Question about Electrolux UltraLux 2000 Bagged Canister Vacuum
? light come on no power
? light come on but vac. does not come on
    Scholar:
  • 128 Answers
You motor might be broken
this is the only thing i can think of unless your motor is not getting power
this could be a loose wire
if the light is comming on then the unit its self has power
hope this helps:-)
ricko
Posted on Dec 29, 2008
The panasonic EComax light rollers not turning , belt is fine. filters are fine.. and even with power on nothing happens. switch is on carpet mode.
"belt is fine" . Not likely. Belts need replacing yearly. Just because it isn't broken doesn't mean it's working properly. Most vacs should be serviced annually. Take it to your local vac shop for service.
Oct 26, 2014 | Vacuums
My central vaccum just stop working last night. It does not turn on at all.
I've gone through 3 vx475 vac in the past 7 yrs. Last one was sent to me in Apr 2010. Just yesterday, once again, my vac just quit. Green power light is on but no other sign of anything. Had a burning smell when vac quit, like motor just fried. Called Nutone again and they can't imagine whats going on but will send out another vac free and was told to throw out old one. They said dust may get into the motor and cause it to quit. These vacs aren't cheap, can't imagine that its so simple to just call up and have a brand new one sent to me. I've asked if they are rebuilt units and was told no. So my advise to you, if you haven't already, is to simply call them up w/model and serial # and they shouldn't give you any prob. good luck.
Sep 03, 2010 | Broan-NuTone VX475 Bagged Central System...
Electrolux diplomat power switch won't depress. One minute it was working, the next it wasn't. When I try to press the button, it doesn't feel like I'm making a connection. The Empty Bag light came on when...
The power switch has failed if it wont depress. As for the change bag light, its a little tube that measures airflow. If it gets clogged up it can issue a faulty code. Its best left to a vac shop to fix the check bag light. Depending on how handy you are the power switch isn't too bad to replace. I recommend searching youtube or consulting the vac expert collective of vacuumland.org.
Sep 25, 2017 | Electrolux Vacuums
I have an electolux [ lux classic] vacuum cleaner, and there is no power to it. I think it is a loose wire, as it was tempermental before. I can't find a way to get into it to see if it is a wire
Does the green power light located on the top of the vac come on with the cord plugged in the outlet ? If so your switch could be bad. If not, you could have a bad connection or a broken wire. Caution ! If you do get into the vac, you can cause more damage to the vac. Is the vac more than five years old. If not, your vac is still under waranty and you should get it fixed for free. Take it back to you Aerus/Electrolux shop. You can find out if the unit is still under waranty by calling the customer service with the serial number. They can tell you. 1-800-243-9078.
If you still want to get into the vac (which I do not recommend) let me know and I will tell you.
Joe
Nov 15, 2009 | Electrolux Vacuums
On my kenmore central vac no power unplug unit plug it back green light comes on but try turning vac on green light goes off again .
Please clarify that we are talking about the central vac LED/switch panel panel and plugging it into a 110 V wall receptacle.
If I understand when you unplug from the power source ,then plug back in the green LED comes on, looking normal ? But when you manually activate the switch on the motor housing of the vac itself the vac does not start and the LED goes out, so no green or red LED at that point?
If this is the case , Kenmore CV's built approx 5 years ago (MADE by EUREKA) and prior had a circuit board with attached cord (as opposed to detachable) which was prone to relay failure. There were several symptoms, most common was that the relay on that switch panel /circuit board would fuse on and the vac would continue to run when the hose was detached from the wall.However some I worked on from that era had exactly the same symptom you describe. If your unit is between 5 and 10 years old and this sounds accurate, you can unscrew this curved side panel relay with one philips screw. Inside on the PCB will be an L shaped black or white 24volt relay, generally rated at 10 amps. The replacement board or relay will be rated at least 24V/ 15 amps or more. If you can isolate your motor and test it separtely with a power cord or meter , the realy/board will be the only control componnet left.
If you have a small tipped soldering IRON, not a gun, you can generally find a replacement relay to rebuild the board for about $6 at an electronics parts store. Otherwise you will need to replace the control board itself, anywhere form $45 to $70 plus service call if you have a tech come out to the house, and the tech will just unscrew , detach wires and replace the board, no repair , approx 15 minutes work. This will likely cost over $100.
Please post back with your results
Oct 24, 2009 | Easy Flo EF1400 Central System Vacuum
The beater of my kenmore vacuum won't turn on - the primary light goes on but none of the sensor lights go on.
Kenmore vacs generally have three male contacts at the machine end.Internally when the hoses swivels these contacts run on three brass rings which can also get dirty due to proximity to dirt. They can get dirty or dirt can fall into the corresponding female socket where the hose meets the vac. If you have just changed the bag inspect these connections near the intake port on the vac.
The working LED means you have a partial connection. Also try wiggling and twisting gently at the handle of the hose and where the wand connects to the hose and the power head elbow... you have 4 connections between vac and head
Sep 06, 2009 | Kenmore 22812 Bagged Canister Vacuum
Need to replace belt on beater brush
If you press on either side of the raised top light cover it will come off. Then you will be able to see the light bulb and two screw heads. Remove the two screws and the top cover of the power brush will lift off and you will be able to access the belt. You can find this belt at www.vacbelts.com.
Jul 01, 2009 | Vacuums
Central Vac will not turn on.
These problems are nearly exclusively caused by a bad circut board and replacing it is the fix. Bad boards can cause many different effects so its nearly impossible to be sure. The 9v signal wire is not enough to short out an entire unit so it is unlikely the hose. If it is a direct connect system and you are pulling power from the 110 somehow that would cause main unit problems but that is unlikely at best. Sounds like a failed board to me.
Best of Luck
Jun 04, 2009 | Easy Flo EF1400 Central System Vacuum
I need to know how to change my kirby into a blower?
Raise the light assessory on the front of the vac. Remove the roller assembly by rotating the square dial as indicated by the arrows. Then you must attach the accessory that sort of looks like a 4 inch square open box to the front of the vac where you removed the roller assembly and lock into place. Next you remove your bag assembly by unsnapping at the top of the handle to the vac, then at the base of the bag assembly you must unlock the plastic base from the metal vac unit by turning it counter clockwise and then pulling off. Finally you attach the hose assembly where you removed the bag assembly and lock into place by turning clockwise (reverse of taking off bag assembly base). Put vac in neutral and power on. Now you will blow from the hose assembly.
Apr 20, 2009 | Kirby G4 Bagged Upright Vacuum
Electrolux Z8240 Cyclonic Bagless Vacuum Cleaner
Be sure to check the hose , wands and power brush for obstructions as well.
If there's a burning hair electrical odor then it might be toast.
i despise bagless vac's as they always wind up being more maintenance and expence then bagged vac's.
Good Luck and let me know what you find out.
Oct 08, 2008 | Vacuums
Electrolux UltraLux 2000 Bagged Canister Vacuum Logo
53 people viewed this question
Top Electrolux Vacuums Experts
Marvin
Marvin
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
