Well....you entering the WRONG IP address.....
from your manual :
3 Configuring this Wireless-G Router
In this chapter, it describes how to use the web management tool, a web browser-based utility that
allows you to remotely configure and manage this Wireless-G Router.
Open your Web browser and type the IP address "http://192.168.1.254" and press <ENTER>.
Enter the User name and Password when prompted, the default User name is "root", and the
default Password is "1234".
Tallon41
SOURCE: cnet CWR-854 does not work
You may be advised to use an RJ45 LAN cable to try the following, then use the wireless connection when all ais up and running. The default Login ID and Password is ?root? with password ?1234?. This Wireless Access Point?s default IP address is 192.168.1.253, You can reset this Wireless Access Point back to its default settings by clicking on Reset button, and then press OK button to confirm your decision. Note: you can also hold down the reset button on this Wireless Access Point?s panel for more than 10 seconds to reset its default settings back to factory default. If the reset doesnt work turn off router then on again first, but if the reset doesnt work, the router may need to be replaced.
SOURCE: CNET CWR-854 Wireless G problem.
hello!
you may try this and see if this help solve your problem
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear
stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and test the Internet connection.
if this still didnot work, maybe you need to upgrade the firmware of your router
SOURCE: Can't Access Web configuraton for Cnet CWR-854 Wifi router
Have you try to update the firmware by any chance?
Let me know
comier957
SOURCE: no access to web based utilty
Seems like you need to verify that the web management interface is at the address your specified or that your PC is indeed wirelessly connected to the CWR-854.
The following suggestions assume you use Windows XP as your OS:
Use the Default Gateway value as the new address to use for the web based utility if it differs from what you expected.
SOURCE: I want to connect cnet cwr 854 as an Access point AP,
ENABLE YOUR WDS ENTER THE MAC ADRESS CIENT
