 2007 | GE 46GW945 46" Rear Projection Television
Convergence
Replace (2) STK392-150s these are your convergence ics.
Nov 12, 2007 | RCA P52928 52" Rear Projection Television
Convergence/menu problem
The convergence power supply has failed,replacing the 215530 reg.on this board will restore the convergence menu,this board is on the right side facing the back or the set mounted on the black plastic above the board with the 6 heat sinks on it
Mar 01, 2007 | RCA P52930BL 52" Rear Projection...
Fuse location on tv
a fuse is a small glass tube about 3/4" to 1". it is located near the end of the power cord inside the tv. it is located in the power board supply circuit. there are several reason why fuse blew up. 1. sudden surge current/voltage in your area 2. shorted in either power supply or horizontal deflection circuits. when replacing fuse, be sure to change it with the same value. but if after replacement has been done and the fuse blew again, there is a short in the circuit as stated in reason no. 2. refer to a qualified service technician if you are not inclined with this job. good luck!
Feb 12, 2007 | Panasonic CT-32HXC43 32" TV
RCA HD52W59 HDTV Projection Television Logo
1,005 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
