Question about Watches
How to adjust watch band on relic steel watch
First 4 links on both ends of the watch band have directional arrows pointing to the left on one side and point to the right on the other side . 3links wide and 2 skinny links in center seems like a pin goes through all 5. need to size this watch band . how do i remove the links to size it.
  • 51 Answers
OK basically there must be an element that you can push out in the direction of the arrow. Either there is a very thin pin (like a needle) that you can push out with a blunt sewing needle (break the tip), or there is a more sophisticated system as it is shown under the following link:
How to remove links from a watch strap
Cheers
Critter
Posted on Dec 26, 2008
  • alexander czajor Dec 29, 2008
    What do you mean "inappropriate" ? At least I tried to help.
Shorten the band on a Mossimo watch
Thank you for contacting FixYa.
  • Place the watch face down on the cloth. This will help keep your watch from being scratched.
  • 2
    Examine the links closest to the buckle. These links will have small pin holes on each side of the link, as well as a small arrow engraved on the inner side of the band. These indicate the direction the pins must be removed.
  • 3
    Place the driving tool (a thumbtack will work) inside the pin hole in the band and push the pin out in the direction of the arrow. Remove the pin carefully from the other side.
  • 4
    Repeat Step 3 to remove any links needed to adjust the band properly.
  • 5
    Reattach the band to the buckle. Attach each end of the buckle back to the bracelet, driving the pin in the opposite direction from how it was removed (opposite the arrow).
  • Best regards. Jewel
    Sep 15, 2010 | Bulova Watch
    Remove links
  • Wrap the watch band around your wrist to determine how many links need to be removed for the watch to fit properly.
  • 2 Place the watch face-down on a flat surface.
  • 3 Look on the back of the watch band. You will find an arrow that indicates which direction you should push the pins to remove the links.
  • Find the point at which the extra links need to be removed for your watch to fit your wrist. Using a 1 mm flathead screwdriver (or the edge of one side of a pair of tweezers), push the pins in the direction indicated by the arrows.
  • Finish removing the pins with your pliers.
  • Keep the extra links in case you ever need extra room on your watch band.
  • For further assistance, check out the link:
    http://www.pulsarwatches.com/home2.asp#FAQ
    Aug 17, 2010 | Pulsar Men's Stainless Steel Bracelet...
    How do you adjust the steel watch band of a Citizen Sky Hawk A-T? JY0000-53E
      Making the Band Shorter
    1. Step 1 Stand the bracelet up on its side. Look for arrows on the inside of the bracelet.
    2. Step 2 Insert a small pointed tool from your hobby or watch set into the tiny holes on the edge of the bracelet. Insert the tool in the hole at the base of the arrow. You will see two holes on the edge of the band. Both pins need to be removed.
    3. Step 3 Push the pin out with force in the direction the arrow is pointing. Repeat this process on the second pin. When the pins are removed the link will be loose.
    4. Step 4 Remove the link from its neighbor and replace one pin to secure the bracelet.
    5. Making the Band Longer
    6. Step 1 Remove the link closest to the clasp by putting a small, pointed tool into the tiny hole on the edge of the watch band.
    7. Step 2 Push the pin out so the link is detached from the clasp.
    8. Step 3 Put a new link next to the detached link and line them up so a new pin can go through their holes and attach them together. You may need to snap them together depending on the type of Citizen bracelet you have.
    9. Step 4 Place the pin into the hole on the edge of the band and push the pin through the band with your sharp tool to attach the two links.
