Question about Toshiba Satellite P105-S6104 Notebook
Display has 2 inch black stripe running vertically down screen
Recently had a Bios upgrade. The next day a 2 inch black stripe appeared down the middle of screen. Is this fixable?
  • jordidjh Jan 12, 2009
    I have a Toshiba Qosmio G10 which has just developed the same problem. Nothing's been done to it, not been dropped, no system changes. It started with a 2ins wide vertical black strip down the screen, after trying to fix it, it started to resemble more of a vertical barcode striping and now is simply a faded area on screen with small horizontal lines visible in the strip area. Any ideas?
  • Shoaib Rais
    Shoaib Rais May 11, 2010
    see if this black strip is also on the external monitor if u connect a monitor thru vga
I have an IBM think pad that developed a 2 inch black strip on the left side of my dispaly. I tried restoring to a previous setting, I updated video drivers, I reset display properties. None of the above worked and am now thinking of formatting and reinstalling windows as a last hope unless someone has any other ideas.
Posted on Oct 28, 2010
Display issues
no photo posted, of bad screen, why? why make help blind?
the display LCD is bad.
or is the 2008 , solderballs Nvidia chip failure.
if the screen fails in BIOS (press f10 or ESC to enter setup
an fails under boot CD linux or any kind the screen is bad
test with big battery out, always. run on AC power only to test.
do the funny LINES change if you gently twist screen case?
i see reviews on this LT back to 2009
the vista review page on its support pages is stamped 2008
oops !
the BIOS screens are here. hit ESC then F10
dv7-1245dx
this is called hp setup, its BIOS.
if these screens look bad, bingo for bad screen LCD or the GPU.
http://h10032.www1.hp.com/ctg/Manual/c01662442
Jan 01, 2018 | HP Pavilion dv7-1245dx Notebook
How to fix vertical black line on panasonic viera th-42pz80
If you let me know in which location of the screen is located I can assist with the possible cause since the vertical line can be caused by different items based on where its located on the Screen such as center of screen, or far right side or midle of the right half side of the screen. Reply to this same post with where the line is located and I will assist you with it.
Oct 16, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
Vertical black stripe on screen
Hi my name is Roety,
I can help you with your issue ,
The black strip is either a bad panel or part of the lower buffer board is bad. There are ribbon cables that run from the panel to the buffer it may just be a loose ribbon connector
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Dec 29, 2009 | Gateway GTW-P42M303 42 in. Plasma...
Right half of screen is Black with a White vertical stripe
Yeah, I have this exact same problem, except my mom slammed my laptop shut in frustration around half an hour ago, so that's why it's like this. The right half of my screen is black with two colorful stripes (mostly white), but the left half is visible. I've researched a bit and found out that this is because the LCD in your monitor has burnt out, and since you don't have a monitor to attach, the only thing you can do is to go to where you bought the laptop and either get it fixed for free or return it for a brand new one (if your warranty still stands). If not, you might as well get a new laptop. I think my warranty has expired, so I'll get a new laptop, hopefully.
Hope this helps!
~Sam.
Jun 08, 2009 | HP Compaq FP 7317 17" Flat Panel LCD...
Windows Vista freezes while loading up& Blue Vertical Bars appear
Hi
Reflashing the bios doesn't make any difference.
Check in the BIOS Screen whether notebook scree has the same issue if it is the same then it is a hardware issue if it is fine in the bios screen then need to run the hdd and memory test
After the test result we can decide next steps
> If hdd and memory test passes - then reload the os.
To login to bios - Reboot the system and keep tap on f10
Apr 28, 2009 | HP Pavilion dv9000z Notebook
Magnavox 42MF7000/17 Green Stripes Pixel down section of display
Possible Defect in programing. Call Manufacturer for possible support in Updating Firmware.
Jan 18, 2009 | Philips Magnavox 42MF521D/37 Television
Booting problems with my Toshiba Satellite P105
Try to reinstall the video driver from Safe mode.
It appears your hard disk is OK but the operating system and or registry is corrupted.
1. Try installing the video driver first.
2. If it still does not work, back up your data files in Safe Mode then re-install XP again, make sure you delete the partition and create a new partition and do a full NTFS format, not a quick format.
Nov 12, 2008 | Toshiba Satellite A25-S207 Notebook
Black Vertical Stripe Our Hitachi plasma TV has just started displaying a vertical black stripe about three inches wide right down the middle of the screen. This stripe comes and goes every hour or so,...
try doing white wash feture in options see if u can get it out this way 1st before having to take aprt cheak cables are using old style sumtimes they do get glitch do factory reset thx for using fix ya . nick
Feb 03, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Dark Vertical Stripe on Right Edge of Screen
I experienced the same approx. 1/2" vertical stripe on a Viewsonic vx1945 and ATI Radeon x1050 video adapter on Vista Business SP1, but the stripe appeared along the left edge of the screen, instead of right edge. I then temporarily decreased the monitor resolution, and the stripe went away. I then increased the monitor resolution back to its original setting, and the stripe did not re-appear. So, that was the 'fix' in my situation, hope this helps.
Dec 11, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Toshiba Satellite P105-S6104 Notebook Logo
1,152 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
