Question about RCA F32650 32" TV
Tv makes loud chirping noise but does not turn on
I need to fix my 32"tv. It makes a loud chirp noise, but does not turn on. Is it worth fixing or should i get a new set?
    Problem Solver:
  • 4 Answers
Cost i about $100 from $50 just to look at it. not really worth it especially if it reaches $300. this is a transistor problem
Posted on Jan 06, 2009
My GE DBXR453GAWW is making a loud chirping noise
The rear drum berring is worn causing the chirp.
The motor berring is bad causing the chirp.
Service is needed to prevent fruther damage.
Jan 19, 2010 | Dryers
Zenith 32" TV Chirping Noise No Picture
Components in Power supply are bad most likely a 35v 100ufd capacitor if not then your Flyback transformer is bad
Jun 09, 2009 | Zenith IQB32B42W 32" TV
Chirping noise from Freezer and Refrig
Simple fix. Unplug refrigerator, locate fan, wipe clean from collected dirt etc. and spray a little WD-40 on the shaft. Spin the fan. Plug in and voila, chirp is gone.
Permanent fix, replace motor.
Nov 21, 2008 | Refrigerators
RCA F32650 no picture
Sounds like the flyback. Mine did the same. I am in the process of trying to fix it. Try for more help.
Jun 24, 2008 | RCA 32F531T 32" TV
TV makes chirping noise, won't turn on!
That usually means a problem in the start up or deflection circuits. Diode, Horizontal ouput or driver transformer. What Chassis is this set, and I will be ableto give you some better information. Rca , GE and phillips need to be diagnosedwith the chassis number. Let me know the chassis.
Jan 25, 2008 | Televison & Video
Model F27650 RCA Entertainment Series
I have a RCA Entertainment Series 32' Model Number F32650Y01E024C226E just stopped working. no picture, just a chirping loud noise that came from the back of the tv.
Any suggestions?
Jan 06, 2008 | RCA 32F531T 32" TV
No power just a chirping noise.
Chirping means the power supply is being loaded down by a short in most cases, likely a bad convergance IC
Oct 21, 2007 | Philips 60PP9352 60" Rear Projection...
My RCA TV turned itself off and started making chirping noise
You have poor solder connections these sets are famous for this! Solder Flyback transfomer pinns this should fix it.
Oct 07, 2007 | RCA D52W19 52" Rear Projection Television
RCA F27667 No Picture / Chirping sound
I will bet you 10 to 1 that the flyback transformer and the horizontal output transistor is bad. an no at this point the set is not worth fixing.
Sep 28, 2006 | RCA F27667 27" TV
My tv is making a chirping sound with no picture
Sure can as its the most common problem RCA ever had with their tv sets, besides the tuner sheild problem in the past.. Your problem maybe a small coil off the horizontal driver transformer and the other side going to the base of the horizontal output transistor, as the coil needs to be taken out and the leads scraped as at the factory the robot left too much enamial on the coil wire and it causes a bad connection. Problem 2 could be a shorted horizontal output transistor that is shorted and or the main high voltage tranformer/flyback. If you know how to work on tvs then all you gotta do is give the model or chassis # to the parts distributor and they will give a kit with alot of papers to read and follow as well as a small blue cap along with a new transformer and be sure you measure the horizontal output transistor out of the circuit as in circuit it will measure shorted because the horizontal drive transformer to the base of it. Now if your not a tech then your gonna want to take in this set to a pro but let me warn ya its gonna cost between $175.00 to $250.00 bucks to fix.. Good luck
May 30, 2006 | RCA F32650 32" TV
RCA F32650 32" TV Logo
251 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
