Question about Tatung Elio Photo JukeBox MP3 Player
Usb problem When I plug my new elio photo duke box into the usb port of my Dell computer it comes up with unrecognised device. The same thing happens when I plug it into all the other usb ports. I have followed the troubleshooting guide and gone into device manager to update drivers It then says I have the most recent version. The software on the disc was sucessfully installed and my Dell computer is only 3 years old with Windows XP as the operating system. What could be the problem
Just thanks to the person who replied. I still cant use the Elio on my Dell computer 'says USB Device not recognised,' but it works on my boyfriends new Dell computer and on the computer at work. I contacted Dell support and they emailed me with a web address to download some drivers which I did. It actually recognised the device for about 2 mins but them the same thing happened again keep pluging it in hopeing it will connect again but it doesnt also the battery shows low after very little use. Wonder if I can return the elio it is still under guarantee. Kasy
Posted on May 09, 2007
Absolutely no idea but mine does the same thing....works ok on my sisters non dell computer.......
Posted on May 08, 2007
  • dave coates Jun 01, 2007
    perhaps its cos dell use only usb 1.1 they dont really like using 2.0 as it adds cost .......i am going to buy a 2.0 card andwill report results( side of elio says it need usb2.0
  • dave coates Jun 04, 2007
    went and bought a pci card that sits in a spare slot on mother board(2 min to fit) its a usb2.0 card....now works fine..card cost me 15 quid from local pc shop......as i said before, cos of the low cost of dell pc`s they normally only fit usb 1.1 sockets.......elio now works perfectly!!!!
SOURCE:
I have taken some new photos on my camera but when I have connected it up to the pc to transfer the photos it keeps saying no new picutures or video were found on this device
TRANSFERRING PHOTOS TO COMPUTER
If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
May 27, 2012 | Ricoh Caplio GX Digital Camera
It cannot transfer pictures to Computer, unrecognised file format
May 09, 2012 | Vivitar ViviCam 8320 Digital Camera
I plug in my GEx5 to my computer but my computer doesn't recognize the camera
some cameras need to have the software installed on the computer, did you install the software? depending on the age of the computer some devics can be power hungry on usb ports and so will come up as unrecognised devices, ive expirienced this myself. or last but not least the camera has a faulty usb controller inside, there are a few reasons but the worst one is when its the computer is an old one and the usb ports just dont have enough power to run the camera.
Sep 06, 2011 | GE X5 Digital Camera
When I plug in a device my dell says I do not have usb 2.0
The Dell website says your model comes with 2 usb ports in from and 5 in the rear, all of which are usb 2.0. If this is happening with just this one device then there might be a problem with the device not your PC. Try plugging it into one of the other ports and try a different device. If you get the message on all of the ports and with all divices then the USB driver may have been corrupted go to the Dell website and look for updated/new drivers, there is probably a direct link to dell on the start menu. If you have the resource disks for the computer one of them is probably labled as having the device drivers on them. Put that disk into your drive then from the start menu open control panel, double click on system and go to the hardware tab. Open the Divice Manager. At the bottom of the list expand the Universal Serial Bus Controlers. Right click any of the USB Root Hub entries and select update driver, follow the instructions on the wizard that opens. Good Luck
Dec 10, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
My USB port is saying unrecognised drive
Most of the time when this happens its the device that your plugging in. Try another device in the same port. If it gives you the same error then it may be the port. If it works then its probably the device.
Sep 19, 2009 | Intel D945GCL Motherboard
Moultrie 40 spy camera will not put photos on sd 1gb card
TRY A DIFFERENT USB PORT ON PC...usb has 2 standards...1.5 and 2.0...new Dell,at least, has 1.5s on front;faster 2.0 usb ports on back...2.0's will drive 1.5 devices, but 1.5 ports won't drive 2.0 devices
Aug 31, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
I'm trying to use the Sakar CR-75 Digital Card Reader to transfer photos from my telephone memory card to my computer. I've done this in the past with the same card and the same computer but now I can't...
does the same happen if you try on another computer (if it does then replace the cable or connect device directly without usb cable extension (if applicable))
if it works fine on another computer..
what happen after you plugged the device on your computer? have you try different usb ports? does other devices work fine on the same usb ports on your computer?
Dec 02, 2008 | Computers & Internet
Palm 515
Hi yes the plug into the cradle if this is fine then the firmware could have become corrupt due to virus or some data getting change this can happen.
The other thing you can try is remove all the software off the computer then plug the usb in and see if your computer tells you in a pop up box that new device has been found.
If it says this then the chances are its software of firmware problem ok.
If your computer dont give you pop up box telling you new device connected then the try another usb port to rule out the usb port being the problem or try a different device in the usb port to make sure its working fine.
If your computer dont pick the palm up then the problem is more likely to be hardware related like port on palm damaged or even internal parts failing inside the palm.
So just try plug it into usb port and see if your computer picks it up look under my computer and see if its listed their then let me know ok
Mar 27, 2008 | Palm m515 Handheld
No power adapter or cradle to charge my elio jukebox
Yes, the Elio will charge from the USB cable to the computer
May 25, 2007 | Tatung Elio Photo JukeBox MP3 Player
Elio doesnt connect
i have similar problem, i think i know why mine doesn't work. My son connected the usb port to power supply, since then the elio manager does not recognise that the player is connected.... something must have blown in the usb circuitry
Jan 29, 2007 | Tatung Elio Photo JukeBox MP3 Player
Tatung Elio Photo JukeBox MP3 Player Logo
161 people viewed this question
Top Tatung Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Tatung Audio Player and Recorder Expert? Answer questions, earn points and help others
