Beko TV/DVD combi doesn't play dvd's
Hi, My brand new Beko Tv/dvd combi won't play dvds it keeps coming up "No Disc". Is there something I can do to resolve this or is the dvd player knackered?Cheers Al.
Slinteriors
  • 8617 Answers
SOURCE: dvds wont play
sounds like the optical pickup is faulty in your DVD player, have you tried the DVD in another unit?
Posted on Jan 17, 2008
  • 108 Answers
SOURCE: philips HTS6510 dvd player useless ..
This is because you DVD player's lense got too old. Try to clean that with a good Lense Cleaner. If the problem persists, change the Lense for the same.
Posted on Feb 04, 2008
SOURCE: Digilogic TV and DVD combi
Clean the laser lens
Posted on Nov 07, 2008
SOURCE: Tv hums when hdmi is connected via dvd player
how do you have the audio hooked up for it if you are using componet cable (red,white) for sound they could be causing the humming you can either switch audio cables or use some other form of cable for sound
Posted on Jan 24, 2009
JOHN RESTY
  • 38 Answers
SOURCE: dvd is not recognising dvds
your DVD lens is damage you change that another lens from same DVD
Posted on May 05, 2009
No sound from pre-recorded dvds in tv/dvd combo
Check the sound setup to TV. Refer its user manual for details. Check whether the audio format to the recorded disc do match with to that of TVs.
Apr 25, 2013 | Televison & Video
Recently bought a toshiba tv and dvd combi but wont play any dvds
You need to go in the menu and change the region code. yours is not set for amarican made dvd's
Mar 05, 2013 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
My old dvd player will not play some discs it says wrong disc what is the problem?
the reason why your old dvd player doesn't read the new dvd's is that might not compatible format or not the same region.
Nov 15, 2012 | Televison & Video
Hitachi 22 inch tv dvd will not play dvds it keeps coming up no disc
You have to clean the lens. Buy a DVD wet and dry cleaner. That should do it.
Jun 10, 2012 | Televison & Video
Check disc
The DVD player's laser pickup assembly is intermittent and since it is brand new and under warranty take it back for replacement. There should be no issue with your TV set.
Mar 18, 2012 | Televison & Video
My Technika TV/DVD Combi was playing a DVD but then made a noise like it was trying to skip tracks before going off. When I try to go back on to the DVD it says "no signal" and won't...
Hi.We can't help you here. Take it to a repairman. Inside you maybe able to check for a fuse but nothing else. If the cost is more than a new TV than you can decide for yourself. Good luck
Jun 28, 2011 | Televison & Video
WRONG DISC ERROR WHEN PLAYING A DVD
HI,. this is a lens assembly fault. the lens is malfunctioning or, it may have stopped reading. this wrong disc code is just a universal warning that is concerning a fault if the main board doesn't receive any data(audio,video) when the disc is inserted.
Due to the integrated status of your unit, this will be a costly repair because, the entire assembly is combined together with the vcr section as well.
You will need to replace the entire assembly to fix this issue. the lens has burned out.
you can confirm my diagnosis by preforming a cleaning of the lens with a cleaning disc. if the unit continues to not read or play a CD after the cleaning, this will confirm my diagnosis.
Please rate and have a great day:)
May 23, 2009 | Bush DVD142RC 14 in. TV/DVD Combo
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Vhs dvd combi panasonic dmr ez47
If you select the HDMI channel to watch a dvd does it do it then, if not disconnect both ends of the scart lead and reconnect or replace. If the scart lead is not in properly this could happen, when you switch on the player and play a disc your tv will automatically switch to the AV/Scart channel, but you are better off manually turning the TV over to the HDMI Hi-Def channel for DVD.
Dec 24, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
