Need code for universial remote or where to buy the Fujitusi remote
SOURCE: Universal RCA Remote controll
If what the prior poster said doesn't work- try this, Take your old ILO remote to a large VCR store-one that displays many brands on a shelf, and they are all plugged in. Just point your old ILO remote at the shelf of VCRs and press the on/off button on the old remote. The unit on the store's shelf(reguardless of brand) that "Blinks" is the manufacture's code you are looking for. So if a Sony 'blinks' use the sony codes that came with your universal remote. A lot of 'brands' are made by the same company, dependant on year of mamufacture, EG Sony=some Sharp=wards admrial, Panasonic=some GE=some Quzar=some toshiba
SOURCE: Insignia TV code for RCA Universial Remote Control (RCR450)
What about trying a code search with the remote itself.. Turn on your tv, Push and hold the TV button till it blinks, then press and hold then SETUP button while pressing and releasing the PWR button continously till the tv powers off. Once it does that, press PWR again. TV should come on and the code will then stay locked in.. Good luck again
SOURCE: need remote code for programming a bell expressvu receiver
Here for the Jensen remote just click below;
Here is link to the manual:
http://www.remotecodelist.com/remotes/jensen/JR300C.pdf
Here is some helpful information I found:
Without the code on JER-323:
1.Manually turn on the component you want the remote to control.
2. Press the device button, example:( TV) and the (power button) for 3 seconds until the (on/off button stays lit).
3. Once the (on/off) button is lit, press the (on/off) button until the unit (the TV or unit you are trying to control.) turns off.
4. When the code is located, press the (stop) button at the bottom to save the code.
Here are some codes I found for the Jensen 323:
GE VCR: 2000, 2013, 2021, 2022, 2053, 2087, 2089, 2091, 2115, 2120
Motorola Cable Box: 5000, 5003, 5046, 5047, 5052
Mitsubishi TV 0093, 0150, 0178, 0019
JVC VCR 0067, 0041, 0008
JVC DVD 0558, 0623
Hope it may help you;
Regards,
VOTIT
SOURCE: need samsung remote codes for apex tv
I was able to program my Samsung P241 DVD to my APEX TV remote (CK5D-C1) using code 352. I see that it is also the code for Hitachi DVD.
SOURCE: I have an RCA universial remote control and lost
Visit this link. On the bottom right side of the page, it is written in red: "Find your remote codes here!", click on this and a new window will open.
Select your remote control model from the drop-down menu and you will be presented with its manual and complete list of available codes.
Testimonial: "Thank you very much this helped solve my problem...."
