Question about Acer Aspire 3004WLCi Notebook
Computer won't power up
I'm not sure why, but my laptop won't power up. Any thoughts? Should I buy a new battery or get a new ac adapter? Any help would be greatly apprecited!!!
I think my 3004 over heated when I left it on a leather chair.
When I press the on button, an orange light in the front of the unit flashes six times. The computer does nothing.
Posted on Dec 30, 2007
    Scholar:
  • 113 Answers
The first thing you must must check if the AC Adapter is working, because, even if the battery is bad the AC Adapter must allow the notebook to turn on. Check if there is any light turned on on the AC Adapter. Now, there can be several other reasons why the notebook is not powering up - - A bad hard drive. You can remove the hard drive and then try turning on the notebook - Bad RAM. Again the RAM can be removed and check if the notebook powers up We can have several other reasons why the notebook is not turning on. Those are just some general issues and common resolutions Please revert back with further observations.
Posted on Apr 19, 2007
Won t charge new battery
Few options: either the connection is "hazy" (try moving the plug in the hole), battery is fake or battery has been abused and is empty...
Aug 16, 2013 | HP Mini Computers & Internet
Dell m5110 laptop won't charge new battery and ac adapter is not recognized in bios
Try another AC cord/charger with the EXACT same specs as original. Is the battery a genuine Dell battery, if not return it? Some aftermarket laptop batteries don't play well with your computer, the pin-out connections aren't correct and MAY be a fire hazard.
Apr 06, 2013 | Dell Inspiron Computers & Internet
Averatec 3700 notebook is charged but will not power on, nothing happens when power button is pushed even when power cord is plugged in
Try to remove the battery and turn the computer on with only the AC adapter connected. If it works then the battery is failing. If it does not there is something wrong with the motherboard or the AC adapter. hopefully it is just the AC adapter. Try to borrow an AC adapter from a friend or anybody else. Make sure that the current and power rating is exactly the same. Or else you might end up with a burned laptop. It the known working AC adapter works, then it is your charger. Buy a new one.
Jul 04, 2011 | Battery Technology Battery Averatec 3700...
Hi, my laptop crashes when the ac adaptor is plugged in yet it will charge the battery fine when the laptop is shut down.
Problem description: The laptop shuts off when AC power adapter is plugged in. The laptop works fine on battery power but as soon as you connect it to AC adapter, the laptop turns off.
Possible cause: 1. Power adapter failure.
2. Motherboard failure.
Possible troubleshooting steps and repair solution: First of all, test the power adapter. Make sure the adapter outputs correct voltage. It's possible that the output voltage is not correct and the laptop shuts down to prevent the damage. Test your laptop with another known good power adapter.
If the problem still exists, even after replacing the adapter, most likely it's the motherboard failure. Replace the motherboard.
Resource: Acer Laptop AC Adpaters
Mar 20, 2011 | Acer Computers & Internet
Hello. At first, the indicator light that shows whether the battery is loading/getting empty etc. failed. As I thought it wasn`t important I continued using the laptop. Then the battery loading adapter...
Most probably this is caused by the battery charging circuit inside your laptop. It looks like it is not charging the battery. If this is the case you won't be able to fix it yourself. You and should send it for repair.
Feb 28, 2011 | Computers & Internet
Dell xps m1210 won't power up with new battery. Check notes.
If it is working fine with a fresh battery then it is not a motherboard problem. It is either a bad ac adapter jack on the motherboard or the actual ac adapter cord is not working. Try cables2go.com as they have replacement ac adapters for almost everything under the sun. Hope this helps.
Jul 10, 2009 | Computers & Internet
Toshiba M115 S3094 Battery Probelm
Your battery not able to hold a charge is a bad battery.
Love your precise description & diagnoses. Wish others would describe their troubles as well as you!
Have a great day!
Mar 14, 2008 | HP Pavilion dv6000z Notebook
Bad decision with new AC adapter for M105-s3004?
if you look at the bottom of the laptop, you,ll see a voltage rated input. i.e 19v-3.1A or similar.
providing the plug fits, and the voltages are the same, you can,t do much damage to either battery or motherboard.
you can buy universal voltage packs now for laptops, which usually run from 15volts to 19-20 volts.
And several different connectors. for different models.
Of course the manufacturers want you to buy theres, and at thier top notch prices, but a replacements every bit as good. although may not be as superior quality.
check the voltage rated input underneath, if it,s the same.
Use it.
Mike @ compurepair.
Feb 25, 2008 | Toshiba Satellite M105 Notebook
Acer Aspire 3004WLCi Notebook Logo
120 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