    10. Step 5 Repeat this process if you need to attach more than one link.
    Aug 14, 2010 | Citizen Watches
    Adjusting a casio s940db watchband
  • On the inside of the band, locate the links with the arrow etched on them. The arrows mark the removable links.Lay the watch on its side on a flat surface with the arrows pointing downward. Be sure to leave about 1/2 cm of space between the bottom of each removable link and the flat surface. Using a 1/32" flat head jeweller's screw driver (or metric size 1.0), insert the tip of the screw driver into one side of the removable links' pin holes. You will find that the pins have an end that looks like a screw head. This is misleading - press down very firmly on the other end. Press downward firmly to make the pin pop out the other side. Be careful not to lose it.Remove the pin on the other side of the arrow-marked link.Repeat as necessary to remove half the needed links. You will remove the other half from the other side of the band to maintain equal band length.Flip the watch over so the arrows are pointing upward.Align the holes in the remaining links. Insert the rounded edge of one of the pins into the open link hole. The pin will go in without trouble until the top.Holding the pin in place, carefully flip the watch over again and firmly push the pin fully into placing using the flat surface. The pin will snap into place.Repeat for the other half of the band as necessary.
  • Sep 26, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
    How to make a relic watch bracelet a little smaller?
    No but if this is a mens watch there might be a micro adjustment on the clasp. To adjust press the pin in the clasp and move the pin in or out depending on the position of the pin to make loose or tight.
    Sep 18, 2009 | Relic 0504648FA
    Purchased fossil ladies watch am4183 at Macy's, stainless steel band is too big, is this band adjustable, if so how.
    Check the sides of watch band and you will see the pin ends. They are holding all links together. If there are arrows inside the watch band, they are pointing the way the pins must come out.
    To shorten the band you have to:
    Extract the pins.
    Take link(s) off.
    Join the rest of band together and drive pins back.
    Jan 01, 2009 | Fossil JR8096 Wrist Watch
    Item number L12445 band adjustment
    How do I shorten the links on a woman's eco drive citizens watch band?
    Apr 22, 2008 | Watches
    Remove link form Relic Wrist band
    For my relic ZR15372, all I did was take a thin, hard object (a thumbtack in my case) and carefully pushed out the connecting bar from the link.
    If you look at the inside of the band of your watch, you may notice that on some of the links (the ones nearest the clasp for me) there is a little arrow pointing at the side - if you look at the side of the links, there should be a little hole, big enough to push a thumbtack into. If you apply enough pressure (again, carefully - no need to stab your thumb or any other part of your body), the connector pin should slide out a little on the other side. Then it's just a matter of pulling the pin out - perhaps a pair of tweezers would do the trick.
    Hope this works for you!
    Feb 14, 2008 | Relic 0504648FA
    Watch Band Adjustment
    I just got this watch for a gift and was able to remove links myself after doing some research. It really isn't difficult if you are patient, have a little mechanical experience, and have some very basic "tools" available.
    Tools:
    • 1 push pin like you use on bulletin boards with a plastic head
    • 1 small hammer like a tack hammer
    • 1 pair of small pliers. Needle nose pliers would be best but I used diagonal wire cutters (be careful not to cut the link pin)
    • 1 small block of wood
    Try to pick a well lit table in a room where you will not be interrupted.
    Procedure:
    1. Lay the watch and band sideways on the block of wood so that a pin for the link you would like to remove is just hanging over the edge of the block and pointing down. You need the block to brace the band while you hammer lightly on the pin. Someone to hold the watch in that position would be helpful, but it can be done alone. Only try to remove pins that have an arrow on the back of the band pointing at them. It does not matter with this watch band which way you go with the pin.
    2. Carefully line up the push pin point with the top of the pin.
    3. Slowly, lightly and carefully hammer the plastic side of the push pin so that the pin in the link just emerges from the band on the bottom side enough so that you can grab it with the small pliers.
    4. Slowly and carefully pull the pin straight out with the pliers. You can pick up the watch from the block of wood to get a better grip. Be careful not to bend the pin since you will need to replace at least one of the pins you remove.
    5. Repeat steps 1 - 4 until the band is the correct length. I needed to take out 3 so I removed 2 from one side and 1 from the other side of the clasp.
    6. To fasten the watch back together again, gently insert the pin back in the hole it came from it. You will probably need to use the tack hammer to make the top of the pin flush with the band.
    Nov 05, 2007 | Relic 0504648FA
    Watches Logo
    1,308 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
