Question about Kenwood VR-5090 5.1 Channels Receiver
When switching devices I loose audio after a few minutes after power on.
I have had this unit for at least 4 years now, with no problem. Now when I turn it on, after not being used for a while everything is OK, then after a few minutes I loose the audio when I switch between devices. I have stripped all inputs & outputs down to a minimum (center speaker & TV video out only, cable & DVD in only), and the problem persists. Powering on and of does not help once the problem occurs, but time helps. Is this some kind of overheating problem?
    Genius:
  • 1,074 Answers
Have a tech check your set for lose solder or possibly the audio circuit.good luck.
Posted on Apr 19, 2007
I have a 4 year old Bosch Ecologixx 7 self cleaning condenser dryer, WTW86561GB/02. The problem is after 10 minutes the machine just switches off, and the display panel goes dark
sounds like the thermal safety overload is cutting the power due to overheating hence why it just turns back on after a certain time, when the safety overload reaches a certain temperature it will cut the power to the machine or in some cases just the heating elements, once it cools down it resets and power is restored and by using the warm setting it obviously isn't as hot so its not overheating, its highly likely it is all blocked up internally with lint (i know it says self cleaning but they never work for more than a few years before requiring a proper clean and service)
Jan 30, 2017 | Bosch Washing Machines
How do i fix after modem reset
Basically, you unplug all of the Netgear Xe104 units, wait a minute, then plug the one nearest to the Router back into a wall socket first. Wait a few seconds then plug in a second Xe104 and give it a minute to "talk" to the first unit. Then plug other Xe104's in one at a time. Below you'll find the official troubleshooting steps which you should read carefully if the basic steps above do not resolve the problem.
Also, i should tell you that Powerline adapters such as yours have improved greatly in the last few years, and you can buy a pair of new ones that are very, very much faster than yours for a very modest cost. For example, TP-LINK TL-PA4010KIT
or NETGEAR Powerline 500 1-Port Starter Kit (XAVB5201) or
ZyXEL PLA4225 4-Port 500 Mbps Powerline Gigabit
XE104 User Guide 4-2 Troubleshooting v1.0, September 2005
Power Light Not On Make sure that, if power to the AC power outlet is controlled by a wall switch, the wall switch is in the on position. Verify that the wall socket is live by disconnecting the XE104 85 Mbps Wall-Plugged Ethernet Switch and plugging in some other electrical product, such as a lamp or a hairdryer. If the error persists and you have confirmed the power outlet you are using is live, you have a hardware problem and should contact technical support.
HomePlug Light Not On If the power light is on but the HomePlug light is not, check the following: • Make sure that power is being provided to more than one PowerLine device. Another PowerLine device must be installed for successful communication across the PowerLine. • Verify that the network password is the same on all devices in the PowerLine network.
Ethernet Light is Off • Make sure that the Ethernet cable is plugged in properly at both ends. • Be sure you are using the correct cable on the router that the first XE104 is connected to. When connecting the router's Internet port to a cable or DSL modem, use the cable that was supplied with the cable or DSL modem. This cable could be a standard straight-through Ethernet cable or an Ethernet crossover cable. • On attached Ethernet device or network adapter card, check that the Link light is
Feb 25, 2015 | NetGear Xe104 Wall Plugged Ethernet Switch...
My DTC 6200 converter/decoder was working fine. A few weeks ago I have disconnected it, pull the power cord out of the AC outlet, put the decoder in a safe place. Then when I finish painting, I hook...
Hello
Check out these with your Motorola converter
[1] Verify that the AC power cord is connected to the DCT*
and an AC outlet.
[2] If the DCT* is connected to a switched outlet on another
unit, verify that that unit is powered on.
[3] Press the POWER button on the DCT* front panel instead
of the remote control. The batteries in the remote control
may be depleted
[4] The DCT* may have received a software update and
may not power on while the new software is being
installed. Try again in a few minutes.
OK.
