Question about Sys Technology SYS 172L-C-JT 17" Flat Panel LCD Monitor
Hi, My friend gave me an SYS -172l-C-JT monitor that he wasn't using any more. There's nothing wrong with it, but in the process of setting it up I pressed the wrong sequence off buttons and now it's stuck in Japanese and I can't figure out how to get it back to English. Would someone be kind enough to post or e-mail me step by step instructions on getting it back to English? Also, is there a site where I can download an owners manual?
  • Peter Fadoulakis
    Peter Fadoulakis Dec 28, 2008
    Problem fixed. Neighbor was throwing out a 19 inch flat screen because of a bad power cord. Took it and fixed the power cord.
    "Life is goog again" :)
2 Suggested Answers
rtrahan
  • 741 Answers
SOURCE: Monitor Language stuck on Japanese
The manufacturers website has the manuals and most of the time you can download them As for as the language goes. You may have changed the Regional settings by accident. Click on Start>Control Panel>Regional and Language settings. Set it back to English.
Posted on Dec 26, 2008
Microtek C783 Monitor flickers when turned on
Hi there. Try to remove and reseat your video card first... maybe there's nothing wrong with it actually...
But if you check the on-screen display, like the brightness controls in your lcd monitor blinking... then you need to have it repaired or replaced.
Hope I gave you an Idea.. ^_^
Jun 06, 2010 | Hannspree 19" Widescreen LCD Flat Panel...
No disply
hi im josh in cenu phils.may i help you friend? just try my solutions this will help you.]
All this video card and monitor business sounds fairly complicated although, if it's all running right, it's no big deal. Only when something goes wrong in the process do you need to get involved.
So what can go wrong? Here's a short list:
  • Your cables might be disconnected. If the cable from the video card to your monitor isn't firmly connected, all sorts of strange images can show up onscreen. Or, sometimes, absolutely nothing at all shows up. Cable problems are like that. So if you have a video problem, you should always check your connections, including the power cable. And while you're at it, make sure that you don't have any bent pins on your cable plugs.
  • Your monitor might need adjusting. Most monitors have the same type of picture controls as your TV set—contrast, brightness, and even vertical and horizontal hold on some models. Some monitors let you adjust the size and position of the display image itself. If your display doesn't look right, adjust it.
    tip
    tip_icon.gif To keep your monitor in tip-top shape, avoid dusty areas and strong magnetic fields. You should also use a soft, static-free cloth (or special "screen cleaner" wet pads) to clean your monitor screen at least once a week.
  • You might have a bad monitor/card combination. Believe it or not, some newer video cards don't work with some older monitors. In particular, you can't use a higher-resolution card with a lower-resolution monitor. Check with your dealer to make sure that you have the right monitor/card combination.
  • Your video card might be inserted improperly. The video card is just like any other expansion card in your computer. If the video card isn't seated in its slot properly, it won't work right.
  • Your video card might be set up incorrectly. Some video cards use either separate software programs or switches on the card itself to adapt to a particular monitor and system. If the card's switches are set wrong, the display might not work at all. Check your card's switch settings against those recommended in the card's documentation.
  • Your drivers might be set up incorrectly. If you've loaded the wrong video driver for your video card, you could get gibberish on your screen. If Windows doesn't recognize your video card, it will run a generic video driver—which will display the lowest possible resolution. It's also possible that Windows will recognize the wrong video card, mistaking your card for another card and causing all sorts of havoc. As is the case when installing any new device, you should always double-check your driver setup.
  • You might need a new video driver. Check with the manufacturer of your video card to make sure that you have the latest version of their video driver. Older drivers might not work with newer versions of Windows.
  • Your monitor might be on the fritz. If your TV can go on the fritz, your PC monitor can go on the fritz, too. If you get lots of lines onscreen, or smoke out the back of the monitor, or if nothing at all happens, suspect the worst.
  • Your video card might be bad. Enough said.thats all for now Good luck.
Mar 05, 2009 | Intel Motherboard
Base missing, need replacement parts
I believe this may be you contact link.The   I-800 ...   number is at the bottom of the page.
http://www.sys.com/help/support/components_peripherals.asp
Feb 27, 2009 | Sys Technology SYS 172L-C-JT 17" Flat...
Dec 26, 2008 | Sys Technology SYS 172L-C-JT 17" Flat...
Fluctuating display when processing data in my PC
Does it mean that text, or any data found in your monitor has a shadow? There is nothing wrong which kind of system your using (xp, linux) it is on the monitor. It is on the mixing of color, the repair man/technician knows how to adjust those things.
Thanks
Nov 19, 2008 | LG Studioworks 700S 17" CRT Monitor
Monitor not getting info from computer
Does the computer beep when it starts? Does the monitor work on another pc? Possible culprits with these symptoms are the power supply and video card.
Feb 16, 2008 | HP Pavilion 533w (P9859AR#ABA) PC Desktop
SYS Technology monitor SYS-152L-C-JT
What kind of cable do you need? Data cable?? you can use from the other old crt monitor.
Power cable?? is the same cable from desktop cpu computer. Are the same type.
Sep 06, 2007 | Sys Technology SYS 152L-C-JT (Chrome) 15...
Repair Help
Hi the FIRST thing I would do is, check the Lamp(s) and see if they are OK.. Next replace ALL the Electrolytic Capacitors in the Power Supply section.. with same or Better temperature ratings. Esspecially any by any Heatsinks or the like. If this don't sort ya problem, it may not B worth continuing?
Aug 06, 2007 | Scanport H7 17" LCD Monitor
Sys Technology SYS 172L-C-JT 17" Flat Panel LCD Monitor Logo
88 people viewed this question
Top Sys Technology Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Sys Technology Computer and Internet Expert? Answer questions, earn points and help others
