Question about Dell W4201C 42 in. Plasma HDTV
No Picture Dell W4200HD has ready light. When I hit the power button, the power button goes from standby(purple) to on(blue). After 5 seconds, I can hear the 12v and 5v sub power go out in sequence. After this, the power on(blue) light stays on, and the only way to turn it off is to disconnect it.
  • Roderic Collins Dec 29, 2008
    I changed power supplies, but still had the same symptoms. At that point, I then proceeded to check all connections and make sure that they were making contact. I tried the power button again, paid attention to the led's on the main i/o board, and noticed that they were all lit, and stayed lit. I then connected the cable input, and enjoyed the beautiful picture that came out.
  • RJP1965 Mar 09, 2009
    My apologies to the community. It looks like I posted my same problem incorrectly as a solution. I do not have a solution to this problem yet.
    Problem Solver:
  • 10 Answers
I had the same problem and I found a shorted 100uF 100V electrolytic capacitor on the lower logic level scan board. This board was located underneath the I/O tuner section on the tv. This shorted capacitor was keeping the 70V "VA" power supply output from starting. There are 8 caps total on the 4 logic level scan boards in the tv so you should replace them all.
Posted on Jul 11, 2010
Hello. It looks like I have the same problem that you had with your Dell W4200HD.
Where did you find the new power supply for yours?
Also, did you determine that you didn't really need a new power supply and that it was just a connection problem? If yes, could you please give me some help with what you did to get yours working.
Also, do you still have the power supply you took out of your TV? If yes, would you be willing to sell it to me?
Thanks in advance for your assistance.
Rocky Pruitt
Posted on Mar 09, 2009
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
My Sony KP-46WT500 screen shows the tv image in blue only for a few seconds, then it goes completely blank (as if it were off). Do I need to replace the bulbs?
It is rear projection TV that use 3 picture tubes of red-green-blue to show color picture on tv front screen.
Do you see standby red light blinking when TV shuts off after showing blue image for a while?
If red standby light is blinking, please count it how many times it blinks, there would be 3 seconds pause between blinks so count pause to pause and post it here to find out possible solution.
Dec 22, 2009 | Sony KP-46WT500 46" Rear Projection...
Hi- we are having a problem with our just started overheating....we forgot to open the door...I heard the fan kick we turned off the ps3 to let it cool the ps3 is running...we...
try video reset
when ps3 is in standby mode(red light)
press and hold the power button till you hear a second beep.
standby mode press hold power........"beep"......"beep"..release power button
then try rebuilding the database and the file system in recovery consol
to get to the recovery consol press and hold the power button when ps3 is in standby mode(red light) till you hear a double beep. sometimes the ps3 does a beep then another beep and goes back into standby thsi is fine just release the power and quikly press and hold it again till you get double beep.
like on my 80g system it goes like this
ps3 hold power.......beep .........beep........stanby again....release and hold power again.......beep .........double beep...release power now you should be in recovery menu.
Oct 20, 2009 | Sony Playstation 3 (PS3) Console
My Dell w4200hd will not turn on. The color on the little light by the power on/off switch will change from what I think is standby color to a different color when I try and turn it on, and I hear...
i do have the power supply at my shop. but i don't think the power supply is the problem. i already replaced the power supply on this set with this symtom and no help. you can find parts at J.D.W.
Mar 08, 2009 | Dell W4200 42 in. HD-Ready Plasma...
Sleep Mode Lockup on Dell Inspirion 530 w/ Vista
Try hitting the "Windows" key on your keyboard to bring it out of sleep mode. The "Windows" key is generally found on the bottom row of the keyboard, near the Alt and Ctrl keys, and it has no letters on it, just the Windows logo. That key brings my Windows Vista machines out of sleep mode when other keys won't.
As for the power button, anytime you need to force a computer to turn off, you can press and hold the power button to do so. Usually, you need to hold the power button for 5-10 seconds and it will shut down. Use this option with caution, as it turns the computer off without running through the shutdown process and can cause you to lose data.
Hope this helps.
Mar 08, 2009 | HP Media Center m7060n PC Desktop
TV will not turn on
Nov 11, 2008 | Televison & Video
Dell W4201C 42 in. Plasma HDTV Logo
434 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