Oct 21, 2011 | Arris DCT6200 DTV Receiver
I have model kn-cob-lcb-ca...it does not have a digital display, it was made in 2009..a few nights ago it started beeping...4 beeps, 5 second pause then 4 beeps continuously..the manual says this is a...
send the detector back and have it replaced,
The CO sensor will not alarm to levels of CO below 30 ppm and will alarm in the following time range when exposed to the corresponding levels of CO: 70 ppm CO Concentration 60 - 240 minutes 150 ppm CO Concentration 10 - 50 minutes 400 ppm CO Concentration 4 - 15 minutes The alarm shall include a piezoelectric horn that is rated at 85 decibels at 10 feet. When the unit detects carbon monoxide, the alarm pattern will be four (4) short beeps - followed by five (5) seconds of silence - followed by four (4) short beeps. The unit shall incorporate 2 LED's. A green LED will be illuminated to indicate the alarm is operating properly when plugged into an outlet, and will flash every 10 seconds when on backup battery power. A red LED will flash to indicate that carbon monoxide has been detected until the device is reset or CO is eliminated or will flash to indicate low battery or alarm malfunction. The unit shall at a minimum meet the requirements of CAN/CSA 6.19-01. It shall also include a 10-year manufacturer's limited warranty or
Test/Reset Button - Tests the unit for proper operation. Resets the carbon monoxide alarm.
• Tamper Resist Feature - If activated, unit goes into constant alarm mode if it has been unplugged or has come loose from the outlet.
Sep 20, 2011 | Kidde Nighthawk Combo Gas/co Detector
I have a Sony STR-DH800 which was purchased in May of this year. It was working fine until last weekend when the speakers popped and the unit said it was protecting and shut down. Now I can power on the...
Only solution go back for warranty if there is no answer for this solution in the user manual.
release power connector for a moment isnt the right thing tom do , this product is to young for any kind of problems, the hum is look like there is a capacitor damaged or something loose in the power supply that there failed a powerline , the only thing is back to the dealer for warranty.
Apr 23, 2017 | Sony STR-DH800
The display turn off after few minutes (blank screen, no message). When it does that, the power led stay green. When I turn it off and on, the display work again for a few minutes and the same problem...
jackperson, Might be internal problem with the units power supply (ac line in to DC conversion) having shutdown issues. You will need to do some reading in my fixya profile for a while and then you will know what to look for inside unit. If not into electronic repair stuff, skip the reading and trade-in unit for new, if current unit is 4, 5, 6 years old. 12fixlouie
Mar 12, 2010 | LG L1730S 17" LCD Monitor
No Audio
IT MAY BE A GOOD IDEA TO CHECK THE WIRES BEHIND THE HEAD UNIT AS THIS IS WHERE EVERYTHING IS POWERED FROM, MAYBE A LOOSE EARTH LEAD OR MAYBE A LOOSE POWER LEAD, SOMETHING SOUNDS LOOSE.
Jun 18, 2009 | JBL BP1200.1 Car Audio Amplifier
Hoveround MPV 4. Joystick problem?
Count how many lights are flashing to determine the root cause of the problem. Here is alink that may help:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
The abrupt stop may have knocked something loose.
Apr 09, 2009 | NRS Hoveround MPV 4 - Hovaround Used...
Xdm46cc
I bet your unit is about 4 years old...
I have installed 4 of these systems 4 years ago and each is failing at about the 4 year mark (3 so far).
The flashing volume lights are a communication error, meaning the keypads are not communicating with the controller. If all of the keypads are doing the same thing and your have checked your cables then the problem is with the controller. I would unplug the unit for a few days and see if that helps.
It appears the units work consistently and reliably for about 4 years however in my case 75% have failed at the 4 year mark.
Fortunately I have a meter and oscilloscope and determined why they are failing. The main power supply unit that feed power to the 5VDC regulator is failing.
It is not clear whether M&S replacement units have addressed this problem or not. Therefore, to fix the problem for my customers, I added and additional small power supply (fits inside the case) and injected the signal on the input side of the 5VDC regulator. My solution hopefully will not expire after 4 years.
It appears to me from my small sample size that M&S may have a flaw in their original engineering and replacing it with the same will guarantee future failure.
I hope this helps others. :)
Oct 29, 2008 | M&S Systems Local Audio Input Module -...
Magellan roadmate 300 wont stay on
It is the cigarette adapter, mine was doing the same thing until I bought a new adapter. When the old adapter plug to the GPS unit moved at all it would lose power.
Jan 13, 2008 | Magellan RoadMate 300 GPS Receiver
Open Questions:
Kenwood VR-5090 5.1 Channels Receiver Logo
88 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Mike Duncan
Mike Duncan
rigger094
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
