Question about Brother HL-2070N Laser Printer
Brother HL 5250 DN status shows "error". Won't print.
My recently purchased HL 5250 DN was printing fine until today. Status showed that printer was ready. I sent a document to printer and nothing happened. I checked status and it said "error". What is wrong and what can I do to fix problem?
  • Anonymous Mar 18, 2014
    printer is online, but does not print
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 27, 2009
Why won't it print?
Brother HL 2040 Laser Printer Repair solution - YouTube
? 2:25
www.youtube.com/watch?v=t4GGvm3aW7c
Oct 25, 2012 - Uploaded by nobblynoel Brother HL 2040 Printer Repair solution for multiple page jams For more Info ... My Brother HL2030 laser printer is making a groaning/grinding noise on ..... FIX YOUR PRINTER: ERROR: Printer Does not Grab Paper fromTray ...
Aug 07, 2015 | Brother HL-2030 Laser Printer
What are the steps to reset toner lights for Brother HL 2240
Try this Toner reset sequence (worked on Brother HL-5350DN)
With Printer off open the toner door
Hold the Go button as you turn the printer on.
All lights will turn on. Keep holding Go until status light goes off.
Press the Go button 2x.
The Paper, Drum & Toner light will come on
Press Go 6x
Status light will turn red
Close the front.
Jul 02, 2014 | Brother Hl2240d - Hl-2240d Laser Printer...
Hl-1440 printer red, yellow lights keep flashing on and off prints ok what is it
Normally nothing to e alarmed about. As you said, it still appera to print okay. This flasing is a warning that your toner is low and will soon need to be replaced. If you recently replaced the toner artridge and know this not to be the case, print out a supplies status page from the onboard menu to see if it show low. Sometimes we are not aware of how much we have printed, hence the warning and the printer is usually right.
Apr 27, 2010 | Brother HL 1440 Laser Printer
Print want print
If you recently purchased it, just put it back in the box and take it back to the store for a replacement. I wouldn't bother tryng to fix it if you can get a brand new one that works the way it's supposed to.
Apr 02, 2010 | Brother HL 2140 Laser Printer
Brother HL-5250 printer toner Light on but Cartridge has Toner it
Try this....
1: Turn off power and remove toner/drum
2: Tape the little spring loaded lever just inside the printer on the upper left hand side in the *DOWN* position! Do not replace drum yet and...
3: Turn power on to printer and let it cycle. Status/Toner lights will come on as usual.
4: Turn off printer, remove tape from lever, replace drum and turn back on.
Mar 08, 2010 | Brother HL 5250DN Laser Printer
I have a Brother HL-5250, drum light on, not printing
When the drum light is on solid, it's time for a new drum, if you have a new drum, just open the front door and hold the go button til all lights flash and the drum is reset. Press the go button 3 times and it will print a sheet showing the drum status.
Sep 15, 2009 | Brother HL 5250DN Laser Printer
Brother HL-5250 DN - Drum Replacement Problem
Try a new toner, if its still a problem then the drum is a dud. I've had dud generic drum's before.
Feb 26, 2009 | Brother HL 5250DN Laser Printer
Duplex Printer prints one side upside down
If it's the same as the Brother 4070 you go into printer proerties (press properties next to printer selector after sending a document to print).  Choose the advanced tab, on this tab near the top are five buttons with icons on, the second one shows two pages with A and B on, press this to access the duplex and binding options.  In there change from "flip on top edge" to "flip on left edge"
Jan 17, 2009 | Brother HL 5250DN Laser Printer
My Brother HL 5240 has Status toner, drum and paper lights on, I bought it on 4/30/08, new toner, plenty of paper, it showed on computer: printer is off line, but it was connected with computer. Really...
The drum light will flash on my brother HL-5240 Laser Printer when printing but it continues to print just fine. Does this mean the drum needs to be replaced?
Aug 07, 2008 | Office Equipment & Supplies
Brother 5250
I had the same problem on 4 Brother HL-5250's, I checked the whole printer, and couldn't find a paper jam, yet the red printer light wouldn't shut off. I finally followed the instructions on Brother's website for removing a paper jam, and the solution for all 4 printers was paper stuck in the fuser cover. See below on how to open the fuser cover.
Pull the tabs at the left and right hand sides toward you to open the fuser cover (1).
  2. Hint
  3. There are 2 kinds of covers at the rear of the printer. Please make sure to open both the back cover (step 7) and the fuser cover (step8).
  • May 27, 2008 | Brother HL 5250DN Laser Printer
    Brother HL-2070N Laser Printer Logo
    789 people viewed this question
    James Cagle
    James Cagle
    Samyfam
    Samyfam
    Jim Keysor
