Question about Refrigerators
I need some parts for refrigidare # frs28zrg how can i get it?
  • 231 Answers
Try partstore.com
http://www.partstore.com/ModelSearch.aspx?MfgName=Electrolux&BrandName=Frigidaire&ModelNumber=frs28zrg
They are asking more details about your model.
Good Luck!!
Posted on Dec 26, 2008
How to tell if refrigidare temp is working
please, could you be more specific? if you are asking about car ac system, is very noticeable if it is not working or you could use a thermometer..it should be from the top of my head around 36-40 degrees
Sep 24, 2017 | Cars & Trucks
Our fridigaire refrigerator model #frs28zrg's ice maker is leaking water into the ice storage bin causing it to freeze over and the ice is unable to come out the door. We have to take the ice out every...
The reason that is happening,is the water inlet valve is not fully closing and seeping water through it,it drips into the ice storage bin and freezes the ice into one huge block. To fix that the water inlet valve needs to be replaced.Their are 2 valves on that refrig. and the one that is causing the problem is the one with dual outlets its part # 218658000 It can be purchased at your local appliance parts store on online at
searspartsdirect.com
repairclinic.com
apwagner.com
apdepot.com
midwestapplianceparts.com
Gene
Aug 21, 2011 | Frigidaire Refrigerators
What is the capacity of kenmore refrigidare 596.79272993
Made by Amana, age should be over 10 years old. Users manual:
http://www.managemylife.com/mmh/owner_manuals/search?sid=MMHMxSearsx00019&query=59679272993+KENMORE
Many replacement chassis / cabinet parts not available. Common items are still available.
Have tried using multiple sources for size computation including parts look up. Most come up with 22.4 Cu ft
Kelly
Sep 22, 2010 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Frs28zrg leaking. frozen water in bottom of freezer. drips on inside of fridge/freezer. water/ice not working....should I attempt to fix this or pay $100 for my home warranty repair...
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model clean drains
Aug 15, 2009 | Frigidaire FRS3R5EMB Side by Side...
Need Oce 3165 parts manual; can you provide? We need a new TTF belt, etc.
I have all the parts u need and i can send the parts catalog as a pdf file if u need
ahosam at yahoo
Jul 10, 2009 | OCE Office Equipment & Supplies
I have a Frigidaire frs28zrg with puresource water filter purchased used so probably 3 to 6 yrs old maybe more. The dispenser stopped dispensing water rather suddenly, but it's still making ice. We...
Check the reservoir behind the crispers for frozen lines. If it is froze it will take several days to thaw out with the frig below 40 degF. If it is not frozen you can disconnect the line at the water valve and see if the lever is operating the valve. Switch, water valve and waterlines and filter. process of elimination to find the culprit. Eric
Jul 08, 2009 | Refrigerators
Howling noise in frig
You need a new Fan motor . Or oil in the right place may do if it not worn by now.
Feb 24, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigidare model # plhs267za
sounds like the air damper control for refrig is freezing in the open positon. not a really consumer freindly repair,(dropping side control panel checking damper door for ice build up, removing ice and applying a silicone lubricant(vasiline) to prevent further freezing of air damper motor. sounds easy enoug but that panel is real tricky to drop and mount back in.
Mar 04, 2008 | Frigidaire PLHS267ZA Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
