Question about Kenmore Elite 45986 Front Load Washer
Kenmore elite he3 model # 11044832200 gives me a f15 error code. have already unplugged and replugged every connection between the CCU, MCU and drive motor, machine will fill and drain properly but will not aggitate and spin, belt, motor and drum will rotate by hand, so I am not sure which component is bad (MCU, CCU or drive motor?) can you help?
  • 640 Answers
It because you change cycles in the wash mode,,over reset...all fixes accept reset unplug .needs technician...if you fell you can do this repost question,,as replacing motor control unit
Posted on Dec 26, 2008
How much does a motor control part cost for a kenmore elite he3 washer
Posted on May 06, 2009
F28 error code on kenmore elite he3 washer
F28 error code is a communication problem between the CCU and the MCU. Try unplugging the machine for several minutes.
Nov 28, 2016 | Kenmore Washing Machines
I have a kenmore elite he3. i do not know if it is a kingsize or not, but i get the error code F11, model # 11046742700, serial # CSU3001599. I was told to unplug 3 wires on the board to reset the washer....
"F11" is a Serial Communications error between the Central Control Unit (CCU) and Motor Control Unit (MCU). The CCU is the main computer for the washer and is located directly behind the wash tub. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem.
Whirlpool is the manufacturer of both model washers and recommends the following troubleshooting advice. Remove the top panel of the washer by removing the three screws holding it in place in the rear. Once the screws are removed, the panel slides back, then off. Remove the rear panel of the washer for access to the drive motor and MCU. Now check the following:
- Check the wire harness connections between the CCU, the MCU and Drive Motor. Make sure all connections are attached and making good contact. Check for any broken wires or connector pins.
- Check the Drive Motor to see if it free spins and that the belt is still attached and not slipping. If the motor is seized, replace it. If the belt is broken or worn, replace it as well.
- Check the MCU. Connector 1 is the Serial Communications Link between the MCU and CCU. Connector 2 is the connector to the drive motor. Resistance checks across pins 1, 2, & 3 are the motor windings. Connector 3 is the power supply - 120VAC should be read across pins 1 and 2 with the door in the locked position. NOTE: The connectors are read 1, 2, and 3 from the bottom to the top with the MCU installed.
- Check the CCU. Verify connectors 7 and 11 are properly installed. Facing from the front of the washer, connector 7 is the 4th connector from the RIGHT along the front. This is MCU Power. Connector 11 is the Serial Communications link from the CCU to the MCU and is located along the left hand side of the CCU (the connectors are numbered 11 through 14 back to front).
- Check the Drive Motor. Remove the connector and perform resistance checks on the motor connector pins. Readings across pins 1 to 2, 2 to 3 and 1 to 3 should read 6 ohms.
In most cases this is an indication of a failed CCU. This is an easy repair that the average do-it-yourselfer can accomplish on their own. If the washer is still under a warranty, parts and labor would be covered. With no warranty, a replacement parts will vary in price depending on where you get them. There are several good websites available that you can order parts on line and have shipped directly to you.
NOTE: Remove all the connectors from the CCU ONE AT A TIME and reconnect to see if the error code goes away BEFORE you decide to purchase a new one. It is not common, but sometimes a flaky connection can generate error codes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!!!
Aug 30, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
I have a kenmore elite he3 front loader washer. it gives me a f11 code when i attempt to wash a load.
F/11 is serial communication error code. It means the communication between the central control unit (CCU) and the motor control unit (MCU) is not good. Possible causes include worn or failed drive system components, faulty CCU or MCU, broken wiring harness, faulty drive motor, or faulty wiring harness connections in the CCU, the motor, or the MCU.
Jun 09, 2010 | Kenmore Elite 45986 Front Load Washer
F6????
The F06 error code on the HE3 elite is a tachometer error. Per the tech sheet, it says to check all connections and continuity between the MCU, CCU and Drive Motor. The tech sheet says normal reading is at 6 ohms.
Apr 18, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
I have a kemore Elite HE3 with a F11 code. It will restart and run for another min or so. I have checked the wires and connections
F/11 Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
Jan 09, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore HE4t washer has an F06 code
"F06" is a motor speed error code. This means there is a problem with either the drive motor, motor control unit (MCU), or interconnecting wiring. The following link explains:
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
I would begin by attempting to reset the Central Control Unit (CCU). This is the main computer for the washer. Sometimes these error codes can be erroneous. If you unplug the washer for at least 30 minutes, this will reset the CCU. Often, this is all that is required to correct momentary glitches. If the error code reappears following a CCU reset, then you have a legitimate problem.
If resetting the CCU doesn't work, verify all your connector plugs on the drive motor and MCU by unplugging and replugging each one (one at a time). Sometimes these connector plugs can vibrate loose.
If these preliminary steps don't work, follow the advice in the link provided. If you have any questions please let me know. I hope this helps you.
Jul 17, 2009 | Kenmore Elite 45986 Front Load Washer
F11 Code Error
Hi. this is a Serial communication error
This will occur when the Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Potential Causes
• Check Wire Harness connections to the MCU, the motor, and Central Control Unit (CCU)
• Check MCU
• Check CCU
• Check Motor
Most cases, it will be a fualty wiring harness
Jul 13, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 front loading washing machine(F11 code)
Jun 28, 2009 | Kenmore Elite 45986 Front Load Washer
Help! Mt Kenmore Elite Quietpak2 HE3 keeps
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Mar 10, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore HE3 stops in middle of cycle, flashes F-11.
  • Check MCU
  • Check CCU
  • Check Motor
Dec 08, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
1,097 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
